Radio propagation beacon
| Contents |
Transmission characteristics
160 meters beacons
10 meters beacons
| R1 |
| R2[3] |
| R3 |
6 meters beacons
VHF/UHF beacons
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
Beacon projects
IARU Beacon Project
| Slot | DX Entity | Call | Location | Latitude | Longitude | Grid Sq |
| 01 | United Nations | 4U1UN | New York City | 40º 45' N | 73º 58' W | FN3ØAS |
| 02 | Canada VE8AT | Eureka, Nunavut | 79º 59' N | 85º 57' W | EQ79AX | |
| 03 United States W6WX Mt. Umunhum 37º 09' N 121º 54' W CM97bd | ||||||
| 04 Hawaii KH6WO Laie 21º 38' N 157º 55' W BL11ap | ||||||
| 05 New Zealand ZL6B Masterton 41º 03' S 175º 36' E RE78tw | ||||||
| 06 Australia VK6RBP Rolystone 32º 06' S 116º 03' E OF87av | ||||||
| 07 Japan JA2IGY Mt. Asama 34º 27' N 136º 47' E PM84jk | ||||||
| 08 Russia RR9O Novosibirsk 54º 59' N 82º 54' E NO14kx | ||||||
| 09 Hong Kong VR2B Hong Kong 22º 16' N 114º 09' E OL72bg | ||||||
| 10 Sri Lanka 4S7B Colombo 6º 6' N 80º 13' E NJ06cc | ||||||
| 11 South Africa ZS6DN Pretoria 25º 54' S 28º 16' E KG44dc | ||||||
| 12 Kenya 5Z4B Kariobangi 1º 15' S 36º 53' E KI88ks | ||||||
| 13 Israel 4X6TU Tel Aviv 32º 03' N 34º 46' E KM72jb | ||||||
| 14 Finland OH2B Lohja 60º 19' N 24º 50' E KP2Ø | ||||||
| 15 Madeira CS3B Santo da Serra 32º 43' N 16º 48' W IM12or | ||||||
| 16 Argentina LU4AA Buenos Aires 34º 37' S 58º 21' W GFØ5tj | ||||||
| 17 Peru OA4B Lima 12º 04' S 76º 57' W FH17mw | ||||||
| 18 Venezuela YV5B Caracas 10º 25' N 66º 51' W FK6Ønj |
ITU sponsored beacons
DARC beacon project
The Deutscher Amateur Radio Club (DARC) sponsors two beacons which transmit from Scheggerott, near Kiel (54.68750N - 9.791670E). [8] These beacons are DRA5 on 5195 kHz and DK0WCY on 10144 kHz. In addition to identification and location, every 10 minutes these beacons transmit solar and geomagnetic bulletins. Transmissions are in Morse code for aural reception, RTTY and PSK31. [9] DK0WCY operates also a limited service beacon on 3579 kHz at 0720-0900 and 1600-1900 local time.
RSGB 5 MHz beacon project
Notes and references
- HF 0-20 MHz beacons
- Andrew Talbot, G4JNT: The Next Generation of Beacons for the 21st century (PTT format).
|   | This article contains textual material from Wikipedia (TM). Wikipedia texts are licensed under the Creative Commons Attribution-Share Alike license. In short: you are free to distribute and modify the text as long as you attribute its author(s) or licensor(s). If you alter, transform, or build upon this work, you may distribute the resulting work only under the same or similar license to this one. Wikipedia article: {{{1}}} | WP |
