SINCGARS
Frequency Band |
30.000 MHz to 30.550 MHz |
32.000 MHz to 33.000 MHz |
34.000 MHz to 35.000 MHz |
36.000 MHz to 37.000 MHz |
38.000 MHz to 39.000 MHz |
40.000 MHz to 42.000 MHz |
46.600 MHz to 47.000 MHz |
49.600 MHz to 50.000 MHz |
It should be noted that military operations in single channel mode are found on any frequency between 30.000 and 87.975 MHz outside the government/military exclusive use bands on a non-interference basis. Use of the 150.0 Hz CTCSS or PL tone squelch allows for frequency sharing with other users. This, combined with the fact that civilian allocations in the 30-50 MHz band use 20 kHz channel steps, compared to the 25 kHz channeling used by military VHF-FM or SINCGARS systems. The 150 Hz tone squelch is close enough to the civilian 151.4 Hz CTCSS tone that many scanners or communications receivers will decode military VHF FM traffic as having 151.4 Hz CTCSS when in reality they are transmitting 150 Hz. Use of 150 Hz also permits the operation of "relay" (repeater) setups using two radios, the appropriate cables and filters and a high elevation location. Relay functionality has been included in FM tactical radios since the SCR-300 (BC-1000) series. It was not, however, heavily used until the Vietnam war. Most battlefield relay sites use RC-292 or similar high performance antennas. The wide frequency range of modern FM radios allows for maximum flexibility in choosing frequency pairs.
The 46.6 MHz - 47.0 MHz and 49.6 MHz - 50.0 MHz bands are shared with low power devices such as cordless phones, low power walkie-talkies and R/C devices.
Background and History
- 26.000 MHz - 69.950 MHz SEM-35 and similar clones/variants used in Europe and elsewhere
- 26.000 MHz - 70.000 MHz Radio Set 3600 - Dutch origin, used in various countries
- 26.000 MHz - 70.000 MHz TRC-552 - French origin, used in Africa, etc. as well
- 47.000 MHz - 56.000 MHz PRC-239 manpack radio, from Italy, exported to Middle East, etc.
- 40.000 MHz - 50.000 MHz PRC-439 manpack radio, from Italy, exported to Middle East, etc.
- 26.515 MHz - 27.99125 MHz Export CB radio European UK band plan (see also: 26.510 MHz - 27.860 MHz, 26.565 MHz - 27.99125 MHz)
Evolution of military FM radio tactical radio bands: World War II, Korea and Beginning of Vietnam War (roughly 1940-1965)
Frequency Band | Use | Channel Step/Frequency Spacing |
20.000 MHz to 27.900 MHz | Armor Band (tank radio, tank destroyers, tank command nets) | 100 kHz (channels 200-279), PRC-8, PRC-8A, SCR-508, SCR-509, SCR-510, SCR-528, SCR-538, etc |
27.000 MHz to 38.900 MHz | Artillery Band | 100 kHz (channels 270-389), PRC-9, PRC-9A, SCR-608, SCR-609, SCR-610, SCR-628 |
38.000 MHz to 54.900 MHz | Infantry Band | 100 kHz (channels 380-549), PRC-10, PRC-10A, BC-1000/SCR-300 (partial, 40-48 MHz only) |
40.000 MHz to 48.000 MHz | Infantry Band (partial) | 200 kHz (channels 0-40), SCR-300 (BC-1000) manpack backpack radio |
Most of Vietnam War and Cold War (roughly 1965-1980s)
30.000 MHz to 75.950 MHz | Tactical Band (30-76 MHz) (150 Hz CTCSS "new squelch" system) removes need for manual squelch control | 50 kHz (channelized intent frequency control) PRC-25, PRC-77, VRC-12 and dozens of others |
1980s-present
30.000 MHz to 87.975 MHz | Tactical Band (30-88 MHz) 150 Hz CTCSS (some radios allow use of other tones) | 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode |
30 MHz to 512 MHz | Tactical Band (30-88 MHz) combined with VHF/UHF bands, including the airband, VHF marine band, VHF land mobile bands | 25 kHz step, single channel SC (fixed frequency) mode or frequency hopping FH (anti-jamming countermeasure) mode, 2.5, 5, 8.33 kHz steps |
380-470 MHz | Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems | Various frequency steps and modes used for short range communications within squads/fireteams |
2400-2500 MHz (2.4 GHz) | Intra-Squad Radio (ISR) and Improved Intra Squad Radio (IISR) systems | Various frequency steps and modes (including spread spectrum and frequency hopping) used for short range communications within squads/fireteams |
