MURS
Revision as of 14:06, 25 August 2019 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS Frequencies / Channels:
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power, 2w transmitter, around 5w ERP - located in downtown Richmond, VA)
  • The Mount Jackson, VA MURS simplex repeater has 50+ mile coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of eastern West Virginia. Confirmed active August 2019.
  • The Richmond, VA MURS simplex repeater has considerably less coverage due to its low power transmitter and location in an urban area. Coverage is reliable in downtown Richmond and other areas of the city. Both of these MURS repeaters use MURS ch 2 - 151.880 MHz and CTCSS / PL tone 156.7 Hz for transmit and receive. The Richmond MURS repeater is off-grid power (solar powered with battery backup) to help support emergency communications. Confirmed
active August 2019.
