Radio propagation beacon
Revision as of 03:40, 4 October 2012 by Strange Attractor (Talk | contribs)
DK0WCY & DRA5 beacons
Transmission characteristics
160 meters beacons
60 meters beacons
DRA5 5195.0 kHz JO44VQ DARC
LX0HF 5205.3 kHz
GB3RAL 5290.0 kHz IO91IN RSGB
GB3WES 5290.0 kHz IO84QN RSGB
GB3ORK 5290.0 kHz IO89JA RSGB
30 meters beacons
10 meters beacons
R1
  • 28199-28201 WW Time Shared
  • 28201-28225 Continuous Duty
R2[3]
  • 28199-28201 IBP/NCDXF
  • 28225-28300 Shared
R3
  • 28190-28200 IBP
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
Band Beacon Sub-band (MHz)
IARU R1 IARU R2 IARU R3
33 cm N/A Varies Locally N/A
Band Beacon allocation (kHz)
4 m 70,000-70,030
2 m 144,400-144,490
70 cm 432,800-432,990
23 cm 1296,800-1296,990
ON0EME moon beacon
SHF and microwave beacons
1.2 cm Beacons are rare
Optical and infrared beacons
Main articles: LowFER, HiFER.
MedFER 510 & 1704 kHz
(510-1705 kHz)
USA, Canada § 15.219
BeFER 6776 kHz Canada -
49ers 49846 kHz
(49820-49900 kHz)
USA § 15.235
Beacon projects
IARU Beacon Project
url="http://www.darc.de"
ITU sponsored beacons
As part of an International Telecommunications Union-funded project, radio propagation beacons were installed by national authorities at Sveio, Norway (callsign LN2A, 59.60420N - 5.291670E) and at Darwin, Australia (callsign VL8IPS, 12.60420S - 131.29200E). The beacons operated on frequencies 5471.5 kHz, 7871.5 kHz, 10408.5 kHz, 14396.5 kHz, and 20948.5 kHz.(6) (15) Since 2002, there have been no reception reports for these beacons and the relevant ITU web pages have been removed. (7)
Radio Beacon LN2A
14395 00 - 20 - 40
20945 04 - 24 - 44
5470 08 - 28 - 48
7870 12 - 32 - 52
10407 16 - 36 - 56
The contact address is:
P O Box 447 Sentrum
N-0104 Oslo
Norway
DARC beacon project
RSGB 5 MHz beacon project
U.S. Navy beacons
WSPR Network
This is an a large scale amateur radio propagation beacon project which uses the WSPR (Weak Signal Propagation Reporter) transmission scheme available with the WSJT software suite, created by Joe Taylor, K1JT. The loosely-coordinated beacon transmitters and receivers, collectively known as the WSPRnet, report the real-time propagation characteristics of a number of frequency bands and geographical locations via the Internet. The WSPRnet website provides detailed propagation report databases and real-time graphical maps of propagation paths. WSPR Networks operates on the following amateur radio frequencies (USB dial settings in kHz) 136.0, 502.4, 1836.6, 3592.6, 5287.2, 7038.6, 101387.0, 14095.6, 18104.6, 21094.6, 24924.6, 28124.6, 50293.0, 70028.6 and 144489.0 kHz.
Notes and references
  6. HF 0-20 MHz beacons
Beacon lists
IK0WRB beacon keyer schematic
WP
