Radio propagation beacon
Transmission characteristics
160 meters beacons
60 meters beacons
Callsign | Frequency | Locator | Details |
DRA5 | 5195.0 kHz | JO44VQ | DARC |
LX0HF | 5205.3 kHz | ||
OK1IF | 5258.5 kHz | JO40HG | Recording: [1] |
GB3RAL | 5290.0 kHz | IO91IN | RSGB |
GB3WES | 5290.0 kHz | IO84QN | RSGB |
GB3ORK | 5290.0 kHz | IO89JA | RSGB |
OV1BCN | 5290.0 kHz | JO55SI | Op OZ1FJB [2] |
10 meters beacons
R1 |
R2[3] |
R3 |
40 MHz beacons
- The first radio propagation beacon on 40 MHz was OZ7IGY in Jystrup, Denmark (JO55WM) and transmits on 40021 kHz. Transmitted power is 22 W to a dipole antenna. Modulation is F1A keying (frequency Shift Keying), with a shift of 250 Hz. [3]
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
R1 | R2 | R3 | |
4 m | 70,000-70,030 |
2 m | 144,400-144,490 |
70 cm | 432,800-432,990 |
23 cm | 1296,800-1296,990 |
SHF and microwave beacons
R1 | R2 | R3 | |
9 cm | 3,400.800-3,400.995 | 3,456.300-3,456.400 | Unknown |
5 cm | 5,760.800-5,760.995 | 5,760.300-5,760.400 | Unknown |
3 cm | 10,368.800-10,368.995 | 10,368.300-10,368.400 | Unknown |
1.2 cm | Beacons are rare |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
- Aurora Beacon DK0WCY
![]() | This article contains textual material from Wikipedia (TM). Wikipedia texts are licensed under the Creative Commons Attribution-Share Alike license. In short: you are free to distribute and modify the text as long as you attribute its author(s) or licensor(s). If you alter, transform, or build upon this work, you may distribute the resulting work only under the same or similar license to this one. Wikipedia article: Radio_propagation_beacon | WP |
