Militia Radio Frequencies
Revision as of 16:29, 29 November 2020 by R4002 (Talk | contribs)
Transmit CTCSS tones are recommended, but not required. Receive must be set for carrier squelch (no receive CTCSS or PL tone). Users may simply turn all tones off (no transmit tone or receive tone) if they prefer. Transmit tones are recommended to facilitate interoperability with commonly used tones and default radio channel/tone settings. For example, the Baofeng BF-888S series radios use 127.3 Hz CTCSS on 462.625 MHz (BF-888S channel 6, FRS channel 18) and 136.5 Hz CTCSS on 462.725 MHz (BF-888S channel 7, FRS channel 22). The Retevis FRS handheld radios use the CTCSS tones indicated for FRS channels 1-7, 15, 18 and 22. For more information on default factory out of the box Baofeng Retevis etc. CTCSS tone settings and frequencies/channel plans, see this page.
  • Channel 002 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 2
  • Channel 003 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 3
  • Channel 004 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 4
  • Channel 005 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 5
  • Channel 006 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 6
  • Channel 007 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 7
  • Channel 015 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 15
  • Channel 042 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 2 CALL - high power setting
  • Channel 102 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 2 HP - high power setting
  • Channel 103 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 3 HP - high power setting
  • Channel 104 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 4 HP - high power setting
  • Channel 105 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 5 HP - high power setting
  • Channel 106 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 6 HP - high power setting
  • Channel 107 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 7 HP - high power setting
  • Channel 115 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 15 HP - high power setting
