PMR446
| Channel | Freq MHz |
| 1 | 446.00625 |
| 2 | 446.01875 |
| 3 | 446.03125 |
| 4 | 446.04375 |
| 5 | 446.05625 |
| 6 | 446.06875 |
| 7 | 446.08125 |
| 8 | 446.09375 |
| 9 | 446.10625 |
| 10 | 446.11875 |
| 11 | 446.13125 |
| 12 | 446.14375 |
| 13 | 446.15625 |
| 14 | 446.16875 |
| 15 | 446.18125 |
| 16 | 446.19375 |
Digital FDMA
Digital dPMR446 uses 32 digital voice channels separated by 6.25 kHz from each other with 4-level FSK modulation at 3.6 kbit/s. These frequencies overlap the original 16 analog voice/digital voice frequencies and operate in the same 446.0 to 446.2 MHz frequency range of the original PMR446 service. Kenwood designates the 6.25 kHz PMR446 digital band as DPMR446 or Digital DPMR446, not to be confused with digital DMR Tier 1 (which operates on the 12.5 kHz "wideband" channels, same frequencies as the analog channels).
| 1 | 446.003125 |
| 2 | 446.009375 |
| 3 | 446.015625 |
| 4 | 446.021875 |
| 5 | 446.028125 |
| 6 | 446.034375 |
| 7 | 446.040625 |
| 8 | 446.046875 |
| 9 | 446.053125 |
| 10 | 446.059375 |
| 11 | 446.065625 |
| 12 | 446.071875 |
| 13 | 446.078125 |
| 14 | 446.084375 |
| 15 | 446.090625 |
| 16 | 446.096875 |
| 17 | 446.103125 |
| 18 | 446.109375 |
| 19 | 446.115625 |
| 20 | 446.121875 |
| 21 | 446.128125 |
| 22 | 446.134375 |
| 23 | 446.140625 |
| 24 | 446.146875 |
| 25 | 446.153125 |
| 26 | 446.159375 |
| 27 | 446.165625 |
| 28 | 446.171875 |
| 29 | 446.178125 |
| 30 | 446.184375 |
| 31 | 446.190625 |
| 32 | 446.196875 |
Authorized PMR446 Countries
- 446.006250 MHz - Analog FM or wideband digital channel 1
- 446.01875 analog channel 2
- 446.015625
- 446.021875
- 446.028125
- 446.03125 analog channel 3
- 446.034375
- 446.040625
- 446.04375 analog channel 4
- 446.046875
- 446.053125
- 446.05625 analog channel 5
- 446.059375
- 446.065625
- 446.06875 analog channel 6
- 446.071875
- 446.078125
- 446.08125 analog channel 7
- 446.084375
- 446.090625
- 446.09375 analog channel 8
- 446.096875
- 446.103125
- 446.10625 analog channel 9
- 446.109375
- 446.115625
- 446.11875 analog channel 10
- 446.121875
- 446.128125
- 446.13125 analog channel 11
- 446.134375
- 446.140625
- 446.14375 analog channel 12
- 446.146875
- 446.153125
- 446.15625 analog channel 13
- 446.159375
- 446.165625
- 446.16875 analog channel 14
- 446.171875
- 446.178125
- 446.18125 analog channel 15
- 446.184375
- 446.190625
- 446.19375 analog channel 16
- 446.196875
| 7 || 446.08125
| 8 || 446.09375
| 9 || 446.10625
| 10 || 446.11875
| 11 || 446.13125
| 12 || 446.14375
| 13 || 446.15625
| 14 || 446.16875
| 15 || 446.18125
| 16 || 446.19375
