Radio propagation beacon
Transmission characteristics
Most beacons consist of a simple digital keyer, based on discrete digital electronics or a microcontroller, and a low power transmitter or tranceiver. Antennas usually are types with low directivity.
160 meters beacons
60 meters beacons
| LX0HF | 5205.3 kHz | ||
| OK1IF | 5258.5 kHz | JO40HG | Recording: [1] |
| GB3RAL | 5290.0 kHz | IO91IN | RSGB |
| GB3WES | 5290.0 kHz | IO84QN | RSGB |
| GB3ORK | 5290.0 kHz | IO89JA | RSGB |
30 meters beacons
10 meters beacons
| R1 |
| R2[3] |
| R3 |
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
| R1 | R2 | R3 | |
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
SHF and microwave beacons
| R1 | R2 | R3 | |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
DARC beacon project
RSGB 5 MHz beacon project
Notes and references
- HF 0-20 MHz beacons
- Ionosonde
- Radio beacon
Beacon lists
Currently there are two regularly updated international beacon lists, compiled by Martin G3USF and Joost, ZS5S. Both lists are available on-line.
- Aurora Beacon DK0WCY
