Amateur radio
hamateurszzz hamsexy dot com eham dot net et cetera hams don't like CBers. Hammies hamateurs HF frequencies listed below. Several VHF/UHF allocations worldwide. Exact band limits vary from country to country, with 2 meters generally being 144-146 MHz and 70cm generally being centered around 432 MHz or 440 MHz, the US bands of 144-148 MHz and 420-450 MHz are generally larger than allocations in other countries.
Amateur radio has secondary allocation in many bands.
Amateur Radio Bands
- 28000 kHz - 29700 kHz - 10 meter band
- 40 MHz - 8 meter band (only available in some countries)
- 70 MHz - 4 meter band (69 MHz, 70 MHz band, only available in some countries)
- 144-148 MHz - 2 meter band (144-146 MHz only in many countries)
- 222-225 MHz - 1.25 meter band (220-225 MHz in some areas), only available in some countries
- 902-902 MHz - 33cm band (shared with Part 15 services in the US, not available in many areas)
- 1240-1300 MHz - 23cm band
- 2400-2500 MHz - 2.4 GHz or 2.45 GHz band, shared with Part 15, WiFi and about six dozen other services, including Part 18 ISM
