Radio propagation beacon
History
Transmission characteristics
160 meters beacons
60 meters beacons
| LX0HF | 5205.3 kHz | ||
| HG7BHB | 5252.3 kHz | JN97LE | |
| OK1IF | 5258.5 kHz | JO40HG | Inactive. Recording: [1] |
| GB3RAL | 5290.0 kHz | IO91IN | RSGB, inactive |
| GB3WES | 5290.0 kHz | IO84QN | RSGB, inactive |
| GB3ORK | 5290.0 kHz | IO89JA | RSGB, inactive |
| SZ1SV | 5398.5 kHz | KM17UX | Op SV1IW & SV1JG. Inactive. |
30 meters beacons
10 meters beacons
| R1 |
| R2[3] |
| R3 |
40 MHz beacons
6 meters (50 MHz) beacons
4 meters (70 MHz) beacons
General beacon operations
Special beacon allocations
VHF/UHF beacons
| 4 m | 70,000-70,030 |
| 2 m | 144,400-144,490 |
| 70 cm | 432,800-432,990 |
| 23 cm | 1296,800-1296,990 |
ON0EME moon beacon
144 MHz transatlantic beacons
| Callsign | Locator | Frequency (kHz) | Info |
| CU2VHF | HM77DT | 144401 | |
| CU8DUB | HM49KL | 144420 | |
| D4C/B | HK76MV | 144436 | 750 m ASL, 20W CW. Copied by Dave Pedersen, PJ4VHF/N7BHC, on Bonaire Island on May 6, 2015 [4] |
| ED8ZAA/B | IL18 | 144484 | |
| GB3WGI[24] | IO64BL | 144487 | 100 W CW and JT65. Activated on June 4, 2013. |
| K4MHZ | FM25 | 144300 | 2M Transatlantic Beacon, Hatteras, NC: CW at 10 WPM. Running 100W to a 12 element long Yagi at 50' on a center azimuth of 70 degrees towards the Azores, Canary Islands, and southern Europe/North Africa. |
| N7BHC | FM15PA | 144291 | Mode: CW, 13 WPM. Transmit sequence: N7BHC FM15PA N7BHC FM15PA N7BHC FM15PA (15 second carrier) (15 seconds receive period). Location: 35.0302 N - 76.7146 W |
| NP2X/B | FK77PR | 144291 | St. Croix, US Virgin Islands - 240 feet AMSL (73 meters AMSL) - RF Concepts 160 watt, reduced to 100 watts for beacon operation - 15 element yagi @ beam heading of 55 degrees (Portgual) - np2xbeacon@gmail.com |
| PY2MTV/B | GG66va | 144300 | Beaming to AF/EU |
| VE1SMU/H | 144.288 | ||
| VO1ZA | GN37JS | 144400 | Inactive |
| W1RJA/B | FN41CJ | 144282 | Southern Rhode Island. Emission: A1 (amplitude keyed CW) Power: 60 Watts Feedline: 160' Cablewave FLC 12-50 half inch hardline. Antenna: 9.5 dBd 5 element yagi beaming 60 degrees azimuth. Height: 140 feet (43M) above base elevation of 130 feet (40M) ASL |
| WA1ZMS | FM07FM | 144285 | Activated on October 29, 2006 - 4200FT AMSL - Antenna: 2-yagi pair, Directive Systems DPM144-5 Antenna gain: 11.5dBd Radiated power: 1400W ERPd) |
Indian Ocean beacon project
SHF and microwave beacons
| 3 cm | 10,368.800-10,368.995 | 10,368.300-10,368.400 | Unknown (25) |
Optical and infrared beacons
| Type | Frequencies | Countries | FCC Part 15 rules |
| LowFER | 160-190 kHz | USA, Canada | § 15.217 |
| MedFER | 510 & 1704 kHz (510-1705 kHz) | USA, Canada | § 15.219 |
| BeFER | 6776 kHz | Canada | - |
| HiFER | 13553-13567 kHz | USA, Canada | § 15.225 |
| 49ers | 49846 kHz (49820-49900 kHz) | USA | § 15.235 |
Beacon projects
IARU Beacon Project
ITU sponsored beacons
As part of an International Telecommunications Union-funded project, radio propagation beacons were installed by national authorities at Sveio, Norway (callsign LN2A, 59.60420N - 5.291670E) and at Darwin, Australia (callsign VL8IPS, 12.60420S - 131.29200E). The beacons operated on frequencies 5471.5 kHz, 7871.5 kHz, 10408.5 kHz, 14396.5 kHz, and 20948.5 kHz.(6) (15) Since 2002, there have been no reception reports for these beacons and the relevant ITU web pages have been removed. (7) (20)
For a number of years, ITU-R Study Group 3 has been promoting a world-wide HF field-strength measurement campaign, the impetus for which arose from WARC HFBC-87 and the request for improved accuracy in HF propagation prediction. At that time, the Study Group recognised that significant improvements in HF propagation prediction methods needed a substantial body of new measurement data and to that end, administrations and organisations were invited to participate in the measurement campaign, either by installing suitable transmitters or by collecting long-term data from appropriate receiving systems. The campaign is specified in Recommendation ITU-R P.845 'HF field-strength measurement' and comprises a world-wide network of transmitters and receivers using coded transmissions on pre-determined frequencies. The reasons for the campaign and the continuing need for participation in it, are underlined in Resolution ITU-R 27 (HF field-strength measurement campaign). So far, regular transmissions are being provided by the Administrations of Australia and Norway. Details of the transmitter in Norway, operated by the Norwegian Telecommunications Authority and Telenor Broadcasting, are given below: | ||||||||||||
Radio Beacon LN2A
Administrations and organizations participating in the work of ITU-R are invited to consider the possibility of participating in the campaign, either through the provision of transmissions or by the collection of field strength measurement data, both in accordance with the specifications given in Recommendation ITU-R P.845. For further details on the campaign, including the availability of a suitable receiving system, please contact the ITU-R Counsellor for Study Group 3 (Dr. Kevin A. Hughes) at ITU Headquarters, in Geneva. The Norwegian Telecommunications Authority and Telenor Broadcasting would be pleased to acknowledge reception reports of LN2A with a QSL card. The contact address is: Norwegian Telecommunications Authority (Att. AYO/TF) | ||||||||||||
| Radio Beacon VL8IPS
DARC beacon project
RSGB 5 MHz beacon project
WSPR Network
- Ionosonde
- Radio beacon
- Letter beacon
- High Frequency Beacon
- Part_15_Beacons
Notes and references
- HF 0-20 MHz beacons
- Martin Harrison, G3USF: "Getting started in... beacons, part 2", RadCom, 89(03), Radio Society of Great Britain, pp. 30, March 2013.
- Charlie Newton, G2FKZ: "Radio Auroras", revised edition edited by Steve Telenius-Lowe, 9M6DXX, Radio Society of Great Britain, ISBN 9781-9050-8681-8, pp. 8, 2012.
- 144 MHz Transatlantic Beacon List by Derek Hilleard G4CQM
- "GB3WGI 144 MHz transatlantic beacon", RadCom, 89(08), Radio Society of Great Britain, pp. 11, August 2013.
- Allocations vary by country. In Australia, VK3RMB is on 10368.536 MHz, VK3RGI on 10368.434 MHz and VK3RXX on 10368.530 MHz.
Beacon lists
- Aurora Beacon DK0WCY
- ON0EME moon beacon status
