Militia Radio Frequencies
Revision as of 23:35, 5 February 2021 by R4002 (Talk | contribs)
  • Channel 9 - 467.5875 MHz - FRS 9 - Mutual Aid, Tac
  • Channel 13 - 467.6875 MHz - FRS 13 - Mutual Aid, Tac
  • Channel 32 - 151.8800 MHz - MURS 2 - Command
  • Channel 33 - 151.9400 MHz - MURS 3 - Primary Patriot Militia Calling
  • Channel 34 - 154.5700 MHz - MURS 4 - Command
  • Channel 35 - 154.6000 MHz - MURS 5 - Command
T-CTCS (transmit tone) recommendations below. ALWAYS LEAVE RECEIVER SQUELCH OPEN (CSQ). On CHIRP it's Tone, not TSQL. When programming a radio manually, R-CTCS should be set to OFF. T-DCS set to OFF and R-DCS set to OFF.
  • FRS 1 - 67.0 Hz
  • FRS 2 - 71.9 Hz or 118.8 Hz
  • FRS 3 - 74.4 Hz, 88.5 Hz or 127.3 Hz.
  • FRS 4 - 131.8 Hz
  • FRS 5 - 136.5 Hz, 79.7 Hz, or 88.5 Hz
  • FRS 6 - 141.3 Hz
  • FRS 7 - 146.2 Hz
  • FRS 8 - 88.5 Hz
  • FRS 9 - 88.5 Hz, 97.4 Hz, or 127.3 Hz
  • FRS 10 - 77.0 Hz or 88.5 Hz
  • FRS 11 - 88.5 Hz
  • FRS 12 - 88.5 Hz
  • FRS 13 - 88.5 Hz
  • FRS 14 - 88.5 Hz or 107.2 Hz
  • FRS 15 - 71.9 Hz, 110.9 Hz, 123.0 Hz or 141.3 Hz
  • FRS 16 - 141.3 Hz
  • FRS 17 - 141.3 Hz
  • FRS 18 - 127.3 Hz
  • FRS 19 - 127.3 Hz or 141.3 Hz
  • FRS 20 - 141.3 Hz strongly recommended
  • FRS 21 - 141.3 Hz
  • FRS 22 - 136.5 Hz
  • MURS 1 - 88.5 Hz
  • MURS 2 - 88.5 Hz
  • MURS 3 - 88.5 Hz
  • MURS 4 - 88.5 Hz
  • MURS 5 - 88.5 Hz
