Radio propagation beacon
History
Transmission characteristics
160 meters beacons
60 meters beacons
Callsign | Frequency | Locator | Details |
DRA5 | 5195.0 kHz | JO44VQ | DARC |
LX0HF | 5205.2 kHz | JN39dr | Radioamateurs du Luxembourg [1] |
HG7BHB | 5252.3 kHz | JN97LE | |
OK1IF | 5258.5 kHz | JO40HG | Inactive. Recording: [2] |
GB3RAL | 5290.0 kHz | IO91IN | RSGB, inactive |
GB3WES | 5290.0 kHz | IO84QN | RSGB, inactive |
GB3ORK | 5290.0 kHz | IO89JA | RSGB, inactive |
OV1BCN | 5290.5 kHz | JO55SI | Op OZ1FJB [3] |
HB9AW | 5291.0 kHz | JN47BE | [4] |
SZ1SV | 5398.5 kHz | KM17UX | Op SV1IW & SV1JG. Inactive. |
30 meters beacons
DK0WCY | 10144.0 kHz | JO44VQ | DARC |
IK3NWX | 10137.3 kHz | JN55VF | nr Monselice, PD 15m asl |
10 meters beacons
R1 |
R2[3] |
R3 |
40 MHz beacons
- The first radio propagation beacon on 40 MHz is OZ7IGY in Jystrup, Denmark (JO55WM) and transmits on 40071 kHz
40021 kHz(40.071 MHz). Transmitted power is 20 W to a dipole antenna. The beacon is frequency- and time-locked to GPS. The sequence is programmed to send PI4 , followed by a short pause, and then the call sign and grid locator sent in CW, then a pause, and a carrier until start of the next cycle. PI4 is a digital mode specifically designed for beacons and propagation studies, similar to JT4 and WSPR. To decode PI4, tune 800 Hz below the nominal frequency. - The Radio Society of Great Britain has a license for beacon transmissions from GB3RAL (Didcot, UK) on 40050 & 60050 kHz (40.050 MHz & 60.050 MHz - 8 meters and 5 meters).
- While not a beacon by design, the US Government's SNOTEL telemetry system on 40 MHz operates more than 600 transmitters (mostly in the Rocky Mountain and Western United States regions) on 40670 kHz (40.670 MHz, 40.67 MHz). During sporadic-E band openings, data bursts from the SNOTEL system can be heard on 40.67 MHz.
- The Canadian military base Shuffield (CYSD) in Alberta operates a FM mode military VHF FM radio beacon transmitting continuously with a CW ID / a Morse code ID YSD followed by a tone burst on 36.6 FM (36600 kHz FM, 36.600 MHz FM, 36.60 FM, 36.6 MHz).
6 meters (50 MHz) beacons
In the 6 meters (50 MHz) band, beacons traditionally operate in the lower part of the band, in the range 50000 kHz to 50080 kHz. Due to unpredictable and intermittent long distance propagation, usually achieved by a combination of ionospheric conditions, beacons are very important in providing early warning for 50 MHz openings.
The ARRL bandplan recommends 50060 to 50080 kHz for beacons in the United States.
In Australia beacons operate from 50280 to 50350 kHz.
The new IARU Region 1 bandplan moves 50 MHz beacons, with the exception of beacons participating to the Synchronized Beacon Project, in a new allocation, 50400 to 50500 kHz.
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
IARU R1 | IARU R2 | IARU R3 | |
4 m | 70,000-70,030 |
2 m | 144,400-144,490 |
70 cm | 432,800-432,990 |
23 cm | 1296,800-1296,990 |
ON0EME moon beacon
144 MHz transatlantic beacons
Callsign | Locator | Frequency (kHz) | Info |
CU2VHF | HM77DT | 144401 | |
CU8DUB | HM49KL | 144420 | |
D4C/B | HK76MV | 144436 | 750 m ASL, 20W CW. Copied by Dave Pedersen, PJ4VHF/N7BHC, on Bonaire Island on May 6, 2015 [5] |
ED8ZAA/B | IL18 | 144484 | |
GB3WGI[24] | IO64BL | 144487 | 100 W CW and JT65. Activated on June 4, 2013. |
K4MHZ | FM25 | 144300 | 2M Transatlantic Beacon, Hatteras, NC: CW at 10 WPM. Running 100W to a 12 element long Yagi at 50' on a center azimuth of 70 degrees towards the Azores, Canary Islands, and southern Europe/North Africa. |
N7BHC | FM15PA | 144291 | Mode: CW, 13 WPM. Transmit sequence: N7BHC FM15PA N7BHC FM15PA N7BHC FM15PA (15 second carrier) (15 seconds receive period). Location: 35.0302 N - 76.7146 W |
NP2X/B | FK77PR | 144291 | St. Croix, US Virgin Islands - 240 feet AMSL (73 meters AMSL) - RF Concepts 160 watt, reduced to 100 watts for beacon operation - 15 element yagi @ beam heading of 55 degrees (Portgual) - np2xbeacon@gmail.com |
PY2MTV/B | GG66va | 144300 | Beaming to AF/EU |
VE1SMU/H | 144.288 | ||
VO1ZA | GN37JS | 144400 | Inactive |
W1RJA/B | FN41CJ | 144282 | Southern Rhode Island. Emission: A1 (amplitude keyed CW) Power: 60 Watts Feedline: 160' Cablewave FLC 12-50 half inch hardline. Antenna: 9.5 dBd 5 element yagi beaming 60 degrees azimuth. Height: 140 feet (43M) above base elevation of 130 feet (40M) ASL |
WA1ZMS | FM07FM | 144285 | Activated on October 29, 2006 - 4200FT AMSL - Antenna: 2-yagi pair, Directive Systems DPM144-5 Antenna gain: 11.5dBd Radiated power: 1400W ERPd) |
Indian Ocean beacon project
SHF and microwave beacons
9 cm | 3,400.800-3,400.995 | 3,456.300-3,456.400 | Unknown |
5 cm | 5,760.800-5,760.995 | 5,760.300-5,760.400 | Unknown |
3 cm | 10,368.800-10,368.995 | 10,368.300-10,368.400 | Unknown (25) |
1.2 cm | 24,048.800-24,048.995 | Beacons are rare |
Optical and infrared beacons
Type | Frequencies | Countries | FCC Part 15 rules |
LowFER | 160-190 kHz | USA, Canada | § 15.217 |
MedFER | 510 & 1704 kHz (510-1705 kHz) | USA, Canada | § 15.219 |
BeFER | 6776 kHz | Canada | - |
HiFER | 13553-13567 kHz | USA, Canada | § 15.225 |
49ers | 49846 kHz (49820-49900 kHz) | USA | § 15.235 |
Beacon projects
IARU/NCDXF HF Beacon Project
ITU sponsored beacons
As part of an International Telecommunications Union-funded project, radio propagation beacons were installed by national authorities at Sveio, Norway (callsign LN2A, 59.60420N - 5.291670E) and at Darwin, Australia (callsign VL8IPS, 12.60420S - 131.29200E). The beacons operated on frequencies 5471.5 kHz, 7871.5 kHz, 10408.5 kHz, 14396.5 kHz, and 20948.5 kHz.(6) (15) (27) Since 2002, there have been no reception reports for these beacons and the relevant ITU web pages have been removed. (7) (20)
For a number of years, ITU-R Study Group 3 has been promoting a world-wide HF field-strength measurement campaign, the impetus for which arose from WARC HFBC-87 and the request for improved accuracy in HF propagation prediction. At that time, the Study Group recognised that significant improvements in HF propagation prediction methods needed a substantial body of new measurement data and to that end, administrations and organisations were invited to participate in the measurement campaign, either by installing suitable transmitters or by collecting long-term data from appropriate receiving systems. The campaign is specified in Recommendation ITU-R P.845 'HF field-strength measurement' and comprises a world-wide network of transmitters and receivers using coded transmissions on pre-determined frequencies. The reasons for the campaign and the continuing need for participation in it, are underlined in Resolution ITU-R 27 (HF field-strength measurement campaign). So far, regular transmissions are being provided by the Administrations of Australia and Norway. Details of the transmitter in Norway, operated by the Norwegian Telecommunications Authority and Telenor Broadcasting, are given below: | ||||||||||||
Radio Beacon LN2A
Administrations and organizations participating in the work of ITU-R are invited to consider the possibility of participating in the campaign, either through the provision of transmissions or by the collection of field strength measurement data, both in accordance with the specifications given in Recommendation ITU-R P.845. For further details on the campaign, including the availability of a suitable receiving system, please contact the ITU-R Counsellor for Study Group 3 (Dr. Kevin A. Hughes) at ITU Headquarters, in Geneva. The Norwegian Telecommunications Authority and Telenor Broadcasting would be pleased to acknowledge reception reports of LN2A with a QSL card. The contact address is: Norwegian Telecommunications Authority (Att. AYO/TF) | ||||||||||||
Radio Beacon VL8IPS
DARC beacon project
RSGB 5 MHz beacon project
Beacon GB3RAL, which is located at the Rutherford-Appleton Laboratory (RAL), also transmits continuously on 28215 kHz and on a number of low VHF frequencies (40050, 50053, 60053 and 70053 kHz).[10]
WSPR Network
IARU Region | Beacon frequencies (kHz) |
R1 | 50000, 50001, 50002, 50003, 50004, 50005, 50006, 50007, 50008, 50009 |
R2 | 50010, 50011, 50012, 50013, 50014, 50015, 50016, 50017, 50018, 50019 |
R3 | 50020, 50021, 50022, 50023, 50024, 50025, 50026, 50027, 50028, 50029 |
Frequency (kHz) | TS0 | TS1 | TS2 | TS3 | TS4 |
50005 | EI0SIX | GB3MCB | PI7SIX | GB3MCB | OZ4BHM |
50006 | IW9GDC/B | IW9GDC/B | GB3NGI | IW9GDC/B | GB3NGI |
- Ionosonde
- Radio beacon
- Letter beacon
- High Frequency Beacon
- Part 15 Beacons
- 11 meter band 27 MHz CB radio band beacons
- Pagers and data links as well High power RC systems - de facto 11 meter beacons
Notes and references
- HF 0-20 MHz beacons
- Martin Harrison, G3USF: "Getting started in... beacons, part 2", RadCom, 89(03), Radio Society of Great Britain, pp. 30, March 2013.
- Charlie Newton, G2FKZ: "Radio Auroras", revised edition edited by Steve Telenius-Lowe, 9M6DXX, Radio Society of Great Britain, ISBN 9781-9050-8681-8, pp. 8, 2012.
- 144 MHz Transatlantic Beacon List by Derek Hilleard G4CQM
- "GB3WGI 144 MHz transatlantic beacon", RadCom, 89(08), Radio Society of Great Britain, pp. 11, August 2013.
- Allocations vary by country. In Australia, VK3RMB is on 10368.536 MHz, VK3RGI on 10368.434 MHz and VK3RXX on 10368.530 MHz.
- According to USA/FCC rules, a Beacon is defined as an amateur station transmitting communications for the purposes of observation of propagation and reception or other related experimental activities. (Part 79.3.a.9)
- "HF Propagation Beacons", Shortwave Magazine , 59 (5), ISSN 0037-4261, pp.37, May 2001.
Beacon lists
Currently there is one regularly updated international beacon list, compiled by Dennis, ZS4BS, and is available on-line. An additional online list by WJ5O contains only 28 MHz (10 meter) beacons.
- Dennis Green, ZS4BS: Worldwide List of HF Beacons.
- John G. Troster, W6ISQ, & Robert S. Fabry, N6EK: "The NCDXF/IARU International Beacon Network - Part 1", QST, The American Radio Relay League, October 1994, pp. 31-33.
- John G. Troster, W6ISQ, & Robert S. Fabry, N6EK: "The NCDXF/IARU International Beacon Network - Part 2", QST, The American Radio Relay League, November 1994, pp. 49-51.
- John G. Troster, W6ISQ, & Robert S. Fabry, N6EK: "The NCDXF/IARU International Beacon Network - Report and Update", QST, The American Radio Relay League, September 1997, pp. 47-48.
- Alan Gale, G4TMV: "An introduction to beacon DXing", Version 1.0, December 2012.
- Aurora Beacon DK0WCY
- ON0EME moon beacon status
![]() | This article contains textual material from Wikipedia (TM). Wikipedia texts are licensed under the Creative Commons Attribution-Share Alike license. In short: you are free to distribute and modify the text as long as you attribute its author(s) or licensor(s). If you alter, transform, or build upon this work, you may distribute the resulting work only under the same or similar license to this one. Wikipedia article: Amateur_radio_propagation_beacon | WP |
