Amphetamine Radio
Revision as of 00:00, 5 August 2024 by R4002 (Talk | contribs)
Not to be confused with fishnet beacons or driftnet beacons (radio buoys).
Amphetamine Radio often transmits several SSTV images throughout their broadcasts and appears to be one of the most prolific transmitters of SSTV, along with other frequent users of SSTV including Wolverine Radio. Some of their broadcasts consist entirely of SSTV images. SSTV is usually transmitted in Scottie 1 mode. In addition to voice IDs, MCW (modulated CW) IDs are usually transmitted, often either before or after SSTV frames are sent.
Amphetamine Radio has not been heard for quite some time (as of August 2024). The op has indicated that he is currently unable to put up a proper antenna and will attempt to resume broadcasts once that situation changes.
Amphetamine Radio teams up with Detective Friday to fight the latest teenage dope menace! Amphetamine Radio SSTV 6950 kHz - 3 February 2018
Amphetamine Radio SSTV 6925 kHz - 25 September 2015
Amphetamine Radio SSTV 6955 kHz - 11 April 2017
Amphetamine Radio QSL
