Militia Radio Frequencies
Revision as of 12:38, 24 August 2020 by R4002 (Talk | contribs)
Militia portable handheld tactical radios - VHF/UHF FM dualbanders such as the Baofeng series UV-5R, UV-82, VHF/UHF mobile radios, single-band mobile radios, etc.
Transmit CTCSS tones are recommended, but not required. Receive must be set for carrier squelch (no receive CTCSS or PL tone). Users may simply turn all tones off (no transmit tone or receive tone) if they prefer. Transmit tones are recommended to facilitate interoperability with commonly used tones and default radio channel/tone settings. For example, the Baofeng BF-888S [[series radios use 127.3 Hz CTCSS on 462.625 MHz (BF-888S channel 6, FRS channel 18) and 136.5 Hz CTCSS on 462.725 MHz (BF-888S channel 7, FRS channel 22). The Retevis FRS handheld radios use the CTCSS tones indicated for FRS channels 1-7, 15, 18 and 22. For more information on default factory out of the box Baofeng Retevis etc. CTCSS tone settings and frequencies/channel plans, see this page.
  • Channel 001 - MURS 1 - 151.8200 MHz - Mode: NFM - Tone: 88.5Hz - display channel name: MURS 1
  • Channel 002 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 88.5Hz - display channel name: MURS 2
  • Channel 003 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 88.5Hz - display channel name: MURS 3
  • Channel 004 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 88.5Hz - display channel name: MURS 4
  • Channel 005 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 88.5Hz - display channel name: MURS 5
  • Channel 011 - FRS 1 - 462.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 1
  • Channel 012 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 2
  • Channel 013 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 3
  • Channel 014 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 77.0 Hz - display channel name: FRS 4
  • Channel 015 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 136.5 Hz - display channel name: FRS 5
  • Channel 016 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 6
  • Channel 017 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 146.2 Hz - display channel name: FRS 7
  • Channel 018 - FRS 8 - 467.5625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 8
  • Channel 019 - FRS 9 - 467.5875 MHz - Mode: NFM - Tone: 97.4 Hz - display channel name: FRS 9
  • Channel 010 - FRS 10 - 467.6125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 10
  • Channel 011 - FRS 11 - 467.6375 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 11
  • Channel 012 - FRS 12 - 467.6625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 12
  • Channel 013 - FRS 13 - 467.6875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 13
  • Channel 014 - FRS 14 - 467.7125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 14
  • Channel 015 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 15
The VHF frequencies are recommended for command nets, the UHF frequencies are recommended for tactical/short-range low probability of intercept (LPI) nets. UHF (FRS) frequencies are ideal for urban operations. Any of the 22 FRS channels may be used for tactical voice radio operations - with deference given to the calling and standby channels - FRS 1, FRS 3, FRS 19 and FRS 20.
  • 467.5625 MHz - Militia/Patriot UHF FRS 8
Tactical Radio Voice Intercept and Low Level Voice Intercept (LLVI)
Intra-Squad Radio - very short range tactical radio radio
Possible options for intra-squad radio (not to be confused with inter-squad radio - communications between different squads...intra-squad radio refers to communications within a single squad and therefore extremely short range radios are required).
  • 900 MHz band 902-928 MHz radios such as the frequency hopping spread spectrum (FHSS) Motorola DTR series.
  • 49 MHz band Part 15 handhelds or VOX headset radios such as the RadioShack and Maxon series - 5-channel 49 MHz FM radios with roughly 500 foot range. These offer excellent performance for intra-squad tactical comms and their extremely low power means only voice intercept receivers (scanners) within 1/2 mile or less can hear them.
