Revision as of 00:14, 24 January 2019 by R4002 (Talk | contribs)
Often heard at construction sites, special events, shopping malls, stores, gas stations, etc. Often supplemented with heavy use of FRS frequencies. Most of the transmissions you'll hear on these frequencies are from portable handheld radios - walkie-talkies, but sometimes high powered mobile radios or even portable repeaters are heard. Portable or temporary repeater output frequencies may be any of the VHF low or VHF high frequencies. On the UHF band, input frequency is 5 MHz above output frequency. In many situations all frequencies are used for simplex only. The 457 MHz frequencies are simplex use only.
  • 27.490 MHz - Itinerant
  • 35.040 MHz - Itinerant
  • 43.040 MHz - Itinerant
  • 151.5125 MHz - Itinerant
  • 151.6400 MHz - Itinerant - narrowband only, maximum bandwidth 6 kHz
  • 151.9550 MHz - Purple Dot
  • 158.4000 MHz - Itinerant
  • 158.4075 MHz - Itinerant
  • 464.4875 MHz - Itinerant
  • 464.5000 MHz - Itinerant Brown Dot, maximum power 35 watts
  • 464.5125 MHz - Itinerant
  • 464.5375 MHz - Itinerant
  • 464.5500 MHz - Itinerant Yellow Dot, maximum power 35 watts
  • 467.7750 MHz - Maximum power 2 watts
  • 467.8000 MHz - Maximum power 2 watts
  • 467.8250 MHz - Maximum power 2 watts
  • 467.8500 MHz - Silver Star, maximum power 2 watts
  • 467.8750 MHz - Gold Star, maximum power 2 watts
  • 467.9000 MHz - Red Star, maximum power 2 watts
  • 469.4875 MHz - Itinerant
  • 469.5125 MHz - Itinerant
  • 469.5375 MHz - Itinerant
  • 469.5625 MHz - Itinerant
35.180 MHz
44.100 MHz
72.080 MHz
72.160 MHz
72.240 MHz
72.320 MHz
72.400 MHz
72.420 MHz
72.440 MHz
72.460 MHz
72.480 MHz
72.500 MHz
72.520 MHz
72.540 MHz
72.560 MHz
72.580 MHz
72.600 MHz
72.620 MHz
72.640 MHz
72.660 MHz
72.680 MHz
72.700 MHz
72.720 MHz
72.740 MHz
72.760 MHz
72.780 MHz
72.800 MHz
72.820 MHz
72.840 MHz
72.860 MHz
72.880 MHz
72.900 MHz
72.920 MHz
72.940 MHz
72.960 MHz
72.980 MHz
75.420 MHz
75.460 MHz
75.500 MHz
75.540 MHz
75.580 MHz
75.620 MHz
75.640 MHz
75.660 MHz
75.680 MHz
75.700 MHz
75.720 MHz
75.740 MHz
75.760 MHz
75.780 MHz
75.800 MHz
75.820 MHz
75.840 MHz
75.860 MHz
75.880 MHz
75.900 MHz
75.920 MHz
75.940 MHz
75.960 MHz
75.980 MHz
152.2625-152.465 MHz 7.5 kHz steps, old Taxicab Radio Service base/repeater output frequencies
154.45625 MHz Operational fixed (SCADA, data links, etc) only
154.46375 MHz Operational fixed (SCADA, data links, etc) only
154.47125 MHz Operational fixed (SCADA, data links, etc) only
154.47875 MHz Operational fixed (SCADA, data links, etc) only
154.505 MHz
154.5275 MHz Mobiles only
154.585 MHz
154.610 MHz
154.625 MHz
154.640 MHz
157.470-157.725 MHz 7.5 kHz steps
160.215-161.610 MHz 7.5 kHz steps, Railroad Use Only
173.20375 MHz Operational fixed (SCADA, data links, etc) only
173.210 MHz Operational fixed (SCADA, data links, etc) only
173.390 MHz Operational fixed (SCADA, data links, etc) only
173.39625 MHz Operational fixed (SCADA, data links, etc) only
