Dead Hand System
Revision as of 14:16, 25 July 2019 by The Wrigley Guerrilla (Talk | contribs)
The Duga Radar array in Chernobyl, claimed by some to be a Perimeter System radar
A S-400 Triumf surface-to-air missile launcher, one of the theorized launchers for the Perimeter System
System concept
Working principles
Upon activation and determination of the happening of a nuclear war, the system sends out a 15P011 command missile with a special 15B99 warhead which passes commands to open all silos and all command centers of the RVSN with appropriate receivers in flight. The command missile system is similar with the US Emergency Rocket Communications System. An alternate theory involves the usage of converted surface-to-air missile launchers, including the S-400 Triumf/SA-21 Growler. The missile, using the advantages of a high-velocity rocket, could fly over dozens of silos and command centers while transmitting commands.
Components
Commanding rocket system:
Converted missile systems:
Some analysts claim that the system is connected to several surface-to-air missile batteries converted to be used by Dead Hand, ranging from the aging SA-1 all the way to the newest SA-21 missile launchers.
Motivation
Operation
Current use
UVB-76 (The Buzzer)
Sources
All sources courtesy of Wikipedia, Military Today, Media Commons, Wikimedia, and the New York Times archive
