Letter beacon
Revision as of 14:00, 29 July 2010 by Strange Attractor (Talk | contribs)
  • Cluster beacons
Location of letter beacons
The leter beacon radio transmissions were discovered in the late 1960s. Their presence became known to the wider amateur radio community in 1978, when beacon “W” started transmitting on 3584 kHz, in the 80 meters band. SPEEDX published indirect evidence that this particular transmitter was located in Cuba. (3)
In 1982 in was reported by SPEEDX, supposedly based on HF direction finding by the US military, that beacon “K” transmitting on 9043 kHz was located at 48° 30' N - 134° 58' E, near the city of Khabarovsk in the USSR. (4), (5) A few years later, it was suggested that the "K" beacons were actually located at Petropavlovsk on the Kamchatka Peninsula and the "U" beacons were located at the Barents Sea coast, between Murmansk and Amderma. (6)
ID letter Location
C Moscow, RUS
D Odessa, UKR
O Moscow, RUS
P Kaliningrad, RUS
S Arkhangelsk, RUS
Z Mukachevo, UKR
ID letter Location
A Astrakhan, RUS (tentative)
C Moscow, RUS
D Sevastopol, UKR
F Vladivostok, RUS
M Magadan, RUS
P Kaliningrad, RUS
S Severomorsk, RUS
ID letter Location
L Tirana, ALB (inactive)
R Izhevsk (Ustinov), RUS
P Kaliningrad, RUS
V Khiva, UZB
Types of letter beacons
Cluster beacons
A +0.1 3595.1, 4558.1, 5154.1, 7039.1, 8495.1, 10872.1 16332.1 (10)
F +0.2 7039.2
K +0.3 5154.3, 7039.3, 8495.3
ID letter Frequencies (kHz)
R 4325.9, 5465.9
V 3658.0, 5141, 5342, 6430.7, 6809, 7027.5, 8103.5, 10202
P (12) 420, 583, 3167, 3291, 3327, 3699.5, 3837, 4031, 4043, 4079
C 8000
FSK beacons
ENIGMA designation
ENIGMA ID Description
MX Cluster beacons
According to ENIGMA the cluster beacons are used by the Russian Navy (and especially the submarine branch) to find the most suitable radio frequency for contact based on current radio propagation conditions. (7)
Similar systems
A few aero navigation Non Directional Beacons also transmit single letter identification codes. They can be easily distinguished from Letter beacons as they transmit in the allocated low frequency and medium frequency bands, most of them are listed in appropriate aviation handbooks and their transmission mode is A2A (full carrier with audio modulation).
Notes & References
  15. Poundstone Willian: Big Secrets, Quill, New York, 1983, ISBN 0688048307, pages 191-193
  4. Spooks mailing list.
Wikipedia article: {{{1}}}
WP
