FM
Revision as of 16:09, 6 March 2024 by R4002 (Talk | contribs)
Frequency Modulation
It is rarely used on HF frequencies, with the exception of 27 MHz 11 meter CB operators in many countries - often in conjunction with AM and SSB, amateur radio operators using the FM in the 10 meter band, land mobile radio users operating on a small number of channelized frequencies in the 25 to 30 MHz range and some specialized maritime mobile (marine radio) systems used by fishing fleets, fishery radio networks, etc.
