Militia Radio Frequencies
Revision as of 03:42, 15 January 2021 by R4002 (Talk | contribs)
May be hand programmed - field programming militia tactical radio frequencies. R-CTCS: OFF, T-CTCS: [see transmit tones listed below...remember to leave the receive in CSQ carrier squelch mode. R-DCS and T-DCS should both be set to OFF. TXP: HIGH - high power. ROGER: OFF. VOICE: OFF. WN: NARR (narrow). Recommend transmit CTCSS (T-CTCS) tone 67.0 Hz for FRS channel 1 (462.5625 MHz) and 141.3 Hz for FRS channel 20 (462.6750 MHz). Transmit CTCSS tone 88.5 Hz or 77.0 Hz recommended for all other channels.
  • Channel 1 - 462.5625 MHz - FRS Channel 1 - FRS Nationwide Calling
  • Channel 2 - 462.5875 MHz - FRS Channel 2 - Patriot Militia Tactical - Neighborhood Watch Channel
  • Channel 3 - 462.6125 MHz - FRS Channel 3 - Patriot Calling/Standby :00 :15 :30 and :45 for 3 minutes - see also: CB channel 3, MURS channel 3
  • Channel 4 - 462.6375 MHz - FRS Channel 4 - Convoy Channel, Tactical Tac Ops (see also, FRS channel 16)
  • Channel 8 - 467.5625 MHz - FRS Channel 8
  • Channel 9 - 467.5875 MHz
  • Channel 10 - 467.6125 MHz -
  • Channel 11 - 467.6375 MHz -
  • Channel 12 - 467.6625 MHz -
  • Channel 13 - 467.6875 MHz -
  • Channel 14 - 467.7125 MHz -
  • Channel 15 - 462.5500 MHz -
  • Channel 16 - 462.5750 MHz -
  • Channel 17 - 462.6000 MHz -
  • Channel 18 - 462.6250 MHz
  • Channel 19 - 462.6500 MHz
  • Channel 20 - 462.6750 MHz -
  • Channel 21 - 462.7000 MHz
  • Channel 22 - 462.7250 MHz -
Transmit CTCSS tones are recommended, but not required. Receive must be set for carrier squelch (no receive CTCSS or PL tone). Users may simply turn all tones off (no transmit tone or receive tone) if they prefer. Transmit tones are recommended to facilitate interoperability with commonly used tones and default radio channel/tone settings. For example, the Baofeng BF-888S series radios use 127.3 Hz CTCSS on 462.625 MHz (BF-888S channel 6, FRS channel 18) and 136.5 Hz CTCSS on 462.725 MHz (BF-888S channel 7, FRS channel 22). The Retevis FRS handheld radios use the CTCSS tones indicated for FRS channels 1-7, 15, 18 and 22. For more information on default factory out of the box Baofeng Retevis etc. CTCSS tone settings and frequencies/channel plans, see this page.
Handheld Radio VHF UHF FRS GMRS MURS Militia Channels
  • Channel 002 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 2
  • Channel 003 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 3
  • Channel 004 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 4
  • Channel 005 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 5
  • Channel 006 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 6
  • Channel 007 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 7
  • Channel 015 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 15
  • Channel 042 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 2 CALL - high power setting
  • Channel 102 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 2 HP - high power setting
  • Channel 103 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 3 HP - high power setting
  • Channel 104 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 4 HP - high power setting
  • Channel 105 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 5 HP - high power setting
  • Channel 106 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 6 HP - high power setting
  • Channel 107 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 7 HP - high power setting
  • Channel 115 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 15 HP - high power setting
