Radio propagation beacon
Transmission characteristics
160 meters beacons
60 meters beacons
In addition to the DARC and RSBG beacon projects (see below), Eddie Bellerby of UDXF discovered in March 2011 a new CW beacon on 5206 kHz, sending LX0HF, presumably from Luxemburg.
10 meters beacons
| R1 |
| R2[3] |
| R3 |
40 MHz beacons
- The first radio propagation beacon on 40 MHz was OZ7IGY in Jystrup, Denmark (JO55WM) and transmits on 40021 kHz. Transmitted power is 22 W to a dipole antenna. Modulation is F1A keying (frequency Shift Keying), with a shift of 250 Hz. [1]
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
Beacon projects
IARU Beacon Project
The International Beacon Project (IBP), which is coordinated by the Northern California DX Foundation and the International Amateur Radio Union, consists of 18 HF propagation beacons worldwide, which transmit in turns on 14100 kHz, 18110 kHz, 21150 kHz, 24930 kHz, and 28200 kHz. [5] The IARU/NDXF beacons transmit in turns on the five designated frequencies according to the following schedule, which repeats every 3 minutes:
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
- Aurora Beacon DK0WCY
