Militia Radio Frequencies
Transmit CTCSS tones are recommended, but not required. Receive must be set for carrier squelch (no receive CTCSS or PL tone). Users may simply turn all tones off (no transmit tone or receive tone) if they prefer. Transmit tones are recommended to facilitate interoperability with commonly used tones and default radio channel/tone settings. For example, the Baofeng BF-888S series radios use 127.3 Hz CTCSS on 462.625 MHz (BF-888S channel 6, FRS channel 18) and 136.5 Hz CTCSS on 462.725 MHz (BF-888S channel 7, FRS channel 22). The Retevis FRS handheld radios use the CTCSS tones indicated for FRS channels 1-7, 15, 18 and 22. For more information on default factory out of the box Baofeng Retevis etc. CTCSS tone settings and frequencies/channel plans, see this page.
Handheld Radio VHF UHF FRS GMRS MURS Militia Channels
- Channel 001 - FRS 1 - 462.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 1
 - Channel 002 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 2
 - Channel 003 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 3
 - Channel 004 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 4
 - Channel 005 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 5
 - Channel 006 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 6
 - Channel 007 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 7
 - Channel 008 - FRS 8 - 467.5625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 8
 - Channel 009 - FRS 9 - 467.5875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 9
 - Channel 010 - FRS 10 - 467.6125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 10
 - Channel 011 - FRS 11 - 467.6375 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 11
 - Channel 012 - FRS 12 - 467.6625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 12
 - Channel 013 - FRS 13 - 467.6875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 13
 - Channel 014 - FRS 14 - 467.7125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 14
 - Channel 015 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 15
 - Channel 016 - FRS 16 - 462.5750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 16
 - Channel 017 - FRS 17 - 462.6000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 17
 - Channel 018 - FRS 18 - 462.6250 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 18
 - Channel 019 - FRS 19 - 462.6500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 19
 - Channel 020 - FRS 20 - 462.6750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 20
 - Channel 021 - FRS 21 - 462.7000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 21
 - Channel 022 - FRS 22 - 462.7250 MHz - Mode: NFM - Tone: 136.5 Hz - display channel name: FRS 22
 - Channel 031 - MURS 1 - 151.8200 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 1
 - Channel 032 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 2
 - Channel 033 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 3
 - Channel 034 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 4
 - Channel 035 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 5
 - Channel 041 - FRS 1 - 462.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 1 CALL - high power setting
 - Channel 042 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 2 CALL - high power setting
 - Channel 043 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 3 CALL - high power setting
 - Channel 044 - FRS 20 - 462.6750 MHz - Mode: NFM - Tone 141.3 Hz - display channel name: FRS 20 CALL - high power setting
 - Channel 045 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 3 CALL - high power setting
 - Channel 046 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 4 TAC - low power setting
 - Channel 047 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 5 TAC - low power setting
 - Channel 048 - FRS 8 - 467.5625 MHz - Mode: NFM_ - Tone: 88.5 Hz - display channel name: FRS 8 TAC - low power setting
 - Channel 048 - FRS 9 - 467.5875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 9 TAC - low power setting
 - Channel 050 - FRS 10 - 467.6125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 10 TAC - low power setting
 - Channel 051 - FRS 11 - 467.6375 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 11 TAC - low power setting
 - Channel 052 - FRS 12 - 467.6625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 12 TAC - low power setting
 - Channel 053 - FRS 13 - 467.6875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 13 TAC - low power setting
 - Channel 054 - FRS 14 - 467.7125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 14 TAC - low power setting
 - Channel 101 - FRS 1 - 462.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 1 HP - high power setting
 - Channel 102 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 2 HP - high power setting
 - Channel 103 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 3 HP - high power setting
 - Channel 104 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 4 HP - high power setting
 - Channel 105 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 5 HP - high power setting
 - Channel 106 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 6 HP - high power setting
 - Channel 107 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 7 HP - high power setting
 - Channel 108 - FRS 8 - 467.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 8 HP - high power setting
 - Channel 109 - FRS 9 - 467.5875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 9 HP - high power setting
 - Channel 110 - FRS 10 - 467.6125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 10 HP - high power setting
 - Channel 111 - FRS 11 - 467.6375 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 11 HP - high power setting
 - Channel 112 - FRS 12 - 467.6625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 12 HP - high power setting
 - Channel 113 - FRS 13 - 467.6875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 13 HP - high power setting
 - Channel 114 - FRS 14 - 467.7125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 14 HP - high power setting
 - Channel 115 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 15 HP - high power setting
 - Channel 116 - FRS 16 - 462.5750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 16 HP - high power setting
 - Channel 117 - FRS 17 - 462.6000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 17 HP - high power setting
 - Channel 118 - FRS 18 - 462.6250 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 18 HP - high power setting
 - Channel 119 - FRS 19 - 462.6500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 19 HP - high power setting
 - Channel 120 - FRS 20 - 462.6750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 20 HP - high power setting
 - Channel 121 - FRS 21 - 462.7000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 21 HP - high power setting
 - Channel 122 - FRS 22 - 462.7250 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 22 HP - high power setting
 - Channel 123 - MURS 1 - 151.8200 MHz - Mode: NFM - Tone: 77.0 Hz - display channel name: MURS 1 HP - high power setting
 - Channel 124 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 77.0 Hz - display channel name: MURS 2 HP - high power setting
 - Channel 125 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 77.0 Hz - display channel name: MURS 3 HP - high power setting
 - Channel 126 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 77.0 Hz - display channel name: MURS 4 HP - high power setting
 - Channel 127 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 77.0 Hz - display channel name: MURS 5 HP - high power setting
Alternate Militia Radio Programming Plan Militia Patriot Radio Frequencies Channels
May be hand programmed - field programming militia tactical radio frequencies. R-CTCS: OFF, T-CTCS: [see transmit tones listed below...remember to leave the receive in CSQ carrier squelch mode. R-DCS and T-DCS should both be set to OFF. TXP: HIGH - high power. ROGER: OFF. VOICE: OFF. WN: NARR (narrow). Recommend transmit CTCSS (T-CTCS) tone 67.0 Hz for FRS channel 1 (462.5625 MHz) and 141.3 Hz for FRS channel 20 (462.6750 MHz).
- Channel 1 - 462.5625 MHz - FRS Channel 1 - FRS Nationwide Calling - transmit 67.0 Hz
 - Channel 2 - 462.5875 MHz - FRS Channel 2 - Patriot Militia Tactical - Neighborhood Watch Channel - transmit 88.5 Hz
The VHF frequencies are recommended for command nets, the UHF frequencies are recommended for tactical/short-range low probability of intercept (LPI) nets.  UHF (FRS) frequencies are ideal for urban operations.  Any of the 22 FRS channels may be used for tactical voice radio operations - with deference given to the calling and standby channels - FRS 1, FRS 2 FRS 3, and FRS 20.
 - 151.9400 MHz - Militia/Patriot VHF MURS 3 - Primary Calling, Command Nets, AmRRON Patriot Nationwide Primary MURS 3 (also FRS 3, CB 3 and 146.42 MHz)
 - 154.5700 MHz - Militia/Patriot VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel, Vehicle Coordination
 - 154.6000 MHz - Militia/Patriot VHF MURS 5 - Tactical or Command Nets
 - 467.5625 MHz - Militia/Patriot UHF FRS 8 - Tactical, Inter Squad Radio coordination/inter-group cooperation
 - 467.5875 MHz - Militia/Patriot UHF FRS 9 - Tactical, Inter Squad Radio coordination/inter-group cooperation
 - 467.6125 MHz - Militia/Patriot UHF FRS 10 - Tactical, Inter Squad Radio coordination/inter-group cooperation
 - 467.6375 MHz - Militia/Patriot UHF FRS 11 - Tactical, Inter Squad Radio coordination/inter-group cooperation
 - 467.6625 MHz - Militia/Patriot UHF FRS 12 - Tactical, Inter Squad Radio coordination/inter-group cooperation
 - 467.6875 MHz - Militia/Patriot UHF FRS 13 - Tactical, Inter Squad Radio coordination/inter-group cooperation
 - 467.7125 MHz - Militia/Patriot UHF FRS 14 - Tactical, Inter Squad Radio coordination/inter-group cooperation
 - 462.5500 MHz - Militia/Patriot UHF FRS 15
 - 462.5750 MHz - Militia/Patriot UHF FRS 16 - Patriot Tactical, Vehicle Coordination (see also: FRS ch. 4)
 - 462.6000 MHz - Militia/Patriot UHF FRS 17
 - 467.5875 MHz - FRS9 - Militia/Patriot UHF FRS Channel 9 - Tactical
 - 467.6125 MHz - FRS10 - Militia/Patriot UHF FRS Channel 10 - Tactical
 - 467.6375 MHz - FRS11 - Militia/Patriot UHF FRS Channel 11 - Tactical
 - 467.6625 MHz - FRS12 - Militia/Patriot UHF FRS Channel 12 - Tactical
 - 467.6875 MHz - FRS13 - Militia/Patriot UHF FRS Channel 13 - Tactical
 - 467.7125 MHz - FRS14 - Militia/Patriot UHF FRS Channel 14 - Tactical
- Radio A - 5 feet above ground communicating with Radio B - 5 feet above ground = 5 miles line of sight range
 - Radio A - 20 feet above ground communicating with Radio B - 5 feet above ground = 9 miles line of sight range
 - Radio A - 30 feet above ground communicating with Radio B - 5 feet above ground = 11 miles line of sight range
 - Radio A - 50 feet above ground communicating with Radio B - 5 feet above ground = 13 miles line of sight range
 - Radio A - 100 feet above ground communicating with Radio B - 5 feet above ground = 17 miles line of sight range
 - Radio A - 20 feet above ground communicating with Radio B - 10 feet above ground = 10 miles line of sight range
 - Radio A - 20 feet above ground communicating with Radio B - 20 feet above ground = 12 miles line of sight range
 - Radio A - 30 feet above ground communicating with Radio B - 10 feet above ground = 12 miles line of sight range
 - Radio A - 30 feet above ground communicating with Radio B - 20 feet above ground = 14 miles line of sight range
 - Radio A - 30 feet above ground communicating with Radio B - 30 feet above ground = 16 miles line of sight range
 - Radio A - 50 feet above ground communicating with Radio B - 10 feet above ground = 14 miles line of sight range
 - Radio A - 50 feet above ground communicating with Radio B - 20 feet above ground = 16 miles line of sight range
 - Radio A - 50 feet above ground communicating with Radio B - 30 feet above ground = 18 miles line of sight range
 - Radio A - 50 feet above ground communicating with Radio B - 40 feet above ground = 19 miles line of sight range
 - Radio A - 50 feet above ground communicating with Radio B - 50 feet above ground = 20 miles line of sight range
 - Radio A - 100 feet above ground communicating with Radio B - 10 feet above ground = 18 miles line of sight range
 - Radio A - 100 feet above ground communicating with Radio B - 20 feet above ground = 20 miles line of sight range
 - Radio A - 100 feet above ground communicating with Radio B - 30 feet above ground = 22 miles line of sight range
 - Radio A - 100 feet above ground communicating with Radio B - 40 feet above ground = 23 miles line of sight range
 - Radio A - 100 feet above ground communicating with Radio B - 50 feet above ground = 24 miles line of sight range
 - Radio A - 100 feet above ground communicating with Radio B - 60 feet above ground = 25 miles line of sight range
 - Radio A - 100 feet above ground communicating with Radio B - 75 feet above ground = 26 miles line of sight range
 - Radio A - 100 feet above ground communicating with Radio B - 100 feet above ground = 28 miles line of sight range
 - Radio A - 200 feet above ground communicating with Radio B - 5 feet above ground = 23 miles line of sight range
 - Radio A - 200 feet above ground communicating with Radio B - 10 feet above ground = 24 miles line of sight range
 - Radio A - 200 feet above ground communicating with Radio B - 25 feet above ground = 27 miles line of sight range
 - Radio A - 200 feet above ground communicating with Radio B - 50 feet above ground = 30 miles line of sight range
 - Radio A - 200 feet above ground communicating with Radio B - 75 feet above ground = 32 miles line of sight range
 - Radio A - 200 feet above ground communicating with Radio B - 100 feet above ground = 34 miles line of sight range
 - Radio A - 200 feet above ground communicating with Radio B - 125 feet above ground = 36 miles line of sight range
 - Radio A - 200 feet above ground communicating with Radio B - 150 feet above ground = 37 miles line of sight range
 - Radio A - 200 feet above ground communicating with Radio B - 175 feet above ground = 39 miles line of sight range
 - Radio A - 200 feet above ground communicating with Radio B - 200 feet above ground = 40 miles line of sight range
 - Radio A - 500 feet above ground communicating with Radio B - 5 feet above ground = 35 miles line of sight range
 - Radio A - 500 feet above ground communicating with Radio B - 10 feet above ground = 36 miles line of sight range
 - Radio A - 500 feet above ground communicating with Radio B - 25 feet above ground = 39 miles line of sight range
 - Radio A - 500 feet above ground communicating with Radio B - 50 feet above ground = 42 miles line of sight range
 - Radio A - 500 feet above ground communicating with Radio B - 75 feet above ground = 44 miles line of sight range
 - Radio A - 500 feet above ground communicating with Radio B - 100 feet above ground = 46 miles line of sight range
 - Radio A - 500 feet above ground communicating with Radio B - 150 feet above ground = 49 miles line of sight range
 - Radio A - 500 feet above ground communicating with Radio B - 200 feet above ground = 52 miles line of sight range
 - Radio A - 500 feet above ground communicating with Radio B - 250 feet above ground = 54 miles line of sight range
 - Radio A - 500 feet above ground communicating with Radio B - 500 feet above ground = 64 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 5 feet above ground = 48 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 10 feet above ground = 49 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 25 feet above ground = 52 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 50 feet above ground = 55 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 100 feet above ground = 59 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 150 feet above ground = 62 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 200 feet above ground = 65 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 250 feet above ground = 67 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 500 feet above ground = 77 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 750 feet above ground = 84 miles line of sight range
 - Radio A - 1000 feet above ground communicating with Radio B - 1000 feet above ground = 90 miles line of sight range
See also:  Common VHF Itinerant Frequencies, AM and SSB CB frequencies,  Hunt Club Frequencies and the American Redoubt Radio Operators Network (AmRRON) and The American Preparedness Radio Network (TAPRN) pages.  Specific AM and SSB 11 meter CB frequencies are included - 26.985 MHz AM, 27.005 MHz AM, 27.365 MHz USB, 27.368 MHz USB, 27.375 MHz USB, 27.378 MHz USB and 27.425 MHz.
