VHF LADD
Revision as of 15:39, 12 September 2025 by R4002 (Talk | contribs)
VHF LADD (Logging Administration Dispatch), LD (Loading Channels) RR (Resource Road or Road Resource) channels, standardized for trucking, logging and use in remote areas for truck-to-truck, truck-to-base and emergency services communications with trucks, loading channels, etc. These frequencies are known by several names, including the Ice Road Channels, Ice Road Truckers Frequencies, Loading Channels, LD channels LAD channels, LADD channels, Resource Road channels, Logging common channels, Natural Resource Road Channels Resource Road VHF, VHF trucking channels, Canadian trucking channels and several other combinations of these. In remote areas of Canada, specific sections of roads are assigned specific channels. This is not the same service as MURS.
Note that use of 27 MHz CB radio equipment (called the General Radio Service in Canada - not to be confused with the General Mobile Radio Service or GMRS) is still a de facto requirement for trucking and use of CB equipment is strongly recommended.
Note that the 4 LADD channels are still in regular FM (20 kHz bandwidth or 16K0F3E emission) while the 5 LD (Loading Channels) and 35 RR (Resource Road) channels are narrowband FM (NFM or FMN - 11.25 kHz bandwidth - also known as 11K3F3E emission, 11K2F3E emission or 11K0F3E emission). CTCSS (PL) or DCS (DPL) should not be used on any of these frequencies.
Receivers must be set for carrier squelch or CSQ mode.
Channel Frequency Remarks/Usage
LADD 1 154.100 MHz LADD Channel 1 - trucking and logging companies, natural resource agencies
LADD 2 158.940 MHz LADD Channel 2 - trucking and logging companies, natural resource agencies
LADD 3 154.325 MHz LADD Channel 3 - trucking and logging companies, natural resource agencies
LADD 4 173.370 MHz LADD Channel 4 - trucking and logging companies, natural resource agencies
LD-1 151.700 MHz Loading Channel 1
LD-2 151.745 MHz Loading Channel 2
LD-3 151.790 MHz Loading Channel 3
LD-4 151.805 MHz Loading Channel 4
LD-5 151.850 MHz Loading Channel 5
LD-6 150.485 MHz Loading Channel 6
LD-7 153.215 MHz Loading Channel 7
LD-8 154.665 MHz Loading Channel 8
LD-9 152.330 MHz Loading Channel 9
LD-10 153.635 MHz Loading Channel 10
LD-11 157.590 MHz Loading Channel 11
LD-12 159.750 MHz Loading Channel 12
LD-13 164.010 MHz Loading Channel 13
LD-14 165.960 MHz Loading Channel 14
RR-01 150.080 MHz Resource Road Channel 1
RR-02 150.110 MHz Resource Road Channel 2
RR-03 150.140 MHz Resource Road Channel 3
RR-04 150.185 MHz Resource Road Channel 4
RR-05 150.200 MHz Resource Road Channel 5
RR-06 150.245 MHz Resource Road Channel 6
RR-07 150.260 MHz Resource Road Channel 7
RR-08 150.320 MHz Resource Road Channel 8
RR-09 150.365 MHz Resource Road Channel 9
RR-10 150.410 MHz Resource Road Channel 10
RR-11 150.440 MHz Resource Road Channel 11
RR-12 150.500 MHz Resource Road Channel 12
RR-13 150.530 MHz Resource Road Channel 13
RR-14 150.545 MHz Resource Road Channel 14
RR-15 150.560 MHz Resource Road Channel 15
RR-16 150.590 MHz Resource Road Channel 16
RR-17 150.680 MHz Resource Road Channel 17
RR-18 150.710 MHz Resource Road Channel 18
RR-19 150.770 MHz Resource Road Channel 19
RR-20 150.830 MHz Resource Road Channel 20
RR-21 151.010 MHz Resource Road Channel 21
RR-22 151.130 MHz Resource Road Channel 22
RR-23 151.190 MHz Resource Road Channel 23
RR-24 151.220 MHz Resource Road Channel 24
RR-25 151.310 MHz Resource Road Channel 25
RR-26 151.340 MHz Resource Road Channel 26
RR-27 151.370 MHz Resource Road Channel 27
RR-28 151.430 MHz Resource Road Channel 28
RR-29 151.460 MHz Resource Road Channel 29
RR-30 151.490 MHz Resource Road Channel 30
RR-31 151.520 MHz Resource Road Channel 31
RR-32 151.580 MHz Resource Road Channel 32
RR-33 151.610 MHz Resource Road Channel 33
RR-34 151.640 MHz Resource Road Channel 34
RR-35 151.670 MHz Resource Road Channel 35
Channel Use Location Information Official Resource Road Channel Allocations
See this official list of Natural Resource Roads LADD LD RR Resource Road VHF Radio Channel Frequency Channel Location Use Maps - kilometer signs with call-in channels are listed on the roads where use of these frequencies are required (link below).
[1]
