MURS
Revision as of 14:48, 7 May 2020 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS is similar in function and intended use to the Freenet license free 149 MHz service available in Germany, the various Nordic JAKTRADIO 155 MHz license free hunting radio services, and the "VHF 245" 245 MHz VHF CB service in Thailand, among other similar CB-like services worldwide.
MURS Frequencies / Channels:
  • Are the "color dot" frequencies license free or part of MURS? Yes and no. Only the Blue Dot and Green Dot channels are license free and part of MURS. The other color dot frequencies, star frequencies, etc. require FCC Part 90 Business Radio licenses to operate on. You must have a license to use 151.625 MHz, 151.955 MHz, 467.925 MHz, 467.850 MHz, 467.7625 MHz, 464.500 MHz and 464.550 MHz, for example.
  • Are MURS channels part of the CB radio service? Legally and technically, yes.
Motorola RDM2070D VHF MURS
Motorola RDM2020 VHF MURS
Motorola RDM2080D VHF MURS
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area - 151.880 MHz 156.7 PL
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power - located in downtown Richmond, VA) - 151.880 MHz 156.7 PL
  • The Mount Jackson, VA MURS simplex repeater - Confirmed active August 2019 - has 50+ mile radius coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of eastern West Virginia and Maryland.
  • The Richmond, VA MURS simplex repeater - Confirmed active May 2020 - has considerably less coverage due to its low power transmitter and location in an urban area. The antenna is located about 20 feet above ground level. Effective radiated power ERP is around 5 watts. However, the repeater covers the downtown Richmond area well and has around 5-10 mile radius coverage.
  • 151.8200 MHz - Militia/Patriot MURS VHF MURS 1
  • 151.8800 MHz - Militia/Patriot MURS VHF MURS 2
  • 154.5700 MHz - Militia/Patriot MURS VHF MURS 4
Alternate VHF militia plans:
  • 151.880 MHz - MURS 2
  • 154.570 MHz - MURS 4
  • 154.600 MHz - MURS 5
  • 151.655 MHz - VHF Business
  • 151.685 MHz - VHF Business
  • 151.715 MHz - VHF Business
  • 151.745 MHz - VHF Business
  • 151.775 MHz - VHF Business
  • 151.805 MHz - VHF Business
  • 151.835 MHz - VHF Business
  • 151.865 MHz - VHF Business
  • 151.895 MHz - VHF Business
  • 151.925 MHz - VHF Business
  • 151.955 MHz - VHF Business
  • 152.870 MHz - VHF Business
  • 152.885 MHz - VHF Business
  • 152.900 MHz - VHF Business
  • 152.915 MHz - VHF Business
  • 152.930 MHz - VHF Business
  • 152.945 MHz - VHF Business
  • 152.960 MHz - VHF Business
  • 152.975 MHz - VHF Business
  • 152.990 MHz - VHF Business
  • 153.005 MHz - VHF Business
  • 154.4825 MHz - VHF Business (narrowband)
  • 154.490 MHz - VHF Business
  • 154.4975 MHz - VHF Business (narrowband)
  • 154.505 MHz - VHF Business (narrowband)
  • 154.515 MHz - VHF Business (narrowband)
  • 154.5275 MHz - VHF Business Itinerant (narrowband)
  • 154.540 MHz - VHF Business
  • 154.5475 MHz - VHF Business
  • 154.555 MHz - VHF Business (narrowband)
  • 154.625 MHz - VHF Business (narrowband)
  • 154.655 MHz - VHF Business (narrowband)
  • 158.4075 MHz - VHF Business Itinerant (narrowband)
