Militia Radio Frequencies
UHF (FRS) is preferred for short-range tactical nets, while VHF (MURS) and CB frequencies are preferred for command nets and vehicle to vehicle communications. Amateur frequencies should never be used by unlicensed personnel or radio operators. See also: Survivalist and Militia Patriot CB AM SSB Frequencies 26-28 MHz 27 MHz 11m band frequency plan.
- Channel 1 - 462.5625 MHz - FRS 1 - FRS Nationwide Calling
- Channel 2 - 462.5875 MHz - FRS 2 - Tac
- Channel 3 - 462.6125 MHz - FRS 3 - Primary Patriot Militia Calling
- Channel 4 - 462.6375 MHz - FRS 4 - Convoy Tac Ops
- Channel 5 - 462.6625 MHz - FRS 5 - Tac
- Channel 6 - 462.6875 MHz - FRS 6 - Tac
- Channel 7 - 462.7125 MHz - FRS 7 - Tac
- Channel 8 - 467.5625 MHz - FRS 8 - Tac
- Channel 9 - 467.5875 MHz - FRS 9 - Tac, Calling/Mutual Aid
- Channel 10 - 467.6125 MHz - FRS 10 - Tac
- Channel 11 - 467.6375 MHz - FRS 11 - Tac
- Channel 12 - 467.6625 MHz - FRS 12 - Tac
- Channel 13 - 467.6875 MHz - FRS 13 - Tac
- Channel 14 - 467.7125 MHz - FRS 14 - Tac
- Channel 15 - 462.5500 MHz - FRS 15 - Tac
- Channel 16 - 462.5750 MHz - FRS 16 - Convoy Tac Ops
- Channel 17 - 462.6000 MHz - FRS 17 - Patriot Militia Ops Tactical
- Channel 18 - 462.6250 MHz - FRS 18 - Tac
- Channel 19 - 462.6500 MHz - FRS 19 - Tac, Calling/Mutual Aid
- Channel 20 - 462.6750 MHz - FRS 20 - Calling/GMRS Travel Channel
- Channel 21 - 462.7000 MHz - FRS 21 - Tac
- Channel 22 - 462.7250 MHz - FRS 22 - Tac
- Channel 31 - 151.8200 MHz - MURS 1 - Calling, Tac/Ops
- Channel 32 - 151.8800 MHz - MURS 2 - Command or Safety Channel
- Channel 33 - 151.9400 MHz - MURS 3 - Primary Patriot Militia Calling or Prepper Frequency Prep
- Channel 34 - 154.5700 MHz - MURS 4 - Command Blue or Tac/Ops (alternate to MURS 1 and MURS 3)
- Channel 35 - 154.6000 MHz - MURS 5 - Command Green or Tac/Ops (alternate to MURS 1 and MURS 3)
- FRS 1 - 462.5625 MHz - 67.0 Hz
- FRS 2 - 462.5875 MHz - 71.9 Hz or 118.8 Hz
- FRS 3 - 462.6125 MHz - 74.4 Hz, 88.5 Hz or 127.3 Hz.
- FRS 4 - 462.6375 MHz - 131.8 Hz
- FRS 5 - 462.6625 MHz - 136.5 Hz, 79.7 Hz, or 88.5 Hz
- FRS 6 - 462.6875 MHz - 141.3 Hz
- FRS 7 - 462.7125 MHz - 97.4 Hz or 146.2 Hz
- FRS 8 - 467.5625 MHz - 88.5 Hz
- FRS 9 - 467.5875 MHz - 88.5 Hz, 97.4 Hz, or 127.3 Hz
- FRS 10 - 467.6125 MHz - 77.0 Hz or 88.5 Hz
- FRS 11 - 467.6375 MHz - 88.5 Hz
- FRS 12 - 467.6625 MHz - 88.5 Hz
- FRS 13 - 467.6875 MHz - 88.5 Hz
- FRS 14 - 467.7125 MHz - 88.5 Hz or 107.2 Hz
- FRS 15 - 462.5500 MHz - 71.9 Hz, 123.0 Hz or 141.3 Hz
- FRS 16 - 462.5750 MHz - 141.3 Hz
- FRS 17 - 462.6000 MHz - 141.3 Hz
- FRS 18 - 462.6250 MHz - 127.3 Hz
- FRS 19 - 462.6500 MHz - 127.3 Hz or 141.3 Hz
- FRS 20 - 462.6750 MHz - 141.3 Hz strongly recommended
- FRS 21 - 462.7000 MHz - 141.3 Hz
- FRS 22 - 462.7250 MHz - 136.5 Hz
- MURS 1 - 151.8200 MHz - 88.5 Hz CALL
- MURS 2 - 151.8800 MHz - 88.5 Hz or 210.7 Hz CTCSS SAFETY tone transmit recommend 210.7 Hz PL
- MURS 3 - 151.9400 MHz - 88.5 Hz or 141.3 Hz CTCSS PREP tone transmit 141.3 Hz PL
- MURS 4 - 154.5700 MHz - 88.5 Hz COMMAND/TAC BLUE
- MURS 5 - 154.6000 MHz - 88.5 Hz COMMAND/TAC GREEN
Simplified MURS / FRS tactical programming - Radio settings: WN: NARR ROGER: OFF ANI: OFF RP-STE: OFF STE: OFF TOT: 30 T-CTCS: 88.5Hz R-CTCS: OFF T-DCS: OFF R-DCS: OFF
- Channel - FUTURE SECTION FOR SIMPLIFIED PLAN
- Channel 001 - FRS 1 - 462.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 1
- Channel 002 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 118.8 Hz - display channel name: FRS 2
- Channel 003 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 3
- Channel 004 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 131.8 Hz - display channel name: FRS 4
- Channel 005 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 136.5 Hz - display channel name: FRS 5
- Channel 006 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 6
- Channel 007 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 146.2 Hz - display channel name: FRS 7
- Channel 008 - FRS 8 - 467.5625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 8
- Channel 009 - FRS 9 - 467.5875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 9
- Channel 010 - FRS 10 - 467.6125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 10
- Channel 011 - FRS 11 - 467.6375 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 11
- Channel 012 - FRS 12 - 467.6625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 12
- Channel 013 - FRS 13 - 467.6875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 13
- Channel 014 - FRS 14 - 467.7125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 14
- Channel 015 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 123.0 Hz - display channel name: FRS 15
- Channel 016 - FRS 16 - 462.5750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 16
- Channel 017 - FRS 17 - 462.6000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 17
- Channel 018 - FRS 18 - 462.6250 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 18
- Channel 019 - FRS 19 - 462.6500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 19
- Channel 020 - FRS 20 - 462.6750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 20
- Channel 021 - FRS 21 - 462.7000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 21
- Channel 022 - FRS 22 - 462.7250 MHz - Mode: NFM - Tone: 136.5 Hz - display channel name: FRS 22
- Channel 031 - MURS 1 - 151.8200 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 1
- Channel 032 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 2
- Channel 033 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 3
- Channel 034 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 4
- Channel 035 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 5
- Channel 041 - FRS 1 - 462.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 1 CALL - high power setting
- Channel 042 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 118.8 Hz - display channel name: FRS 2 CALL - high power setting
- Channel 043 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 3 CALL - high power setting
- Channel 044 - FRS 20 - 462.6750 MHz - Mode: NFM - Tone 141.3 Hz - display channel name: FRS 20 CALL - high power setting
- Channel 045 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 - display channel name: MURS 3 CALL - high power setting
- Channel 046 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 4 TAC - low power setting
- Channel 047 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 5 TAC - low power setting
- Channel 048 - FRS 8 - 467.5625 MHz - Mode: NFM_ - Tone: 88.5 Hz - display channel name: FRS 8 TAC - low power setting
- Channel 048 - FRS 9 - 467.5875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 9 TAC - low power setting
- Channel 050 - FRS 10 - 467.6125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 10 TAC - low power setting
- Channel 051 - FRS 11 - 467.6375 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 11 TAC - low power setting
- Channel 052 - FRS 12 - 467.6625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 12 TAC - low power setting
- Channel 053 - FRS 13 - 467.6875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 13 TAC - low power setting
- Channel 054 - FRS 14 - 467.7125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 14 TAC - low power setting
- Channel 101 - FRS 1 - 462.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 1 HP - high power setting
- Channel 102 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 118.8 Hz - display channel name: FRS 2 HP - high power setting
- Channel 103 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 3 HP - high power setting
- Channel 104 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 131.8 Hz - display channel name: FRS 4 HP - high power setting
- Channel 105 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 136.5 Hz - display channel name: FRS 5 HP - high power setting
- Channel 106 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 6 HP - high power setting
- Channel 107 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 146.2 Hz - display channel name: FRS 7 HP - high power setting
- Channel 108 - FRS 8 - 467.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 8 HP - high power setting
- Channel 109 - FRS 9 - 467.5875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 9 HP - high power setting
- Channel 110 - FRS 10 - 467.6125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 10 HP - high power setting
- Channel 111 - FRS 11 - 467.6375 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 11 HP - high power setting
- Channel 112 - FRS 12 - 467.6625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 12 HP - high power setting
- Channel 113 - FRS 13 - 467.6875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 13 HP - high power setting
- Channel 114 - FRS 14 - 467.7125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 14 HP - high power setting
- Channel 115 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 123.0 Hz - display channel name: FRS 15 HP - high power setting
- Channel 116 - FRS 16 - 462.5750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 16 HP - high power setting
- Channel 117 - FRS 17 - 462.6000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 17 HP - high power setting
- Channel 118 - FRS 18 - 462.6250 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 18 HP - high power setting
- Channel 119 - FRS 19 - 462.6500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 19 HP - high power setting
- Channel 120 - FRS 20 - 462.6750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 20 HP - high power setting
- Channel 121 - FRS 21 - 462.7000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 21 HP - high power setting
- Channel 122 - FRS 22 - 462.7250 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 22 HP - high power setting
- Channel 123 - MURS 1 - 151.8200 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 1 HP - high power setting
- Channel 124 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 2 HP - high power setting
- Channel 125 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 3 HP - high power setting
- Channel 126 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 4 HP - high power setting
- Channel 127 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 5 HP - high power setting
- 151.9400 MHz - Militia/Patriot VHF MURS 3 - Primary Calling, Command Nets, AmRRON Patriot Nationwide Primary MURS 3 (also FRS 3, CB 3 and 146.42 MHz)
- 154.5700 MHz - Militia/Patriot VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel, Vehicle Coordination
- 154.6000 MHz - Militia/Patriot VHF MURS 5 - Tactical or Command Nets
- 467.5625 MHz - Militia/Patriot UHF FRS 8 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.5875 MHz - Militia/Patriot UHF FRS 9 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6125 MHz - Militia/Patriot UHF FRS 10 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6375 MHz - Militia/Patriot UHF FRS 11 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6625 MHz - Militia/Patriot UHF FRS 12 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6875 MHz - Militia/Patriot UHF FRS 13 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.7125 MHz - Militia/Patriot UHF FRS 14 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 462.5500 MHz - Militia/Patriot UHF FRS 15
- 462.5750 MHz - Militia/Patriot UHF FRS 16 - Patriot Tactical, Vehicle Coordination (see also: FRS ch. 4)
- 462.6000 MHz - Militia/Patriot UHF FRS 17
- 467.5875 MHz - FRS9 - Militia/Patriot UHF FRS Channel 9 - Tactical
- 467.6125 MHz - FRS10 - Militia/Patriot UHF FRS Channel 10 - Tactical
- 467.6375 MHz - FRS11 - Militia/Patriot UHF FRS Channel 11 - Tactical
- 467.6625 MHz - FRS12 - Militia/Patriot UHF FRS Channel 12 - Tactical
- 467.6875 MHz - FRS13 - Militia/Patriot UHF FRS Channel 13 - Tactical
- 467.7125 MHz - FRS14 - Militia/Patriot UHF FRS Channel 14 - Tactical
Militia Intra-Squad Radio Frequencies Channels UHF 16-Channel Radio Programming Plan Militia Patriot Inter-Squad Radio Frequencies Channel List
RECOMMENDED MILITIA PATRIOT ISR INTRA SQUAD INTER-SQUAD INTRA SQUAD RADIO 16 CHANNEL RADIO BF888S MILITIA PROGRAMMING LIST
Ideal for low power (under 5 watt, ideally in the 0.5 to 2 watt range) short-range communications using dedicated 16 channel UHF handhelds. These radios are very inexpensive, can easily be programmed with CHIRP and since there are only 16 channels, these channels can also be added to your standard VHF/UHF tactical radio of choice's programming plan for communications between the intra squad radio frequencies (intra-squad radio, ISR) and the standard Baofeng militia radios. Identical in function to the real integrated intra-squad radio (IISR), the analog 380-400 MHz military intra squad radio, and Personal Radio Radio (PRR).
- Intra Squad Radio Channel 01 - 467.8375 MHz - 159.8 Hz CTCSS - ISR01 - 467.83750 NFM 159.8 TSQL
- Intra Squad Radio Channel 02 - 469.5125 MHz - 159.8 Hz CTCSS - ISR02 - 469.51250 NFM 159.8 TSQL
- Intra Squad Radio Channel 03 - 456.3375 MHz - 189.9 Hz CTCSS - ISR03 - 456.33750 NFM 189.9 TSQL
- Intra Squad Radio Channel 04 - 456.4375 MHz - 189.9 Hz CTCSS - ISR04 - 456.43750 NFM 189.9 TSQL
- Intra Squad Radio Channel 05 - 467.8625 MHz - 165.5 Hz CTCSS - ISR05 - 467.86250 NFM 165.5 TSQL
- Intra Squad Radio Channel 06 - 467.8875 MHz - 165.5 Hz CTCSS - ISR06 - 467.88750 NFM 165.5 TSQL
- Intra Squad Radio Channel 07 - 462.7875 MHz - 254.1 Hz CTCSS - ISR07 - 462.78750 NFM 254.1 TSQL
- Intra Squad Radio Channel 08 - 462.8875 MHz - 254.1 Hz CTCSS - ISR08 - 462.88750 NFM 254.1 TSQL
- Intra Squad Radio Channel 09 - 462.8375 MHz - 254.1 Hz CTCSS - ISR09 - 462.83750 NFM 254.1 TSQL
- Intra Squad Radio Channel 10 - 469.5625 MHz - 159.8 Hz CTCSS - ISR10 - 469.56250 NFM 159.8 TSQL
- Intra Squad Radio Channel 11 - 457.6625 MHz - 189.9 Hz CTCSS - ISR11 - 457.66250 NFM 189.9 TSQL
- Intra Squad Radio Channel 12 - 452.1875 MHz - 171.3 Hz CTCSS - ISR12 - 452.18750 NFM 171.3 TSQL
- Intra Squad Radio Channel 13 - 451.4375 MHz - 177.3 Hz CTCSS - ISR13 - 451.43750 NFM 177.3 TSQL
- Intra Squad Radio Channel 14 - 457.7125 MHz - 165.5 Hz CTCSS - ISR14 - 457.71250 NFM 165.5 TQSL
- Intra Squad Radio Channel 15 - 451.3375 MHz - 177.3 Hz CTCSS - ISR15 - 451.33750 NFM 177.3 TSQL
- Intra Squad Radio Channel 16 - 467.8000 MHz - 254.1 Hz CTCSS - ISR16 - 467.80000 NFM 254.1 TSQL
CHIRP Programming For BF-888S Type Radio (BF-888S, Luiton LT-458, Arcshell AR-5, Arcshell AR-6, Radioditty GA-2S, etc.)
- Loc - Frequency- Tone Mode - ToneSql - Mode - Power - Skip
- 1 - 467.837500 - TSQL - 159.8 - NFM - Low - S
- 2 - 469.512500 - TSQL - 159.8 - NFM - Low - S
- 3 - 456.337500 - TSQL - 189.9 - NFM - Low - S
- 4 - 456.437500 - TSQL - 189.9 - NFM - Low - S
- 5 - 467.862500 - TSQL - 165.5 - NFM - Low - S
- 6 - 467.887500 - TSQL - 165.5 - NFM - Low - S
- 7 - 462.787500 - TSQL - 254.1 - NFM - Low - S
- 8 - 462.887500 - TSQL - 254.1 - NFM - Low - S
- 9 - 462.837500 - TSQL - 254.1 - NFM - Low - S
- 10 - 469.562500 - TSQL - 159.8 - NFM - Low - S
- 11 - 457.662500 - TSQL - 189.9 - NFM - Low - S
- 12 - 452.187500 - TSQL - 171.3 - NFM - Low - S
- 13 - 451.437500 - TSQL - 177.3 - NFM - Low - S
- 14 - 457.712500 - TSQL - 165.5 - NFM - Low - S
- 15 - 451.337500 - TSQL - 177.3 - NFM - Low - S
- 16 - 467.800000 - TSQL - 254.1 - NFM - Low - S
CHIRP Programming For UV-5R UV-82 Type Radio (Baofeng UV-5R UV-82HP Series, 128 channel VHF/UHF Handheld Radios)
Name may be altered to fit local needs and/or specific applications. For example, instead of "ISR01", a different designator could be used, such as "SRT01" (Short Range Tactical Radio Channel 1), "USR01" (Urban Short Range Channel 1), "LPT" (Low Power Tactical), and so on. The memory channel (LOC or "location" - memory channel number) obviously may be altered to best fit existing programming plans, etc.
- Loc - Frequency - Name - Tone Mode - ToneSql - Duplex - Mode - Power - Skip
- 101 - 467.837500 - ISR01 - TSQL - 159.8 - (None) - NFM - Low - S
- 102 - 469.512500 - ISR02 - TSQL - 159.8 - (None) - NFM - Low - S
- 103 - 456.337500 - ISR03 - TSQL - 189.9 - (None) - NFM - Low - S
- 104 - 456.437500 - ISR04 - TSQL - 189.9 - (None) - NFM - Low - S
- 105 - 467.862500 - ISR05 - TSQL - 165.5 - (None) - NFM - Low - S
- 106 - 467.887500 - ISR06 - TSQL - 165.5 - (None) - NFM - Low - S
- 107 - 462.787500 - ISR07 - TSQL - 254.1 - (None) - NFM - Low - S
- 108 - 462.887500 - ISR08 - TSQL - 254.1 - (None) - NFM - Low - S
- 109 - 462.837500 - ISR09 - TSQL - 254.1 - (None) - NFM - Low - S
- 110 - 469.562500 - ISR10 - TSQL - 159.8 - (None) - NFM - Low - S
- 111 - 457.662500 - ISR11 - TSQL - 189.9 - (None) - NFM - Low - S
- 112 - 452.187500 - ISR12 - TSQL - 171.3 - (None) - NFM - Low - S
- 113 - 451.437500 - ISR13 - TSQL - 177.3 - (None) - NFM - Low - S
- 114 - 457.712500 - ISR14 - TSQL - 165.5 - (None) - NFM - Low - S
- 115 - 451.337500 - ISR15 - TSQL - 177.3 - (None) - NFM - Low - S
- 116 - 467.800000 - ISR16 - TSQL - 254.1 - (None) - NFM - Low - S
The 16 channel version above is designed for 16 channel handheld radios discussed below. Extended versions (using sets of 16 channels) are also possible.
- Channel 01 - 467.8375 MHz - 159.8 Hz CTCSS - ISR01 - 467.83750 NFM 159.8 TSQL
- Channel 02 - 469.5125 MHz - 159.8 Hz CTCSS - ISR02 - 469.51250 NFM 159.8 TSQL
- Channel 03 - 456.3375 MHz - 189.9 Hz CTCSS - ISR03 - 456.33750 NFM 189.9 TSQL
- Channel 04 - 456.4375 MHz - 189.9 Hz CTCSS - ISR04 - 456.43750 NFM 189.9 TSQL
- Channel 05 - 467.8625 MHz - 165.5 Hz CTCSS - ISR05 - 467.86250 NFM 165.5 TSQL
- Channel 06 - 467.8875 MHz - 165.5 Hz CTCSS - ISR06 - 467.88750 NFM 165.5 TSQL
- Channel 07 - 462.7875 MHz - 254.1 Hz CTCSS - ISR07 - 462.78750 NFM 254.1 TSQL
- Channel 08 - 462.8875 MHz - 254.1 Hz CTCSS - ISR08 - 462.88750 NFM 254.1 TSQL
- Channel 09 - 462.8375 MHz - 254.1 Hz CTCSS - ISR09 - 462.83750 NFM 254.1 TSQL
- Channel 10 - 469.5625 MHz - 159.8 Hz CTCSS - ISR10 - 469.56250 NFM 159.8 TSQL
- Channel 11 - 457.6625 MHz - 189.9 Hz CTCSS - ISR11 - 457.66250 NFM 189.9 TSQL
- Channel 12 - 452.1875 MHz - 171.3 Hz CTCSS - ISR12 - 452.18750 NFM 171.3 TSQL
- Channel 13 - 451.4375 MHz - 177.3 Hz CTCSS - ISR13 - 451.43750 NFM 177.3 TSQL
- Channel 14 - 457.7125 MHz - 165.5 Hz CTCSS - ISR14 - 457.71250 NFM 165.5 TQSL
- Channel 15 - 451.3375 MHz - 177.3 Hz CTCSS - ISR15 - 451.33750 NFM 177.3 TSQL
- Channel 16 - 467.8000 MHz - 254.1 Hz CTCSS - ISR16 - 467.80000 NFM 251.1 TSQL
- FRS Channels 1-16 (allows simple interoperability with standard FRS radios and standard militia programmed radios). Tone mode should be set to Tone (not TSQL - unless you are programming radios for a group/unit/team/squad/crew specific channel plan - see links and general information above and example programming plans below).
- Channel 01 - 462.5625 MHz [transmit Tone 67.0 Hz] - FRS Channel 1
- Channel 02 - 462.5875 MHz [transmit Tone 118.8 Hz] - FRS Channel 2
- Channel 03 - 462.6125 MHz [transmit Tone 127.3 Hz] - FRS Channel 3
- Channel 04 - 462.6375 MHz [transmit Tone 131.8 Hz] - FRS Channel 4
- Channel 05 - 462.6625 MHz [transmit Tone 136.5 Hz] - FRS Channel 5
- Channel 06 - 462.6875 MHz [transmit Tone 141.3 Hz] - FRS Channel 6
- Channel 07 - 462.7125 MHz [transmit Tone 146.2 Hz] - FRS Channel 7
- Channel 08 - 467.5625 MHz [transmit Tone 88.5 Hz] - FRS Channel 8
- Channel 09 - 467.5875 MHz [transmit Tone 88.5 Hz] - FRS Channel 9
- Channel 10 - 467.6125 MHz [transmit Tone 88.5 Hz] - FRS Channel 10
- Channel 11 - 467.6375 MHz [transmit Tone 88.5 Hz] - FRS Channel 11
- Channel 12 - 467.6625 MHz [transmit Tone 88.5 Hz] - FRS Channel 12
- Channel 13 - 467.6875 MHz [transmit Tone 88.5 Hz] - FRS Channel 13
- Channel 14 - 467.7125 MHz [transmit Tone 88.5 Hz] - FRS Channel 14
- Channel 15 - 462.5500 MHz [transmit Tone 88.5 Hz] - FRS Channel 15
- Channel 16 - 462.5750 MHz [transmit Tone 88.5 Hz] - FRS Channel 16
- FRS Calling/Tactical Channels (16 channel programming):
- Channel 01 - 462.5625 MHz [transmit Tone 67.0 Hz] - FRS Channel 1 - FRS Nationwide Calling
- Channel 02 - 462.5875 MHz [transmit Tone 88.5 Hz] - FRS Channel 2 - Tactical
- Channel 03 - 462.6125 MHz [transmit Tone 88.5 Hz] - FRS Channel 3 - Patriot/Militia Calling
- Channel 04 - 462.6375 MHz [transmit Tone 88.5 Hz] - FRS Channel 4 - Convoy Tac/Operations
- Channel 05 - 462.5750 MHz [transmit Tone 88.5 Hz] - FRS Channel 16 - Convoy Tactical/Operations
- Channel 06 - 462.6750 MHz [transmit Tone 141.3 Hz] - FRS Channel 20 - GMRS Nationwide Calling
- Channel 07 - 462.6000 MHz [transmit Tone 88.5 Hz] - FRS Channel 17 - Patriot Militia Ops Tactical
- Channel 08 - 462.6250 MHz [transmit Tone 88.5 Hz] - FRS Channel 18 - Tactical
- Channel 09 - 462.6500 MHz [transmit Tone 88.5 Hz] - FRS Channel 19 - Tac, Calling/Mutual Aid
- Channel 10 - 467.6125 MHz [transmit Tone 88.5 Hz] - FRS Channel 10 - Tactical
- Channel 11 - 467.6375 MHz [transmit Tone 88.5 Hz] - FRS Channel 11 - Tactical
- Channel 12 - 467.6625 MHz [transmit Tone 88.5 Hz] - FRS Channel 12 - Tactical
- Channel 13 - 467.6875 MHz [transmit Tone 88.5 Hz] - FRS Channel 13 - Tactical
- Channel 14 - 467.7125 MHz [transmit Tone 88.5 Hz] - FRS Channel 14 - Tactical
- Channel 15 - 462.6625 MHz [transmit Tone 88.5 Hz] - FRS Channel 5 - Tactical
- Channel 16 - 462.6875 MHz [transmit Tone 88.5 Hz] - FRS Channel 6 - Tactical
- Example 16-channel intra squad radio inter squad radio plan - using FRS frequencies only - tone type is TSQL (fully toned) and all radios must be programmed identically. Use of full tone squelch will reduce interference from co-channel users but will prevent interoperability with other groups unless their radios are programmed to use the exact same tone squelch. For this reason, users are cautioned to only use full tone squelch (transmit and receive squelch) for communications within their own trusted group. For additional template private (toned) frequency channel plans using FRS frequencies - see the full list here.
- Channel 01 - 467.6625 MHz - 171.3 Hz CTCSS FRS Channel 12
- Channel 02 - 467.5625 MHz - 165.5 Hz CTCSS FRS Channel 8
- Channel 03 - 467.6375 MHz - 171.3 Hz CTCSS FRS Channel 11
- Channel 04 - 462.7000 MHz - 210.7 Hz CTCSS FRS Channel 21
- Channel 05 - 467.7125 MHz - 165.5 Hz CTCSS FRS Channel 14
- Channel 06 - 462.6000 MHz - 210.7 Hz CTCSS FRS Channel 17
- Channel 07 - 462.6500 MHz - 210.7 Hz CTCSS FRS Channel 19
- Channel 08 - 467.6125 MHz - 171.3 Hz CTCSS FRS Channel 10
- Channel 09 - 467.5875 MHz - 199.5 Hz CTCSS FRS Channel 9
- Channel 10 - 462.5750 MHz - 210.7 Hz CTCSS FRS Channel 16
- Channel 11 - 462.6750 MHz - 210.7 Hz CTCSS FRS Channel 20
- Channel 12 - 462.5500 MHz - 210.7 Hz CTCSS FRS Channel 15
- Channel 13 - 462.5875 MHz - 229.1 Hz CTCSS FRS Channel 2
- Channel 14 - 462.6875 MHz - 229.1 Hz CTCSS FRS Channel 6
- Channel 15 - 462.6125 MHz - 225.7 Hz CTCSS FRS Channel 3
- Channel 16 - 462.7125 MHz - 233.6 Hz CTCSS FRS Channel 7
- Example 16-channel intra squad radio inter squad radio plan - using business frequencies only - tone type is TSQL (fully toned) and all radios must be programmed identically. Use of full tone squelch will reduce interference from co-channel users but will prevent interoperability with other groups unless their radios are programmed to use the exact same tone squelch. For this reason, users are cautioned to only use full tone squelch (transmit and receive squelch) for communications within their own trusted group. For additional template private (toned) frequency channel plans - see the full list here.
The most commonly used frequencies are 464.550 MHz, 464.500 MHz, 467.925 MHz, 467.900 MHz, 467.875 MHz, 467.850 MHz, 467.8125 MHz, 467.7625 MHz, 469.550 MHz, 469.500 MHz, 451.800 MHz, 456.800 MHz, 451.8125 MHz, 456.8125 MHz, 461.0375 MHz, 461.0625 MHz, and 461.0875 MHz. Avoid using those frequencies if at all possible and monitor the particular frequency use in your area.
Channel Assignments Frequency Requirements For Teams Squads Platoons etc.
- Tactical Channels - common frequencies/channels for liaison between friendly forces - must be agreed upon ahead of time. Tactical channels overlap with intra squad radio channels for obvious reasons. For tactical purposes, moving off the designated calling/mutual aid channels is a good idea...and is another reason why having multiple calling/mutual aid channels is a good idea...it allows primary tactical ops to be moved to a secondary mutual aid channel - thus clearing the main calling channel for other friendly forces to use.
In urban areas, UHF (FRS) is the best choice for this, but VHF (MURS) will work as well. In less built-up areas, either will work. Multiple tactical channels should be available for teams to be able to switch to as the situation dictates.
- Calling, Monitor and Mutual Aid Channels - common frequencies/channels for liaison between friendly forces (similar to tactical channels in many respects) - these include FRS channel 3 (462.6125 MHz), MURS channel 3 (151.940 MHz) and others. As with the tactical channels, mutual aid channels should be determined ahead of time.
- Command Channel - Larger formations may wish to have a dedicated command channel, perhaps with a designated alternate (backup) channel. In many situations, this is not needed and actually adds more complexity and confusion.
- Radio A - 5 feet above ground communicating with Radio B - 5 feet above ground = 5 miles line of sight range
- Radio A - 20 feet above ground communicating with Radio B - 5 feet above ground = 9 miles line of sight range
- Radio A - 30 feet above ground communicating with Radio B - 5 feet above ground = 11 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 5 feet above ground = 13 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 5 feet above ground = 17 miles line of sight range
- Radio A - 20 feet above ground communicating with Radio B - 10 feet above ground = 10 miles line of sight range
- Radio A - 20 feet above ground communicating with Radio B - 20 feet above ground = 12 miles line of sight range
- Radio A - 30 feet above ground communicating with Radio B - 10 feet above ground = 12 miles line of sight range
- Radio A - 30 feet above ground communicating with Radio B - 20 feet above ground = 14 miles line of sight range
- Radio A - 30 feet above ground communicating with Radio B - 30 feet above ground = 16 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 10 feet above ground = 14 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 20 feet above ground = 16 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 30 feet above ground = 18 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 40 feet above ground = 19 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 50 feet above ground = 20 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 10 feet above ground = 18 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 20 feet above ground = 20 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 30 feet above ground = 22 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 40 feet above ground = 23 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 50 feet above ground = 24 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 60 feet above ground = 25 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 75 feet above ground = 26 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 100 feet above ground = 28 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 5 feet above ground = 23 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 10 feet above ground = 24 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 25 feet above ground = 27 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 50 feet above ground = 30 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 75 feet above ground = 32 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 100 feet above ground = 34 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 125 feet above ground = 36 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 150 feet above ground = 37 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 175 feet above ground = 39 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 200 feet above ground = 40 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 5 feet above ground = 35 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 10 feet above ground = 36 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 25 feet above ground = 39 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 50 feet above ground = 42 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 75 feet above ground = 44 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 100 feet above ground = 46 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 150 feet above ground = 49 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 200 feet above ground = 52 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 250 feet above ground = 54 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 500 feet above ground = 64 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 5 feet above ground = 48 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 10 feet above ground = 49 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 25 feet above ground = 52 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 50 feet above ground = 55 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 100 feet above ground = 59 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 150 feet above ground = 62 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 200 feet above ground = 65 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 250 feet above ground = 67 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 500 feet above ground = 77 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 750 feet above ground = 84 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 1000 feet above ground = 90 miles line of sight range
