Radio propagation beacon
Transmission characteristics
160 meters beacons
60 meters beacons
10 meters beacons
| R1 |
| R2[3] |
| R3 |
40 MHz beacons
- The first radio propagation beacon on 40 MHz was OZ7IGY in Jystrup, Denmark (JO55WM) and transmits on 40021 kHz. Transmitted power is 22 W to a dipole antenna. Modulation is F1A keying (frequency Shift Keying), with a shift of 250 Hz. [1]
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
| R1 | R2 | R3 | |
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
SHF and microwave beacons
| ITU Region 1 | ITU Region 2 | ITU Region 3 | |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
- Aurora Beacon DK0WCY
