351 MHz UHF Digital Radio Service
351 MHz UHF Digital Personal Radio Service - Japan. 351.1125 MHz - 351.3875 MHz One of numerous UHF band personal radio services available in Japan. Similar in function to FRS in the United States, Canada, etc. Uses the low-UHF 300 MHz band like the 325 MHz Short Range Radio Service in the Philippines and 350 MHz Short Range Radio in India.
See also: 27 MHz CB in Japan as well as double side band DSB (AM) and SSB 27 MHz fishery radio services in Japan and the Specified Low Power Radio 420 MHz/421 MHz/422 MHz band service.
5 watt transmit power limit, digital voice. 351.16875 MHz - 351.38125 MHz. Like other personal radio services in Japan, all radios must be registered and transmit a unique radio ID number via a built-in ROM. Automatic digital callsign identification. 6.25 kHz channels, narrow band, similar to DPMR446.
- Channel 1 - 351.16875 MHz
- Channel 2 - 351.17500 MHz
- Channel 3 - 351.18125 MHz
- Channel 4 - 351.18750 MHz
- Channel 5 - 351.19375 MHz
- Channel 6 - 351.20000 MHz
- Channel 7 - 351.20625 MHz
- Channel 8 - 351.21250 MHz
- Channel 9 - 351.21875 MHz
- Channel 10 - 351.22500 MHz
- Channel 11 - 351.23125 MHz
- Channel 12 - 351.23750 MHz
- Channel 13 - 351.24375 MHz
- Channel 14 - 351.25000 MHz
- Channel 15 - 351.25625 MHz
- Channel 16 - 351.26250 MHz
- Channel 17 - 351.26875 MHz
- Channel 18 - 351.27500 MHz
- Channel 19 - 351.28125 MHz
- Channel 20 - 351.28750 MHz
- Channel 21 - 351.29375 MHz
- Channel 22 - 351.30000 MHz
- Channel 23 - 351.30625 MHz
- Channel 24 - 351.31250 MHz
- Channel 25 - 351.31875 MHz
- Channel 26 - 351.32500 MHz
- Channel 27 - 351.33125 MHz
- Channel 28 - 351.33750 MHz
- Channel 29 - 351.34375 MHz
- Channel 30 - 351.35000 MHz
- Channel 31 - 351.35625 MHz
- Channel 32 - 351.36250 MHz
- Channel 33 - 351.36875 MHz
- Channel 34 - 351.37500 MHz
- Channel 35 - 351.38125 MHz
