MURS
Revision as of 12:33, 21 August 2020 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS Frequencies / Channels:
Motorola RDM2070D VHF MURS
Motorola RDM2020 VHF MURS
Motorola RDM2080D VHF MURS
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area - 151.880 MHz 156.7 PL
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power - located in downtown Richmond, VA) - 151.880 MHz 156.7 PL
  • The Mount Jackson, VA MURS simplex repeater - Confirmed active May 2020 - has 50+ mile radius coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of West Virginia and western Maryland. Very large footprint.
  • The Richmond, VA MURS simplex repeater - Temporarily off the air as of 27 July 2020 - has considerably less coverage due to its low power transmitter and location in an urban area. Antenna is located on top of a low-rise building, ERP is approx. 4-6 watts. 156.7 Hz tone required to open repeater - repeater equipment switched to FRS channel 7 462.7125 MHz [156.7 Hz CTCSS tone].
  • 151.8200 MHz - Militia/Patriot MURS VHF MURS 1 - Tactical and Calling
  • 151.8800 MHz - Militia/Patriot MURS VHF MURS 2 - Sovereign Citizen Freeman Primary Patriot Radio Channel
  • 151.9400 MHz - Militia/Patriot MURS VHF Patriot Nationwide Primary MURS 3 (see also: FRS 3 and CB 3)
  • 154.5700 MHz - Militia/Patriot MURS VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel
  • 462.6125 MHz - Militia/Patriot UHF FRS 3 - UHF Primary/Calling FRS 3 - AmRRON
  • 146.4850 MHz - HAMV48 - 2 meter amateur radio ham channel 146.485 MHz Patriot/Militia - note the common 146.490 MHz simplex frequency interferes with this and vise-versa
  • 462.5625 MHz - FRS 1 - Militia/Patriot UHF FRS Channel 1 - FRS Calling Channel - general calling use (set transmit CTCSS to 67.0 Hz)
  • 462.5875 MHz - FRS 2 - Militia/Patriot UHF FRS Channel 2 - Sovereign Citizen Freeman Primary Patriot Radio Channel
  • 462.6125 MHz - FRS 3 - Militia/Patriot UHF FRS Channel 3 - UHF Primary/Calling FRS 3 - AmRRON
  • 462.6375 MHz - FRS 4 - Militia/Patriot UHF FRS Channel 4 - Patriot Regional Channel/Secondary Tactical, Vehicle Coordination
  • 462.6625 MHz - FRS 5 - Militia/Patriot UHF FRS Channel 5
  • 462.6875 MHz - FRS 6 - Militia/Patriot UHF FRS Channel 6
  • 462.7125 MHz - FRS 7 - Militia/Patriot UHF FRS Channel 7
  • 467.5625 MHz - FRS 8 - Militia/Patriot UHF FRS Channel 8 - Tactical
  • 467.5875 MHz - FRS 9 - Militia/Patriot UHF FRS Channel 9
  • 467.6125 MHz - FRS 10 - Militia/Patriot UHF FRS Channel 10
  • 467.6375 MHz - FRS 11 - Militia/Patriot UHF FRS Channel 11
  • 467.6625 MHz - FRS 12 - Militia/Patriot UHF FRS Channel 12
  • 467.6875 MHz - FRS 13 - Militia/Patriot UHF FRS Channel 13
  • 467.7125 MHz - FRS 14 - Militia/Patriot UHF FRS Channel 14
  • 462.5500 MHz - FRS 15 - Militia/Patriot UHF FRS Channel 15 - Tactical
  • 462.5750 MHz - FRS 16 - Militia/Patriot UHF FRS Channel 16 - Patriot Tactical, Vehicle Coordination
  • 462.6000 MHz - FRS 17 - Militia/Patriot UHF FRS Channel 17 - Tactical
  • 462.6250 MHz - FRS 18 - Militia/Patriot UHF FRS Channel 18
  • 462.6500 MHz - FRS 19 - Militia/Patriot UHF FRS Channel 19 - Tactical, Inter Squad Radio coordination/inter-group cooperation
  • 462.6750 MHz - FRS 20 - Militia/Patriot UHF FRS Channel 20 - GMRS Calling Channel - general calling use (set transmit CTCSS to 141.3 Hz
  • 462.7000 MHz - FRS 21 - Militia/Patriot UHF FRS Channel 21 - Tactical, Inter Squad Radio coordination/inter-group cooperation
  • 462.7250 MHz - FRS 22 - Militia/Patriot UHF FRS Channel 22
  • 151.880 MHz - MURS 2
  • 154.570 MHz - MURS 4
  • 154.600 MHz - MURS 5
  • 151.655 MHz - VHF Business
  • 151.685 MHz - VHF Business
  • 151.715 MHz - VHF Business
  • 151.745 MHz - VHF Business
  • 151.775 MHz - VHF Business
  • 151.805 MHz - VHF Business
  • 151.835 MHz - VHF Business
  • 151.865 MHz - VHF Business
  • 151.895 MHz - VHF Business
  • 151.925 MHz - VHF Business
  • 151.955 MHz - VHF Business
  • 152.870 MHz - VHF Business
  • 152.885 MHz - VHF Business
  • 152.900 MHz - VHF Business
  • 152.915 MHz - VHF Business
  • 152.930 MHz - VHF Business
  • 152.945 MHz - VHF Business
  • 152.960 MHz - VHF Business
  • 152.975 MHz - VHF Business
  • 152.990 MHz - VHF Business
  • 153.005 MHz - VHF Business
  • 154.4825 MHz - VHF Business
  • 154.490 MHz - VHF Business
  • 154.4975 MHz - VHF Business
  • 154.505 MHz - VHF Business
  • 154.515 MHz - VHF Business
  • 154.540 MHz - VHF Business
  • 154.5475 MHz - VHF Business
  • 154.555 MHz - VHF Business
  • 154.625 MHz - VHF Business
  • 154.655 MHz - VHF Business
