Revision as of 20:20, 7 January 2019 by R4002 (Talk | contribs)
High HF and VHF/UHF Land mobile radio service authorized under Part 90 (Land Mobile Radio Services) of the FCC rules. FCC eligibility verbiage states: Persons primarily engaged in any of the following activities are eligible to hold authorizations in the Industrial/Business Pool to provide commercial mobile radio service as defined in part 20 of this chapter or to operate stations for transmission of communications necessary to such activities of the licensee: (1) The operation commercial of business activity; (2) The operation of educational, philanthropic, or ecclesiastical institutions; (3) Clergy activities; or (4) The operation of hospitals, clinics, or medical associations. The FCC has allocated a massive amount of frequencies for the Business/Industrial Radio Service (commonly referred to as "Business Radio" or "Business Radio Service"). The FCC allows use of frequencies in the 2000 to 25000 kHz (2-25 MHz) band for business purposes, only if frequencies above 25 MHz will not satisfy the requirements of the user, in other words, in special cases only.
27.430 MHz suffers from freeband CB QRM
29.710 MHz
29.710 MHz
35.180 MHz
44.100 MHz
72.080 MHz
72.160 MHz
72.240 MHz
72.320 MHz
72.400 MHz
72.420 MHz
72.440 MHz
72.460 MHz
72.480 MHz
72.500 MHz
72.520 MHz
72.540 MHz
72.560 MHz
72.580 MHz
72.600 MHz
72.620 MHz
72.640 MHz
72.660 MHz
72.680 MHz
72.700 MHz
72.720 MHz
72.740 MHz
72.760 MHz
72.780 MHz
72.800 MHz
72.820 MHz
72.840 MHz
72.860 MHz
72.880 MHz
72.900 MHz
72.920 MHz
72.940 MHz
72.960 MHz
72.980 MHz
75.420 MHz
75.460 MHz
75.500 MHz
75.540 MHz
75.580 MHz
75.620 MHz
75.640 MHz
75.660 MHz
75.680 MHz
75.700 MHz
75.720 MHz
75.740 MHz
75.760 MHz
75.780 MHz
75.800 MHz
75.820 MHz
75.840 MHz
75.860 MHz
75.880 MHz
75.900 MHz
75.920 MHz
75.940 MHz
75.960 MHz
75.980 MHz
152.2625-152.465 MHz 7.5 kHz steps, old Taxicab Radio Service base/repeater output frequencies
154.45625 MHz Operational fixed (SCADA, data links, etc) only
154.46375 MHz Operational fixed (SCADA, data links, etc) only
154.47125 MHz Operational fixed (SCADA, data links, etc) only
154.47875 MHz Operational fixed (SCADA, data links, etc) only
154.505 MHz
154.5275 MHz Mobiles only
154.585 MHz
154.610 MHz
154.625 MHz
154.640 MHz
157.470-157.725 MHz 7.5 kHz steps
160.215-161.610 MHz 7.5 kHz steps, Railroad Use Only
173.20375 MHz Operational fixed (SCADA, data links, etc) only
173.210 MHz Operational fixed (SCADA, data links, etc) only
173.390 MHz Operational fixed (SCADA, data links, etc) only
173.39625 MHz Operational fixed (SCADA, data links, etc) only
