MURS
Revision as of 12:26, 21 August 2020 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS Frequencies / Channels:
Motorola RDM2070D VHF MURS
Motorola RDM2020 VHF MURS
Motorola RDM2080D VHF MURS
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area - 151.880 MHz 156.7 PL
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power - located in downtown Richmond, VA) - 151.880 MHz 156.7 PL
  • The Mount Jackson, VA MURS simplex repeater - Confirmed active May 2020 - has 50+ mile radius coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of West Virginia and western Maryland. Very large footprint.
  • The Richmond, VA MURS simplex repeater - Temporarily off the air as of 27 July 2020 - has considerably less coverage due to its low power transmitter and location in an urban area. Antenna is located on top of a low-rise building, ERP is approx. 4-6 watts. 156.7 Hz tone required to open repeater - repeater equipment switched to FRS channel 7 462.7125 MHz [156.7 Hz CTCSS tone].
The VHF frequencies are recommended for command nets, the UHF frequencies are recommended for tactical/short-range low probability of intercept (LPI) nets.
  • 151.8200 MHz - Militia/Patriot MURS VHF MURS 1 - Tactical and Calling
  • 151.8800 MHz - Militia/Patriot MURS VHF MURS 2 - Sovereign Citizen Freeman Primary Patriot Radio Channel
  • 151.9400 MHz - Militia/Patriot MURS VHF Patriot Nationwide Primary MURS 3 (see also: FRS 3 and CB 3)
  • 154.5700 MHz - Militia/Patriot MURS VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel
  • 462.5625 MHz - Militia/Patriot UHF FRS 1 - Secondary Calling, Tactical, FRS Calling Channel (set transmit CTCSS to 67.0 Hz)
  • 462.6125 MHz - Militia/Patriot UHF FRS 3 - UHF Primary/Calling FRS 3 - AmRRON
FRS channel 1 - 462.5625 MHz CSQ (no tone) is the recommended "calling" frequency, along it is often the busiest calling - National SOS Radio Network FRS channel 1 - 462.5625 MHz CSQ (no tone) (1-0) Patriot Radio - Neighborhood Watch Channel FRS channel 2 - 462.5875 MHz CSQ (no tone) (2-0) is the prepper/militia secondary channel (tactical) FRS channel 2 - 462.5875 MHz CSQ (no tone) (2-0) Patriot Radio - Sovereign Citizens Freeman Channel FRS channel 2 - 462.5875 MHz CSQ (no tone) (2-0) Militia and security forces common inter-group inter squad radio channel (primary) FRS channel 3 - 462.6125 MHz CSQ (no tone) (3-0) is the recommend prepper/militia channel with MURS 3 and CB 3 as part of the AmRRON CH3 Project FRS channel 3 - 462.6125 MHz CSQ (no tone) (3-0) Patriot Radio - Patriot Preppers Primary (see above) FRS channel 3 - 462.6125 MHz various Black Lives Matter Protest Coordination Walkie Talkies (various tones/codes) FRS channel 4 - 462.6375 MHz CSQ (no tone) (4-0) is the prepper/militia secondary channel FRS channel 4 - 462.6375 MHz CSQ (no tone) (4-0) Militia and security forces common interagency inter-group tactical coordination channel (secondary) FRS channel 4 - 462.6375 MHz CSQ (no tone) (4-0) Jeep 4x4 Clubs FRS channel 4 - 462.6375 MHz subcode 4 (4-4) Jeep 4x4 Clubs PL 77.0 Hz, see also: CB channels 4 and 16 FRS channel 4 - 462.6375 MHz subcode 16 (4-16) Jeep 4x4 Clubs PL 114.8 Hz FRS channel 7 - 462.7125 MHz subcode 15 (7-15) Airshow/milcom hobbyist recommended channel (backup) PL 110.9 Hz FRS channel 8 - 467.5625 MHz various Black Lives Matter Protest Coordination Walkie Talkies (various tones/codes) FRS channel 8 - 467.5625 MHz subcode 8 (8-8) backup militia operations channel PL 88.5 Hz FRS channel 8 - 467.5625 MHz subcode 14 (8-14) back up militia operations channel PL 107.2 Hz FRS channel 9 - 467.5875 MHz stupid FRS channel 11 - 467.6375 MHz stupid FRS channel 12 - 467.6625 MHz - super tacticool channel more tactical than you could ever be FRS channel 13 - 467.6875 MHz stupid FRS channel 14 - 467.7125 MHz subcode 8 (14-8) back up militia operations channel 88.5 Hz FRS channel 14 - 467.7125 MHz subcode 38 (14-38) Airshow/milcom hobbyist recommended channel (primary) PL 250.3 Hz FRS channel 16 - 462.5750 MHz CSQ (no tone) (16-0) Jeep 4x4 Clubs, see also, FRS channel 4, MURS channel 4, CB channel 4 FRS channel 17 - 462.6000 MHz CSQ (no tone) (17-0) Patriot Radio Patriot Militia Tactical FRS channel 19 - 462.6500 MHz CSQ (no tone) (19-0) Militia and security forces common inter-group inter squad radio channel (secondary) FRS channel 20 - 462.6750 MHz subcode 22 (20-22) is the recommended GMRS calling/travel channel, with CTCSS or PL tone 141.3 Hz FRS channel 21 - 462.7000 MHz CSQ (no tone) (21-0) Militia and security forces common inter-group inter squad radio channel (secondary)
Alternate VHF militia plans:
  • 151.8200 MHz - MURS1 - CALLING / TACTICAL MURS Ch 1
  • 151.8800 MHz - MURS2 - SOVEREIGN CITIZEN FREEMEN MURS Ch 2
  • 151.9400 MHz - MURS3 - PATRIOT NATIONWIDE PRIMARY MURS Ch 3
  • 154.5700 MHz - MURS4 - PATRIOT REGIONAL SECONDARY MURS Ch 4
  • 154.6000 MHz - MURS5 - MURS Ch 5
  • 146.4850 MHz - HAMV48 - 2 meter amateur radio ham channel 146.485 MHz Patriot/Militia
  • 462.5625 MHz - FRS 1 - Militia/Patriot UHF FRS Channel 1
  • 462.5875 MHz - FRS 2 - Militia/Patriot UHF FRS Channel 2
  • 462.6125 MHz - FRS 3 - Militia/Patriot UHF FRS Channel 3
  • 462.6375 MHz - FRS 4 - Militia/Patriot UHF FRS Channel 4
  • 462.6625 MHz - FRS 5 - Militia/Patriot UHF FRS Channel 5
  • 462.6875 MHz - FRS 6 - Militia/Patriot UHF FRS Channel 6
  • 462.7125 MHz - FRS 7 - Militia/Patriot UHF FRS Channel 7
  • 467.5625 MHz - FRS 8 - Militia/Patriot UHF FRS Channel 8
  • 467.5875 MHz - FRS 9 - Militia/Patriot UHF FRS Channel 9
  • 467.6125 MHz - FRS 10 - Militia/Patriot UHF FRS Channel 10
  • 467.6375 MHz - FRS 11 - Militia/Patriot UHF FRS Channel 11
  • 467.6625 MHz - FRS 12 - Militia/Patriot UHF FRS Channel 12
  • 467.6875 MHz - FRS 13 - Militia/Patriot UHF FRS Channel 13
  • 467.7125 MHz - FRS 14 - Militia/Patriot UHF FRS Channel 14
  • 462.5500 MHz - FRS 15 - Militia/Patriot UHF FRS Channel 15
  • 462.5750 MHz - FRS 16 - Militia/Patriot UHF FRS Channel 16
  • 462.6000 MHz - FRS 17 - Militia/Patriot UHF FRS Channel 17
  • 462.6250 MHz - FRS 18 - Militia/Patriot UHF FRS Channel 18
  • 462.6500 MHz - FRS 19 - Militia/Patriot UHF FRS Channel 19
  • 462.6750 MHz - FRS 20 - Militia/Patriot UHF FRS Channel 20
  • 462.7000 MHz - FRS 21 - Militia/Patriot UHF FRS Channel 21
  • 462.7250 MHz - FRS 22 - Militia/Patriot UHF FRS Channel 22
  • 151.880 MHz - MURS 2
  • 154.570 MHz - MURS 4
  • 154.600 MHz - MURS 5
  • 151.655 MHz - VHF Business
  • 151.685 MHz - VHF Business
  • 151.715 MHz - VHF Business
  • 151.745 MHz - VHF Business
  • 151.775 MHz - VHF Business
  • 151.805 MHz - VHF Business
  • 151.835 MHz - VHF Business
  • 151.865 MHz - VHF Business
  • 151.895 MHz - VHF Business
  • 151.925 MHz - VHF Business
  • 151.955 MHz - VHF Business
  • 152.870 MHz - VHF Business
  • 152.885 MHz - VHF Business
  • 152.900 MHz - VHF Business
  • 152.915 MHz - VHF Business
  • 152.930 MHz - VHF Business
  • 152.945 MHz - VHF Business
  • 152.960 MHz - VHF Business
  • 152.975 MHz - VHF Business
  • 152.990 MHz - VHF Business
  • 153.005 MHz - VHF Business
  • 154.4825 MHz - VHF Business
  • 154.490 MHz - VHF Business
  • 154.4975 MHz - VHF Business
  • 154.505 MHz - VHF Business
  • 154.515 MHz - VHF Business
  • 154.540 MHz - VHF Business
  • 154.5475 MHz - VHF Business
  • 154.555 MHz - VHF Business
  • 154.625 MHz - VHF Business
  • 154.655 MHz - VHF Business
