MURS
Revision as of 19:37, 18 March 2019 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS, VHF CB, also rendered as "Multi-Use Radio Service" - not to be confused with similar services such as FRS/GMRS, regular old 26-27 MHz CB, VHF marine or licensed land mobile (business radio) services.
MURS Frequencies / Channels:
MURS Channel Identifier Frequency Maximum Bandwidth
MURS Channel 1 MURS-1 151.820 MHz 11.25 kHz (any mode - narrowband)
MURS Channel 2 MURS-2 151.880 MHz 11.25 kHz (any mode - narrowband)
MURS Channel 3 MURS-3 151.940 MHz 11.25 kHz (any mode - narrowband)
MURS Channel 4 Blue Dot MURS-4 154.570 MHz 20.00 kHz (any mode - wideband)
MURS Channel 5 Green Dot MURS-5 154.600 MHz 20.00 kHz (any mode - wideband)
Repeaters are not allowed on the MURS frequencies per FCC rules. This includes duplex and simplex repeaters, also known as "store-and-forward" repeaters. This rule is apparently often ignored by MURS users as evidenced by the existence of simplex repeaters operating on the MURS frequencies as well as cross-band repeater setups using MURS (on VHF) and FRS/GMRS channels (on UHF). There are several reports on various radio hobbyist Internet forums of MURS repeaters including wide-area simplex repeaters located on mountaintops or MURS simplex repeaters with antennas located on high-rise buildings in urban areas.
CB networks on MURS, high power, militia groups, MURS repeaters, ham operators and other fun
Some CB and ham radio operators also use the MURS frequencies due to favorable propagation characteristics, often with high power. This is against the FCC regulations but is widespread in certain areas due to the availability of open-band VHF/UHF radios, easily modified ham radio equipment that can transmit on the MURS frequencies and the adoption of the MURS frequencies by militia and prepper groups. MURS-based VHF systems range from simple handheld radios programmed with the MURS and FRS frequencies (for example, the Baofeng UV-5R and UV-82 series) to high powered mobile and base station simplex networks to simplex and duplex repeater networks. There are reports of cross-band repeaters using the FRS frequencies and MURS, in addition to high powered MURS simplex repeaters located on mountaintops or tall buildings in urban areas. See also: CB repeaters.
  • 151.8200 MHz 118.8 Hz CTCSS/PL - crossband with GMRS channel 22 462.725 118.8 Hz CTCSS/PL (New Jersey)
  • 151.8800 MHz 167.9 Hz CTCSS/PL - somewhere in Northwest Virginia (on top of a mountain, wide area coverage)
  • 151.8800 MHz 156.7 Hz CTCSS/PL
  • 151.9400 MHz 100.0 Hz CTCSS/PL
  • 154.5700 MHz 156.7 Hz CTCSS/PL - Orange County, New York
It is recommended that MURS simplex repeater and cross-band repeater users use 156.7 Hz or 167.9 Hz as these CTCSS tones are used for interoperability and emergency purposes. Use of default tone 67.0 Hz is not recommended. MURS simplex repeater and MURS GMRS FRS crossband repeater operators should monitor frequency usage in their area to ensure they do not select a PL or DPL (CTCSS or DCS) tone that is used by another MURS, GMRS or FRS user as this would cause heavy interference issues and attract FCC attention.
In other words, don't use carrier squelch, 67.0 Hz CTCSS, 023 DCS/DPL and don't use FRS channel 1 as a crossband frequency
Emergency preparedness radio and communications guides, including the interoperability guide, recommend programming the MURS and FRS frequencies into radios for compatibility with these systems.
There is an effort to standardize the use of "channel 3" as a general "prepper" or emergency preparedness "calling" channel across the three Part 95 services, MURS, CB and FRS (MURS channel 3 - 151.94 MHz, CB channel 3 - 26.985 MHz and FRS channel 3 - 462.6125 MHz) in conjunction with HF/VHF/UHF amateur frequencies.
