11 meter
Revision as of 16:59, 24 January 2019 by R4002 (Talk | contribs)
27.430 MHz to 27.540 MHz 27410 kHz to 27540 kHz Business/Industrial Radio Service (20 kHz steps, FM mode)
27.540 MHz to 28.000 MHz 27540 kHz to 28000 kHz Government and Fixed/Mobile
11 meter is often used by freebanders or CB operators using the "freeband" frequencies from between 25 MHz and CB channel 1 (26.965 MHz) and CB channel 40 (27.405 MHz) and the bottom edge of the 10 meter amateur band (28.000 MHz). Common freeband frequencies include:
  • 25.615 MHz - 26.055 MHz - Band A - often used by taxi cabs and trucking companies (AM mode in the Americas, AM or FM elsewhere)
  • 26.065 MHz - 26.505 MHz - Band B - often used by taxi cabs, trucking companies and hunting clubs
  • 26.515 MHz - 26.955 MHz - Band C - "low band" or "lowers" all sorts of users, AM in the Americas, mixture of AM and FM elsewhere
  • 26.565 MHz - 26.955 MHz - German CB channels 41-80, FM mode only, heavily used in Europe
  • 26.965 MHz - 27.405 MHz - Band D - legal CB band - "mid band", "FCC band" or "CEPT" band
  • 27.315 MHz AM - CB channel 31 - AM DX calling channel, used for DXing in FM mode in Europe and UK
  • 27.405 MHz - 27.855 MHz - Band E - "high band" or "uppers", mixture of SSB, AM and FM
  • 27.60125 MHz - 27.99125 MHz - UK FM 27/81 CB (UK only) also CADS/WPAS Channels LW01-LW40 UK, Ireland (AM/FM modes, Church broadcasts) straight 10 kHz channel steps
  • 27.605 MHz - 27.995 MHz - CADS/WPAS Channels UW01-UW40 UK, Ireland and elsewhere straight 10 kHz channel steps
  • 27.635 MHz AM - CB channel 19 "up one band" - truckers are often heard here (see also 26.735 MHz)
  • 27.855 MHz - 28.305 MHz - Band F - up to 27.995 MHz (channel 11A) popular with taxicabs and truckers, although truckers are often heard above 28.000 MHz it is strongly advised that freebanders stay below 28 MHz
Legal CB Frequencies and Bands
While this information is duplicated on the CB page, the Remote Control and 11 meter datalink and paging pages - this list provides it in order of frequency.
  • 26.330 MHz - New Zealand CB Channel 1
  • 26.340 MHz - New Zealand CB Channel 2
  • 26.350 MHz - New Zealand CB Channel 3
  • 26.370 MHz - New Zealand CB Channel 4
  • 26.380 MHz - New Zealand CB Channel 5
  • 26.390 MHz - New Zealand CB Channel 6
  • 26.400 MHz - New Zealand CB Channel 7
  • 26.420 MHz - New Zealand CB Channel 8
  • 26.430 MHz - New Zealand CB Channel 9
  • 26.440 MHz - New Zealand CB Channel 10
  • 26.450 MHz - New Zealand CB Channel 11
  • 26.470 MHz - New Zealand CB Channel 12
  • 26.480 MHz - New Zealand CB Channel 13
  • 26.490 MHz - New Zealand CB Channel 14
  • 26.500 MHz - New Zealand CB Channel 15
  • 26.520 MHz - New Zealand CB Channel 16
  • 26.530 MHz - New Zealand CB Channel 17
  • 26.540 MHz - New Zealand CB Channel 18
  • 26.550 MHz - New Zealand CB Channel 19
  • 26.565 MHz - German CB Channel 41
  • 26.570 MHz - New Zealand CB Channel 20
  • 26.575 MHz - German CB Channel 42
  • 26.580 MHz - New Zealand CB Channel 21
  • 26.585 MHz - German CB Channel 43
  • 26.590 MHz - New Zealand CB Channel 22
  • 26.595 MHz - German CB Channel 44
  • 26.600 MHz - New Zealand CB Channel 24
  • 26.605 MHz - German CB Channel 45
  • 26.610 MHz - New Zealand CB Channel 25
  • 26.615 MHz - German CB Channel 46
  • 26.620 MHz - New Zealand CB Channel 23
  • 26.625 MHz - German CB Channel 47
  • 26.630 MHz - New Zealand CB Channel 26
  • 26.635 MHz - German CB Channel 48
  • 26.640 MHz - New Zealand CB Channel 27
  • 26.645 MHz - German CB Channel 49
  • 26.650 MHz - New Zealand CB Channel 28
  • 26.655 MHz - German CB Channel 50
  • 26.660 MHz - New Zealand CB Channel 29
  • 26.665 MHz - German CB Channel 51
  • 26.670 MHz - New Zealand CB Channel 30
  • 26.675 MHz - German CB Channel 52
  • 26.680 MHz - New Zealand CB Channel 31
  • 26.685 MHz - German CB Channel 53
  • 26.690 MHz - New Zealand CB Channel 32
  • 26.695 MHz - German CB Channel 54
  • 26.700 MHz - New Zealand CB Channel 33
  • 26.705 MHz - German CB Channel 55
  • 26.710 MHz - New Zealand CB Channel 34
  • 26.715 MHz - German CB Channel 56
  • 26.720 MHz - New Zealand CB Channel 35
  • 26.725 MHz - German CB Channel 57
  • 26.730 MHz - New Zealand CB Channel 36
  • 26.735 MHz - German CB Channel 58
  • 26.740 MHz - New Zealand CB Channel 37
  • 26.745 MHz - German CB Channel 59
  • 26.750 MHz - New Zealand CB Channel 38
  • 26.755 MHz - German CB Channel 60
  • 26.760 MHz - New Zealand CB Channel 39
  • 26.765 MHz - German CB Channel 61
  • 26.770 MHz - New Zealand CB Channel 40
  • 26.775 MHz - German CB Channel 62
  • 26.785 MHz - German CB Channel 63
  • 26.795 MHz - German CB Channel 64
  • 26.805 MHz - German CB Channel 65
  • 26.815 MHz - German CB Channel 66
  • 26.825 MHz - German CB Channel 67
  • 26.835 MHz - German CB Channel 68
  • 26.845 MHz - German CB Channel 69
  • 26.855 MHz - German CB Channel 70
  • 26.865 MHz - German CB Channel 71
  • 26.875 MHz - German CB Channel 72
  • 26.885 MHz - German CB Channel 73
  • 26.895 MHz - German CB Channel 74
  • 26.905 MHz - German CB Channel 75
  • 26.915 MHz - German CB Channel 76
  • 26.925 MHz - German CB Channel 77
  • 26.935 MHz - German CB Channel 78
  • 26.945 MHz - German CB Channel 79
  • 26.955 MHz - German CB Channel 80
  • 26.965 MHz - Standard CB Band Channel 1
  • 26.975 MHz - Standard CB Band Channel 2
  • 26.985 MHz - Standard CB Band Channel 3
  • 26.995 MHz - Standard R/C Frequency "Channel 3A" or Brown
  • 27.005 MHz - Standard CB Band Channel 4
  • 27.015 MHz - Standard CB Band Channel 5
  • 27.025 MHz - Standard CB Band Channel 6
  • 27.035 MHz - Standard CB Band Channel 7
  • 27.045 MHz - Standard R/C Frequency "Channel 7A" or Red
  • 27.055 MHz - Standard CB Band Channel 8
  • 27.065 MHz - Standard CB Band Channel 9
  • 27.075 MHz - Standard CB Band Channel 10
  • 27.085 MHz - Standard CB Band Channel 11
  • 27.095 MHz - Standard R/C Frequency "Channel 11A" or Orange
  • 27.105 MHz - Standard CB Band Channel 12
  • 27.115 MHz - Standard CB Band Channel 13
  • 27.125 MHz - Standard CB Band Channel 14
  • 27.135 MHz - Standard CB Band Channel 15
  • 27.145 MHz - Standard R/C Frequency "Channel 15A" or Yellow
  • 27.155 MHz - Standard CB Band Channel 16
  • 27.165 MHz - Standard CB Band Channel 17
  • 27.175 MHz - Standard CB Band Channel 18
  • 27.185 MHz - Standard CB Band Channel 19
  • 27.195 MHz - Standard R/C Frequency "Channel 15A" or Green
  • 27.205 MHz - Standard CB Band Channel 20
  • 27.215 MHz - Standard CB Band Channel 21
  • 27.225 MHz - Standard CB Band Channel 22
  • 27.235 MHz - Standard CB Band Channel 24
  • 27.245 MHz - Standard CB Band Channel 25
  • 27.255 MHz - Standard CB Band Channel 23 shared with R/C - Blue
  • 27.265 MHz - Standard CB Band Channel 26
  • 27.275 MHz - Standard CB Band Channel 27
  • 27.285 MHz - Standard CB Band Channel 28
  • 27.295 MHz - Standard CB Band Channel 29
  • 27.305 MHz - Standard CB Band Channel 30
  • 27.315 MHz - Standard CB Band Channel 31
  • 27.325 MHz - Standard CB Band Channel 32
  • 27.335 MHz - Standard CB Band Channel 33
  • 27.345 MHz - Standard CB Band Channel 34
  • 27.355 MHz - Standard CB Band Channel 35
  • 27.365 MHz - Standard CB Band Channel 36
  • 27.375 MHz - Standard CB Band Channel 37
  • 27.385 MHz - Standard CB Band Channel 38
  • 27.395 MHz - Standard CB Band Channel 39
  • 27.405 MHz - Standard CB Band Channel 40
  • 27.415 MHz - Brazilian CB Band Channel 41
  • 27.425 MHz - Brazilian CB Band Channel 42
  • 27.435 MHz - Brazilian CB Band Channel 43
  • 27.445 MHz - Brazilian CB Band Channel 43A or 44
  • 27.455 MHz - Brazilian CB Band Channel 45
  • 27.680 MHz - Australian 27 MHz marine band CH 68
  • 27.720 MHz - Australian 27 MHz marine band CH 72
  • 27.820 MHz - Australian 27 MHz marine band CH 82
  • 27.860 MHz - Australian 27 MHz marine band CH 86
  • 27.880 MHz - Australian 27 MHz marine band CH 88
  • 27.900 MHz - Australian 27 MHz marine band CH 90
  • 27.910 MHz - Australian 27 MHz marine band CH 91
  • 27.940 MHz - Australian 27 MHz marine band CH 94
  • 27.960 MHz - Australian 27 MHz marine band CH 96
  • 27.980 MHz - Australian 27 MHz marine band CH 98
