PMR446
| Channel | Freq MHz |
| 1 | 446.00625 |
| 2 | 446.01875 |
| 3 | 446.03125 |
| 4 | 446.04375 |
| 5 | 446.05625 |
| 6 | 446.06875 |
| 7 | 446.08125 |
| 8 | 446.09375 |
| 9 | 446.10625 |
| 10 | 446.11875 |
| 11 | 446.13125 |
| 12 | 446.14375 |
| 13 | 446.15625 |
| 14 | 446.16875 |
| 15 | 446.18125 |
| 16 | 446.19375 |
Digital FDMA
Digital dPMR446 uses 32 digital voice channels separated by 6.25 kHz from each other with 4-level FSK modulation at 3.6 kbit/s. These frequencies overlap the original 16 analog voice/digital voice frequencies and operate in the same 446.0 to 446.2 MHz frequency range of the original PMR446 service. Kenwood designates the 6.25 kHz PMR446 digital band as DPMR446 or Digital DPMR446, not to be confused with digital DMR Tier 1 (which operates on the 12.5 kHz "wideband" channels, same frequencies as the analog channels).
| 1 | 446.003125 |
| 2 | 446.009375 |
| 3 | 446.015625 |
| 4 | 446.021875 |
| 5 | 446.028125 |
| 6 | 446.034375 |
| 7 | 446.040625 |
| 8 | 446.046875 |
| 9 | 446.053125 |
| 10 | 446.059375 |
| 11 | 446.065625 |
| 12 | 446.071875 |
| 13 | 446.078125 |
| 14 | 446.084375 |
| 15 | 446.090625 |
| 16 | 446.096875 |
| 17 | 446.103125 |
| 18 | 446.109375 |
| 19 | 446.115625 |
| 20 | 446.121875 |
| 21 | 446.128125 |
| 22 | 446.134375 |
| 23 | 446.140625 |
| 24 | 446.146875 |
| 25 | 446.153125 |
| 26 | 446.159375 |
| 27 | 446.165625 |
| 28 | 446.171875 |
| 29 | 446.178125 |
| 30 | 446.184375 |
| 31 | 446.190625 |
| 32 | 446.196875 |
Authorized PMR446 Countries
- 446.006250 MHz - Analog FM or wide band digital channel 1
- 446.015625 MHz -
- 446.018750 MHz - Analog FM or wide band digital channel 2
- 446.021875 MHz -
- 446.028125 MHz -
- 446.031250 MHz - Analog FM or wide band digital channel 3
- 446.034375 MHz -
- 446.040625 MHz -
- 446.043750 MHz - Analog FM or wide band digital channel 4
- 446.046875 MHz -
- 446.053125 MHz -
- 446.056250 MHz - Analog FM or wide band digital channel 5
- 446.059375 MHz -
- 446.065625 MHz -
- 446.068750 MHz - Analog FM or wide band digital channel 6
- 446.071875 MHz -
- 446.078125 MHz -
- 446.081250 MHz - Analog FM or wide band digital channel 7
- 446.084375 MHz -
- 446.090625 MHz -
- 446.093750 MHz - Analog FM or wide band digital channel 8
- 446.096875 MHz -
- 446.103125 MHz -
- 446.106250 MHz - Analog FM or wide band digital channel 9
- 446.109375 MHz -
- 446.115625 MHz -
- 446.118750 MHz - Analog FM or wide band digital channel 10
- 446.121875 MHz -
- 446.128125 MHz -
- 446.131250 MHz - Analog FM or wide band digital channel 11
- 446.134375 MHz -
- 446.140625 MHz -
- 446.143750 MHz - Analog FM or wide band digital channel 12
- 446.146875 MHz -
- 446.153125 MHz -
- 446.156250 MHz - Analog FM or wide band digital channel 13
- 446.159375 MHz -
- 446.165625 MHz -
- 446.168750 MHz - Analog FM or wide band digital channel 14
- 446.171875 MHz -
- 446.178125 MHz -
- 446.181250 MHz - Analog FM or wide band digital channel 15
- 446.184375 MHz -
- 446.190625 MHz -
- 446.193750 MHz - Analog FM or wide band digital channel 16
- 446.196875 MHz -
