MURS
Revision as of 14:05, 28 July 2020 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS Frequencies / Channels:
Motorola RDM2070D VHF MURS
Motorola RDM2020 VHF MURS
Motorola RDM2080D VHF MURS
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area - 151.880 MHz 156.7 PL
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power - located in downtown Richmond, VA) - 151.880 MHz 156.7 PL
  • The Mount Jackson, VA MURS simplex repeater - Confirmed active May 2020 - has 50+ mile radius coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of West Virginia and western Maryland. Very large footprint.
  • The Richmond, VA MURS simplex repeater - Temporarily off the air as of 27 July 2020 - has considerably less coverage due to its low power transmitter and location in an urban area. Antenna is located on top of a low-rise building, ERP is approx. 4-6 watts. 156.7 Hz tone required to open repeater - repeater equipment switched to FRS channel 7 462.7125 MHz [156.7 Hz CTCSS tone].
  • 151.8200 MHz - Militia/Patriot MURS VHF MURS 1 - Tactical and Calling
  • 151.8800 MHz - Militia/Patriot MURS VHF MURS 2 - Sovereign Citizen Freeman Primary Patriot Radio Channel
  • 151.9400 MHz - Militia/Patriot MURS VHF Patriot Nationwide Primary MURS 3 (see also: FRS 3 and CB 3)
  • 154.5700 MHz - Militia/Patriot MURS VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel
Alternate VHF militia plans:
  • 151.8200 MHz - MURS1 - CALLING / TACTICAL MURS Ch 1
  • 151.8800 MHz - MURS2 - SOVEREIGN CITIZEN FREEMEN MURS Ch 2
  • 151.9400 MHz - MURS3 - PATRIOT NATIONWIDE PRIMARY MURS Ch 3
  • 154.5700 MHz - MURS4 - PATRIOT REGIONAL SECONDARY MURS Ch 4
  • 154.6000 MHz - MURS5 - MURS Ch 5
  • 151.7000 MHz - BIZ 5
  • 151.7600 MHz
  • 152.9450 MHz
  • 151.8350 MHz
  • 151.8050 MHz
  • 151.5125 MHz
  • 151.6550 MHz - BIZ 11 - BUSINESS 11 / FREEBAND / PATRIOT / MILTIIA
  • 151.6850 MHz
  • 151.7150 MHz
  • 151.7450 MHz
  • 151.7750 MHz
  • 151.8650 MHz
  • 152.7000 MHz - BIZ 18
  • 154.4900 MHz
  • 154.5150 MHz
  • 154.5275 MHz
  • 154.5400 MHz
  • 153.0050 MHz
  • 154.6650 MHz
  • 158.4000 MHz
  • 158.4075 MHz
  • 146.4850 MHz - HAMV48 - 2 meter amateur radio ham channel 146.485 MHz Patriot/Militia
  • 151.880 MHz - MURS 2
  • 154.570 MHz - MURS 4
  • 154.600 MHz - MURS 5
  • 151.655 MHz - VHF Business
  • 151.685 MHz - VHF Business
  • 151.715 MHz - VHF Business
  • 151.745 MHz - VHF Business
  • 151.775 MHz - VHF Business
  • 151.805 MHz - VHF Business
  • 151.835 MHz - VHF Business
  • 151.865 MHz - VHF Business
  • 151.895 MHz - VHF Business
  • 151.925 MHz - VHF Business
  • 151.955 MHz - VHF Business
  • 152.870 MHz - VHF Business
  • 152.885 MHz - VHF Business
  • 152.900 MHz - VHF Business
  • 152.915 MHz - VHF Business
  • 152.930 MHz - VHF Business
  • 152.945 MHz - VHF Business
  • 152.960 MHz - VHF Business
  • 152.975 MHz - VHF Business
  • 152.990 MHz - VHF Business
  • 153.005 MHz - VHF Business
  • 154.4825 MHz - VHF Business (narrowband)
  • 154.490 MHz - VHF Business
  • 154.4975 MHz - VHF Business (narrowband)
  • 154.505 MHz - VHF Business (narrowband)
  • 154.515 MHz - VHF Business (narrowband)
  • 154.5275 MHz - VHF Business Itinerant (narrowband)
  • 154.540 MHz - VHF Business
  • 154.5475 MHz - VHF Business
  • 154.555 MHz - VHF Business (narrowband)
  • 154.625 MHz - VHF Business (narrowband)
  • 154.655 MHz - VHF Business (narrowband)
  • 158.4075 MHz - VHF Business Itinerant (narrowband)
