Radio propagation beacon
History
The earliest record of radio propagation beacons goes back to World War II, when the German military operated propagation beacons on wavelengths of approximate 80 m and 10 m. Many propagation beacons were installed during the International Geophysical Year 1957-1958 These included amateur radio beacon OZ7IGY and GB3IGY (later GB3RAL) on 144 MHz, which are still operational, as well as the now defunct DM3IGY from East Germany on 28001 kHz. (19)
Transmission characteristics
160 meters beacons
60 meters beacons
| LX0HF | 5205.3 kHz | ||
| OK1IF | 5258.5 kHz | JO40HG | Inactive. Recording: [1] |
| GB3RAL | 5290.0 kHz | IO91IN | RSGB |
| GB3WES | 5290.0 kHz | IO84QN | RSGB |
| GB3ORK | 5290.0 kHz | IO89JA | RSGB |
| SZ1SV | 5398.5 kHz | KM17UX | Op SV1IW & SV1JG. Inactive. |
30 meters beacons
10 meters beacons
| R1 |
| R2[3] |
| R3 |
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
ON0EME moon beacon
SHF and microwave beacons
Optical and infrared beacons
| Type | Frequencies | Countries | FCC Part 15 rules |
| LowFER | 160-190 kHz | USA, Canada | § 15.217 |
| MedFER | 510 & 1704 kHz (510-1705 kHz) | USA, Canada | § 15.219 |
| BeFER | 6776 kHz | Canada | - |
| HiFER | 13553-13567 kHz | USA, Canada | § 15.225 |
| 49ers | 49846 kHz (49820-49900 kHz) | USA | § 15.235 |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
WSPR Network
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
- Letter beacon
- High Frequency Beacon
Beacon lists
- Aurora Beacon DK0WCY
- ON0EME moon beacon status
