VHF low band VHF-low
VHF high band VHF band
UHF band
*UHF MED Channels - UHF EMS Channels *Original Channel Plan (25 kHz channels, 12.5 kHz bandwidth)
700 MHz band
800 MHz band
- 853.0125 MHz - 8TAC94D/8TAC94 - Tac 4, simplex or repeater (input: 808.5125 MHz) both with 156.7 Hz CTCSS
- 853.4875 MHz - old 800 MHz itinerant channel, may be used for simplex, tactical or talkaround purposes.
UHF band
- Law Enforcement Plan
- LE A Calling - 167.0875 MHz
- LE B Calling - 414.0375 MHz
- LE 01 Tactical - 162.0875 MHz
- LE 02 Tactical - 162.2625 MHz
- LE 03 Tactical - 162.8375 MHz
- LE 04 Tactical - 163.2875 MHz
- LE 05 Tactical - 163.4250 MHz
- LE 06 Tactical - 167.2500 MHz
- LE 07 Tactical - 167.7500 MHz
- LE 08 Tactical - 168.1125 MHz
- LE 09 Tactical - 168.4625 MHz
- LE 10 Tactical - 418.9875 MHz
- LE 11 Tactical - 419.1875 MHz
- LE 12 Tactical - 419.6125 MHz
- LE 13 Tactical - 414.0625 MHz
- LE 14 Tactical - 414.3125 MHz
- LE 15 Tactical - 414.3375 MHz
- LE 16 Tactical - 409.9875 MHz
- LE 17 Tactical - 410.1875 MHz
- LE 18 Tactical - 410.6125 MHz
- Incident Response Plan
- NC 1 Calling - 164.7125 MHz
- NC 2 Calling - 419.2375 MHz
- IR 01 - 165.2500 MHz
- IR 02 - 165.9625 MHz
- IR 03 - 166.5750 MHz
- IR 04 - 167.3250 MHz
- IR 05 - 169.5375 MHz
- IR 06 - 170.0125 MHz
- IR 07 - 170.4125 MHz
- IR 08 - 170.6875 MHz
- IR 09 - 173.0375 MHz
- IR 10 - 419.4375 MHz
- IR 11 - 419.6375 MHz
- IR 12 - 419.8375 MHz
- IR 13 - 413.1875 MHz
- IR 14 - 413.2125 MHz
- IR 15 - 410.2375 MHz
- IR 16 - 410.4375 MHz
- IR 17 - 410.6375 MHz
- IR 18 - 410.8375 MHz
- 5680 kHz - USB voice - SAR operations
- 8364 kHz - USB voice - SAR operations
- 40.5000 MHz - FM Guard - FM SINCGARS military emergency use only - Fox Guard or Fox Mike Guard 40.5 MHz
- 121.5000 MHz - VHF Guard - VHF aircraft emergency use only - Victor Guard 121.5 MHz
- 243.0000 MHz - UHF Guard - UHF aircraft emergency use only - Uniform Guard 243.0 MHz
- 853.0125 MHz - 8TAC94D - SAR Command interop simplex - 156.7 Hz CTCSS
National Interagency Fire Center - NIFC Radio Cache National Incident Radio Support Cache - NIRSC. Forest fire firefighting wildfire fighting radio communications support. Includes extensive VHF aircraft band capability, remote links (using UHF) for portable/temporary VHF repeater networks, mountaintop VHF aircraft band, mountaintop VHF-FM base stations and linked repeaters using point-to-point UHF systems with directional antennas, VHF-AM base station kits (with UHF remote linking and directional antennas) solar-power charging stations, solar powered repeaters and base stations for VHF-FM and VHF-AM and other go-kits for setting up an entire radio communications network in a remote area with limited or no radio communications infrastructure. Use of the 163.100 MHz and 168.350 MHz government common "work" channels is included in their plan as well as numerous VHF-AM airband frequencies.
- 168.6250 MHz - Nationwide AIR GUARD - Must be included for air-to-ground communications - 110.9 Hz CTCSS required
- 168.6500 MHz - Nationwide Flight Following - National Flight Following frequency, interagency aircraft contact - 110.9 Hz CTCSS required
Oil Spill Cleanup
