Militia Radio Frequencies
Revision as of 22:20, 22 March 2021 by R4002 (Talk | contribs)
  • Channel 9 - 467.5875 MHz - FRS 9 - Tactical, Calling/Mutual Aid
  • Channel 13 - 467.6875 MHz - FRS 13 - Tac
  • Channel 32 - 151.8800 MHz - MURS 2 - Command or Safety Channel
  • Channel 33 - 151.9400 MHz - MURS 3 - Primary Patriot Militia Calling or Prepper Frequency Prep
  • Channel 34 - 154.5700 MHz - MURS 4 - Command Blue
  • Channel 35 - 154.6000 MHz - MURS 5 - Command Green
  • MURS 1 - 151.8200 MHz - 88.5 Hz CALL
  • MURS 2 - 151.8800 MHz - 88.5 Hz or 210.7 Hz CTCSS SAFETY tone transmit recommend 210.7 Hz PL
  • MURS 3 - 151.9400 MHz - 88.5 Hz or 141.3 Hz CTCSS PREP tone transmit 141.3 Hz PL
  • MURS 4 - 154.5700 MHz - 88.5 Hz COMMAND/TAC BLUE
  • MURS 5 - 154.6000 MHz - 88.5 Hz COMMAND/TAC GREEN
  • Channel 032 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 210.7 Hz - display channel name: MURS 2
  • Channel 033 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: MURS 3
  • Channel 045 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 - display channel name: MURS 3 CALL - high power setting
  • Channel 124 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 210.7 Hz - display channel name: MURS 2 HP - high power setting
  • Channel 125 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: MURS 3 HP - high power setting
  • Channel 01 - 467.6375 MHz
  • Channel 02 - 467.6625 MHz
  • Channel 03 - 467.6875 MHz
  • Channel 04 - 467.7125 MHz
  • Channel 05 - 462.6625 MHz
  • Channel 06 - 462.6875 MHz
  • Channel 07 - 462.7125 MHz
  • Channel 08 - 467.5625 MHz
  • Channel 09 - 467.5875 MHz
  • Channel 11 - 462.5625 MHz
  • Channel 12 - 462.5875 MHz
  • Channel 13 - 462.6125 MHz
  • Channel 14 - 462.6375 MHz
  • Channel 15 - 462.7000 MHz
  • Channel 16 - 462.6000 MHz
