Radio propagation beacon
Transmission characteristics
Most beacons consist of a simple digital keyer, based on discrete digital electronics or a microcontroller, and a low power transmitter or tranceiver. Antennas usually are types with low directivity.
160 meters beacons
60 meters beacons
Callsign | Frequency | Locator | Details |
DRA5 | 5195.0 kHz | JO44VQ | DARC |
LX0HF | 5205.3 kHz | ||
OK1IF | 5258.5 kHz | JO40HG | Recording: [1] |
GB3RAL | 5290.0 kHz | IO91IN | RSGB |
GB3WES | 5290.0 kHz | IO84QN | RSGB |
GB3ORK | 5290.0 kHz | IO89JA | RSGB |
OV1BCN | 5290.0 kHz | JO55SI | Op OZ1FJB [2] |
30 meters beacons
DK0WCY | 10144.0 kHz | JO44VQ | DARC |
IK3NWX | 10137.3 kHz | JN55VF | nr Monselice, PD 15m asl |
10 meters beacons
R1 |
R2[3] |
R3 |
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
R1 | R2 | R3 | |
4 m | 70,000-70,030 |
2 m | 144,400-144,490 |
70 cm | 432,800-432,990 |
23 cm | 1296,800-1296,990 |
SHF and microwave beacons
R1 | R2 | R3 | |
9 cm | 3,400.800-3,400.995 | 3,456.300-3,456.400 | Unknown |
5 cm | 5,760.800-5,760.995 | 5,760.300-5,760.400 | Unknown |
3 cm | 10,368.800-10,368.995 | 10,368.300-10,368.400 | Unknown |
1.2 cm | Beacons are rare |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
Beacon lists
Currently there are two regularly updated international beacon lists, compiled by Martin G3USF and Joost, ZS5S. Both lists are available on-line.
- Aurora Beacon DK0WCY
![]() | This article contains textual material from Wikipedia (TM). Wikipedia texts are licensed under the Creative Commons Attribution-Share Alike license. In short: you are free to distribute and modify the text as long as you attribute its author(s) or licensor(s). If you alter, transform, or build upon this work, you may distribute the resulting work only under the same or similar license to this one. Wikipedia article: Radio_propagation_beacon | WP |
