Radio propagation beacon
Revision as of 14:14, 21 January 2023 by R4002 (Talk | contribs)
DK0WCY & DRA5 beacons
History
Transmission characteristics
160 meters beacons
60 meters beacons
DRA5 5195.0 kHz JO44VQ DARC
LX0HF 5205.2 kHz JN39dr Radioamateurs du Luxembourg [1]
HG7BHB 5252.3 kHz JN97LE
OK1IF 5258.5 kHz JO40HG Inactive. Recording: [2]
OV1BCN 5290.5 kHz JO55SI Op OZ1FJB [3]
HB9AW 5291.0 kHz JN47BE [4]
30 meters beacons
10 meters beacons
R1
  • 28199-28201 WW Time Shared
  • 28201-28225 Continuous Duty
R2[3]
  • 28199-28201 IBP/NCDXF
  • 28225-28300 Shared
R3
  • 28190-28200 IBP
40 MHz beacons
  • The first radio propagation beacon on 40 MHz is OZ7IGY in Jystrup, Denmark (JO55WM) and transmits on 40071 kHz 40021 kHz (40.071 MHz). Transmitted power is 20 W to a dipole antenna. The beacon is frequency- and time-locked to GPS. The sequence is programmed to send PI4 , followed by a short pause, and then the call sign and grid locator sent in CW, then a pause, and a carrier until start of the next cycle. PI4 is a digital mode specifically designed for beacons and propagation studies, similar to JT4 and WSPR. To decode PI4, tune 800 Hz below the nominal frequency.
  • The Radio Society of Great Britain has a license for beacon transmissions from GB3RAL (Didcot, UK) on 40050 & 60050 kHz (40.050 MHz & 60.050 MHz - 8 meters and 5 meters).
  • While not a beacon by design, the US Government's SNOTEL telemetry system operates more than 600 transmitters (mostly in the Rocky Mountain and Western United States regions) on 40670 kHz (40.670 MHz, 40.67 MHz). During sporadic-E band openings, data bursts from the SNOTEL system can be heard on 40.67 MHz.
  • The Canadian military base Shuffield (CYSD) in Alberta operates a FM mode military VHF FM radio beacon transmitting a Morse code ID YSD followed by a tone burst on 36.6 FM (36600 kHz FM, 36.600 MHz FM, 36.60 FM, 36.6 MHz).
6 meters (50 MHz) beacons
The new IARU Region 1 bandplan moves 50 MHz beacons, with the exception of beacons participating to the Synchronized Beacon Project, in a new allocation, 50400 to 50500 kHz.
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
Band Beacon Sub-band (MHz)
IARU R1 IARU R2 IARU R3
33 cm N/A Varies Locally N/A
Band Beacon allocation (kHz)
4 m 70,000-70,030
2 m 144,400-144,490
70 cm 432,800-432,990
23 cm 1296,800-1296,990
ON0EME moon beacon
144 MHz transatlantic beacons
CU2VHF HM77DT 144401
CU8DUB HM49KL 144420
D4C/B HK76MV 144436 750 m ASL, 20W CW. Copied by Dave Pedersen, PJ4VHF/N7BHC, on Bonaire Island on May 6, 2015 [5]
ED8ZAA/B IL18 144484
NP2X/B FK77PR 144291 St. Croix, US Virgin Islands - 240 feet AMSL (73 meters AMSL) - RF Concepts 160 watt, reduced to 100 watts for beacon operation - 15 element yagi @ beam heading of 55 degrees (Portgual) - np2xbeacon@gmail.com
VE1SMU/H 144.288
VO1ZA GN37JS 144400 Inactive
Indian Ocean beacon project
SHF and microwave beacons
Optical and infrared beacons
Main articles: LowFER, HiFER.
MedFER 510 & 1704 kHz
(510-1705 kHz)
USA, Canada § 15.219
BeFER 6776 kHz Canada -
49ers 49846 kHz
(49820-49900 kHz)
USA § 15.235
Beacon projects
NCDXF-IARU beacon setup
IARU/NCDXF HF Beacon Project
url="http://www.darc.de"
ITU sponsored beacons
Radio Beacon LN2A
14395 00 - 20 - 40
20945 04 - 24 - 44
5470 08 - 28 - 48
7870 12 - 32 - 52
10407 16 - 36 - 56
The contact address is:
P O Box 447 Sentrum
N-0104 Oslo
Norway
Radio Beacon VL8IPS
5470 00 - 20 - 40
7870 04 - 24 - 44
10407 08 - 28 - 48
14395 12 - 32 - 52
20945 16 - 36 - 56
  • Reception reports could be sent beacon@ips.gov.au
DARC beacon project
RSGB 5 MHz beacon project
U.S. Navy beacons
WSPR Network
IARU Region Beacon frequencies (kHz)
R1 50000, 50001, 50002, 50003, 50004, 50005, 50006, 50007, 50008, 50009
R2 50010, 50011, 50012, 50013, 50014, 50015, 50016, 50017, 50018, 50019
R3 50020, 50021, 50022, 50023, 50024, 50025, 50026, 50027, 50028, 50029
Frequency (kHz) TS0 TS1 TS2 TS3 TS4
50005 EI0SIX GB3MCB PI7SIX GB3MCB OZ4BHM
50006 IW9GDC/B IW9GDC/B GB3NGI IW9GDC/B GB3NGI
Notes and references
  6. HF 0-20 MHz beacons
Beacon lists
Currently there is one regularly updated international beacon list, compiled by Dennis, ZS4BS, and is available on-line. An additional online list by WJ5O contains only 28 MHz (10 meter) beacons.
IK0WRB beacon keyer schematic
WP
