Militia Radio Frequencies
Revision as of 23:14, 11 February 2021 by R4002 (Talk | contribs)
  • Channel 9 - 467.5875 MHz - FRS 9 - Mutual Aid, Tac
  • Channel 13 - 467.6875 MHz - FRS 13 - Mutual Aid, Tac
  • Channel 32 - 151.8800 MHz - MURS 2 - Command
  • Channel 33 - 151.9400 MHz - MURS 3 - Primary Patriot Militia Calling
  • Channel 34 - 154.5700 MHz - MURS 4 - Command
  • Channel 35 - 154.6000 MHz - MURS 5 - Command
T-CTCS (transmit tone) recommendations below. ALWAYS LEAVE RECEIVER SQUELCH OPEN (CSQ). On CHIRP it's Tone, not TSQL. When programming a radio manually, R-CTCS should be set to OFF. T-DCS set to OFF and R-DCS set to OFF.
  • MURS 1 - 151.8200 MHz - 88.5 Hz
  • MURS 2 - 151.8800 MHz - 88.5 Hz
  • MURS 3 - 151.9400 MHz - 88.5 Hz
  • MURS 4 - 154.5700 MHz - 88.5 Hz
  • MURS 5 - 154.6000 MHz - 88.5 Hz
  • Channel 01 - 467.6375 MHz
  • Channel 02 - 467.6625 MHz
  • Channel 03 - 467.6875 MHz
  • Channel 04 - 467.7125 MHz
  • Channel 05 - 462.6625 MHz
  • Channel 06 - 462.6875 MHz
  • Channel 07 - 462.7125 MHz
  • Channel 08 - 467.5625 MHz
  • Channel 09 - 467.5875 MHz
  • Channel 11 - 462.5625 MHz
  • Channel 12 - 462.5875 MHz
  • Channel 13 - 462.6125 MHz
  • Channel 14 - 462.6375 MHz
  • Channel 15 - 462.7000 MHz
  • Channel 16 - 462.6000 MHz
