PMR446
| Channel | Freq MHz |
| 1 | 446.00625 |
| 2 | 446.01875 |
| 3 | 446.03125 |
| 4 | 446.04375 |
| 5 | 446.05625 |
| 6 | 446.06875 |
| 7 | 446.08125 |
| 8 | 446.09375 |
| 9 | 446.10625 |
| 10 | 446.11875 |
| 11 | 446.13125 |
| 12 | 446.14375 |
| 13 | 446.15625 |
| 14 | 446.16875 |
| 15 | 446.18125 |
| 16 | 446.19375 |
Digital FDMA
Digital dPMR446 uses 32 digital voice channels separated by 6.25 kHz from each other with 4-level FSK modulation at 3.6 kbit/s. These frequencies overlap the original 16 analog voice/digital voice frequencies and operate in the same 446.0 to 446.2 MHz frequency range of the original PMR446 service. Kenwood designates the 6.25 kHz PMR446 digital band as DPMR446 or Digital DPMR446, not to be confused with digital DMR Tier 1 (which operates on the 12.5 kHz "wideband" channels, same frequencies as the analog channels).
| 1 | 446.003125 |
| 2 | 446.009375 |
| 3 | 446.015625 |
| 4 | 446.021875 |
| 5 | 446.028125 |
| 6 | 446.034375 |
| 7 | 446.040625 |
| 8 | 446.046875 |
| 9 | 446.053125 |
| 10 | 446.059375 |
| 11 | 446.065625 |
| 12 | 446.071875 |
| 13 | 446.078125 |
| 14 | 446.084375 |
| 15 | 446.090625 |
| 16 | 446.096875 |
| 17 | 446.103125 |
| 18 | 446.109375 |
| 19 | 446.115625 |
| 20 | 446.121875 |
| 21 | 446.128125 |
| 22 | 446.134375 |
| 23 | 446.140625 |
| 24 | 446.146875 |
| 25 | 446.153125 |
| 26 | 446.159375 |
| 27 | 446.165625 |
| 28 | 446.171875 |
| 29 | 446.178125 |
| 30 | 446.184375 |
| 31 | 446.190625 |
| 32 | 446.196875 |
Authorized PMR446 Countries
- 446.000000 MHz - begin PMR446 allocation lower band edge 446.0 MHz
- 446.00625 MHz - Analog FM or wideband digital channel 1
- 446.015625
- 446.021875
- 446.028125
- 446.034375
- 446.040625
- 446.046875
- 446.053125
- 446.059375
- 446.065625
- 446.071875
- 446.078125
- 446.084375
- 446.090625
- 446.096875
- 446.103125
- 446.109375
- 446.115625
- 446.121875
- 446.128125
- 446.134375
- 446.140625
- 446.146875
- 446.153125
- 446.159375
- 446.165625
- 446.171875
- 446.178125
- 446.184375
- 446.190625
- 446.196875
