Militia Radio Frequencies
Revision as of 23:46, 5 February 2021 by R4002 (Talk | contribs)
  • Channel 9 - 467.5875 MHz - FRS 9 - Mutual Aid, Tac
  • Channel 13 - 467.6875 MHz - FRS 13 - Mutual Aid, Tac
  • Channel 32 - 151.8800 MHz - MURS 2 - Command
  • Channel 33 - 151.9400 MHz - MURS 3 - Primary Patriot Militia Calling
  • Channel 34 - 154.5700 MHz - MURS 4 - Command
  • Channel 35 - 154.6000 MHz - MURS 5 - Command
T-CTCS (transmit tone) recommendations below. ALWAYS LEAVE RECEIVER SQUELCH OPEN (CSQ). On CHIRP it's Tone, not TSQL. When programming a radio manually, R-CTCS should be set to OFF. T-DCS set to OFF and R-DCS set to OFF.
  • FRS 1 - 67.0 Hz
  • FRS 2 - 71.9 Hz or 118.8 Hz
  • FRS 3 - 74.4 Hz, 88.5 Hz or 127.3 Hz.
  • FRS 4 - 131.8 Hz
  • FRS 5 - 136.5 Hz, 79.7 Hz, or 88.5 Hz
  • FRS 6 - 141.3 Hz
  • FRS 7 - 146.2 Hz
  • FRS 8 - 88.5 Hz
  • FRS 9 - 88.5 Hz, 97.4 Hz, or 127.3 Hz
  • FRS 10 - 77.0 Hz or 88.5 Hz
  • FRS 11 - 88.5 Hz
  • FRS 12 - 88.5 Hz
  • FRS 13 - 88.5 Hz
  • FRS 14 - 88.5 Hz or 107.2 Hz
  • FRS 15 - 71.9 Hz, 110.9 Hz, 123.0 Hz or 141.3 Hz
  • FRS 16 - 141.3 Hz
  • FRS 17 - 141.3 Hz
  • FRS 18 - 127.3 Hz
  • FRS 19 - 127.3 Hz or 141.3 Hz
  • FRS 20 - 141.3 Hz strongly recommended
  • FRS 21 - 141.3 Hz
  • FRS 22 - 136.5 Hz
  • MURS 1 - 88.5 Hz
  • MURS 2 - 88.5 Hz
  • MURS 3 - 88.5 Hz
  • MURS 4 - 88.5 Hz
  • MURS 5 - 88.5 Hz
Inexpensive 16-channel UHF 400-480 MHz 400-470 MHz 450-470 MHz 16 channel handheld radios such as the BF-888S family (BF-666S, BF-9700, Retevis, etc.) may be used in addition to 128-channel VHF/UHF radios for short range inter squad radio tactical purposes.
Recommend low power setting and, if used as intra squad radios only, CTCSS (PL) or DCS (DPL) - TSQL or DCS on Baofeng radios. Set mode to NFM (narrow FM).
  • Channel 01 - 467.6375 MHz - 165.5 Hz CTCSS TSQL
  • Channel 02 - 467.6875 MHz - 177.3 Hz CTCSS TSQL
  • Channel 03 - 467.5875 MHz - 196.6 Hz CTCSS TSQL
  • Channel 04 - 467.7125 MHz - 233.6 Hz CTCSS TSQL
  • Channel 05 - 467.6625 MHz
  • Channel 06 - 467.5625 MHz
  • Channel 07 - 467.6125
  • Channel 08 - 462.7000
  • Channel 09 - 462.5750
  • Channel 10 - 462.6000
  • Channel 11 - 462.6500
  • Channel 12 - 462.6875 MHz
  • Channel 13 - 462.7000
