VOR
Revision as of 14:28, 20 June 2023 by R4002 (Talk | contribs)
VHF Omnidirectional Radio Range or "Omni Range"
Very High Frequency Omnidirectional Radio Range - VHF aircraft band radio navigation system. Widely used, generally replaced (or at least supplanted non-directional beacons (NDBs). Now VOR is being generally replaced (or largely supplanted by) GPS.
Fixed service, 108 MHz to 117.95 MHz, worldwide. The 108-118 portion is often referred to as the "nav" band (see also: ILS, DME).
The ILS service uses frequencies in the 108.1 MHz - 111.95 MHz VHF band (localizer) and a paired frequency in the 328.6 MHz - 335.4 MHz UHF band (glideslope or glide path). See the ILS page for more information.
The VOR system also operates in the 108 MHz - 112 MHz band and the 112.05 MHz - 117.95 MHz band (50 kHz spacing in the 112.050 MHz - 117.950 MHz band).
Since the 108-112 MHz section is shared between the VOR, VOR/DME, VORTAC navigational stations and the ILS service, care must be taken to avoid accidentally tuning into a VOR and trying to use it as an ILS. No, seriously, airplanes have crashed because pilots tuned to a VOR and treated it like a ILS.
The frequency 108.0 MHz may be used for testing purposes only, due to the potential from FM broadcast band interference from FM stations operating on 107.9 MHz.
VOR frequencies
  • 108.2 MHz
  • 108.25 MHz
  • 108.4 MHz
  • 108.45 MHz
  • 108.6 MHz
  • 108.65 MHz
  • 108.8 MHz
  • 108.85 MHz
  • 109.0 MHz
  • 109.05 MHz
  • 109.25
  • 109.4 MHz
  • 109.45 MHz
  • 109.6 MHz
  • 109.65 MHz
  • 109.8 MHz
  • 109.85 MHz
  • 110.0 MHz
  • 110.05 MHz
  • 110.25
  • 110.4 MHz
  • 110.45 MHz
  • 110.6 MHz
  • 110.65 MHz
  • 110.8 MHz
  • 110.85 MHz
  • 111.0 MHz
  • 111.05 MHz
  • 111.2 MHz
  • 111.25 MHz
  • 111.4 MHz
  • 111.45 MHz
  • 111.6 MHz
  • 111.65 MHz
  • 111.8 MHz
  • 111.85 MHz
  • 112.0 MHz
  • 112.05 MHz
  • 112.1 MHz
  • 112.15 MHz
  • 112.2 MHz
  • 117.9 MHz
  • 117.95 MHz
