MURS
Revision as of 13:00, 15 June 2022 by R4002 (Talk | contribs)
Multi Use Radio Service
Were you looking for militia tactical radio channel plans? (MURS is an important part).
MURS Frequencies / Channels:
MURS Channel 2 MURS-2 151.880 MHz 11.25 kHz Recommended simplex repeater/crossband repeater channel (156.7 Hz CTCSS tone) and SAFETY channel - TX 210.7 Hz CTCSS 210.7 PL
MURS Channel 3 MURS-3 151.940 MHz 11.25 kHz Recommended prepper/emergency management/disaster response calling/working channel - TX 88.5 Hz CTCSS or 141.3 Hz CTCSS 141.3 PL
Motorola RDM2070D VHF MURS
Motorola RDM2020 VHF MURS
Motorola RDM2080D VHF MURS
Despite their age, the Motorola CP110M series, Motorola RMM2050 and RDM2070D are still very popular jobsite radios. The RMM and RDM radios should not be confused with the Motorola RDV. RMV, RMU or RDU series radios (which require licenses to use).
  • 151.8800 MHz MURS Channel 2 151.880 MHz 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area - 151.880 MHz 156.7 Hz CTCSS. The Mount Jackson, VA MURS simplex repeater - Confirmed active May 2020 - has 50+ mile radius coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of West Virginia and western Maryland. Very large footprint.
  • 151.8800 MHz MURS Channel 2 151.880 MHz 156.7 Hz CTCSS/PL - Richmond, Virginia (Richmond City, VA) - OFF THE AIR (as of spring 2021) - unknown status. Previously covered downtown Richmond Virginia (low power transmitter).
