MURS
Multi Use Radio Service
MURS, VHF CB, also rendered as "Multi-Use Radio Service" - not to be confused with similar services such as FRS/GMRS, regular old 26-27 MHz CB, VHF marine or licensed land mobile (business radio) services.
MURS Frequencies / Channels:
| MURS Channel | Identifier | Frequency | Maximum Bandwidth |
| MURS Channel 1 | MURS-1 | 151.820 MHz | 11.25 kHz (any mode - narrowband) |
| MURS Channel 2 | MURS-2 | 151.880 MHz | 11.25 kHz (any mode - narrowband) |
| MURS Channel 3 | MURS-3 | 151.940 MHz | 11.25 kHz (any mode - narrowband) |
| MURS Channel 4 | Blue Dot MURS-4 | 154.570 MHz | 20.00 kHz (any mode - wideband) |
| MURS Channel 5 | Green Dot MURS-5 | 154.600 MHz | 20.00 kHz (any mode - wideband) |
Repeaters are not allowed on the MURS frequencies per FCC rules. This includes duplex and simplex repeaters, also known as "store-and-forward" repeaters. This rule is apparently often ignored by MURS users as evidenced by the existence of simplex repeaters operating on the MURS frequencies as well as cross-band repeater setups using MURS (on VHF) and FRS/GMRS channels (on UHF). There are several reports on various radio hobbyist Internet forums of MURS repeaters including wide-area simplex repeaters located on mountaintops or MURS simplex repeaters with antennas located on high-rise buildings in urban areas.
The 154 MHz frequencies were moved from the Business Radio Service (Part 90 of the FCC rules) and stations previously licensed to use these frequencies with higher power levels are considered grandfathered users and may legally transmit high power transmissions. Wal-Mart and other retailers using 154.600 MHz and 154.570 MHz have continued to use these frequencies after they were made license-free.
