MURS
Revision as of 17:16, 13 March 2020 by R4002 (Talk | contribs)
Multi Use Radio Service
MURS Frequencies / Channels:
Common analog voice emissions (generally FM voice) include 11K2F3E, 11K0F3E, 10K0F3E, 9K20F3E and 9K10F3E (Baofeng radios) for MURS channels 1, 2 and 3. 20K0F3E and 16K0F3E are allowed on MURS 4 and 5. Radios used by Wal-Mart, for example, transmit 20K0F3E emission on 154.57 MHz and 154.6 MHz but transmit 11K0F3E on 151.82 MHz, 151.88 MHz and 151.94 MHz. All five MURS frequencies are heavily used by WalMart and Sam's Club stores.
  • Are the "color dot" frequencies license free or part of MURS? Yes and no. Only the Blue Dot and Green Dot channels are license free and part of MURS. The other color dot frequencies, star frequencies, etc. require FCC Part 90 Business Radio licenses to operate on. You must have a license to use 151.625 MHz, 151.955 MHz, 467.925 MHz, 467.850 MHz, 467.7625 MHz, 464.500 MHz and 464.550 MHz, for example.
  • Are Baofeng radios legal? This is a gray area. If you use the MURS or FRS frequencies you should be good to go. Make sure to use narrowband mode on the MURS and FRS/GMRS frequencies.
  • Are MURS channels part of the CB radio service? Legally and technically, yes.
Motorola RMM2050 5 channel MURS radio default channels:
  • Channel 1 - 154.5700 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 1] - MURS 4
  • Channel 2 - 154.6000 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 2] - MURS 5
  • Channel 3 - 151.8200 MHz 67.0 Hz PL 11.25 kHz bandwidth [Identified in radio programming as Frequency 3] - MURS 1
  • Channel 4 - 151.8800 MHz 67.0 Hz PL 11.25 kHz bandwidth [Identified in radio programming as Frequency 4] - MURS 2
  • Channel 5 - 151.9400 MHz 67.0 Hz PL 11.25 kHz bandwidth [Identified in radio programming as Frequency 5] - MURS 3
Motorola CP110M 8 channel MURS radio default channels:
  • Channel 1 - 154.5700 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 2] - MURS 4
  • Channel 2 - 154.6000 MHz 67.0 Hz PL 20.0 kHz bandwidth [Identified in radio programming as Frequency 1] - MURS 5
  • Channel 6 - 154.5700 MHz CSQ 20.0 kHz bandwidth [Identified in radio programming as Frequency 2] - MURS 4
  • Channel 7 - 154.6000 MHz CSQ 20.0 kHz bandwidth [Identified in radio programming as Frequency 1] - MURS 5
  • Channel 8 - 151.8200 MHz CSQ 11.25 kHz bandwidth [Identified in radio programming as Frequency 3] - MURS 1
Motorola RDM2070D 7 channel Wal-Mart MURS radio default channels:
  • Channel 1 - 154.5700 MHz CSQ
  • Channel 2 - 154.6000 MHz CSQ
  • Channel 3 - 151.8200 MHz 136.5 Hz PL
  • Channel 4 - 151.8800 MHz 136.5 Hz PL
  • Channel 5 - 151.9400 MHz 136.5 Hz PL
  • Channel 6 - 154.5700 MHz 136.5 Hz PL
  • Channel 7 - 154.6000 MHz 136.5 Hz PL
Note: Wal-Mart stores will often re-program their radios to use different CTCSS (PL) tones in areas where frequency congestion is an issue. However, a significant number of stores continue to use CSQ (carrier squelch) on 154.570 MHz and 154.600 MHz. Use of non-MURS frequencies by some Wal-Mart (and Sam's Club) stores has also been reported along with use of the 151.820 MHz, 151.880 MHz and 151.940 MHz MURS frequencies with carrier squelch. Like other Motorola MURS radios, the RDM2070 is hard-programmed for wideband 20 kHz FM on 154.57 and 154.6 MHz.
Motorola RDM2020 2 channel MURS radio default channels:
Motorola RDM2080D 8 channel MURS radio default channels:
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area
  • 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power, 2w transmitter, around 5w ERP - located in downtown Richmond, VA)
  • The Mount Jackson, VA MURS simplex repeater has 50+ mile coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of eastern West Virginia. Confirmed active August 2019.
  • The Richmond, VA MURS simplex repeater has considerably less coverage due to its low power transmitter and location in an urban area. Coverage is reliable in downtown Richmond and other areas of the city. Both of these MURS repeaters use MURS ch 2 - 151.880 MHz and CTCSS / PL tone 156.7 Hz for transmit and receive. The Richmond MURS repeater is off-grid power (solar powered with battery backup) to help support emergency communications. Confirmed active March 2020.
The 27 MHz band (11 meter patriot freeband - 26-28 MHz, 25.615 MHz - 30.105 MHz, etc, legal 40 channel CB) is still heavily used by hunting clubs, preppers, militia organizations and other similar groups. There is some limited use of VHF low band (namely 27.430 MHz, 27.450 MHz, 27.470 MHz, 27.490 MHz, 35.040 MHz, 42.960 MHz, 42.980 MHz, 43.000 MHz, 43.040 MHz and the unlicensed 49 MHz frequencies by these groups as well - likely due to the availability of low cost VHF low band radios on the used secondhand market.
  • 151.8200 MHz - Militia/Patriot MURS VHF MURS 1
  • 151.8800 MHz - Militia/Patriot MURS VHF MURS 2
  • 154.5700 MHz - Militia/Patriot MURS VHF MURS 4
Alternate VHF militia plans:
  • 151.880 MHz - MURS 2
  • 154.570 MHz - MURS 4
  • 154.600 MHz - MURS 5
  • 151.655 MHz - VHF Business
  • 151.685 MHz - VHF Business
  • 151.715 MHz - VHF Business
  • 151.745 MHz - VHF Business
  • 151.775 MHz - VHF Business
  • 151.805 MHz - VHF Business
  • 151.835 MHz - VHF Business
  • 151.865 MHz - VHF Business
  • 151.895 MHz - VHF Business
  • 151.925 MHz - VHF Business
  • 151.955 MHz - VHF Business
  • 152.870 MHz - VHF Business
  • 152.885 MHz - VHF Business
  • 152.900 MHz - VHF Business
  • 152.915 MHz - VHF Business
  • 152.930 MHz - VHF Business
  • 152.945 MHz - VHF Business
  • 152.960 MHz - VHF Business
  • 152.975 MHz - VHF Business
  • 152.990 MHz - VHF Business
  • 153.005 MHz - VHF Business
  • 154.4825 MHz - VHF Business (narrowband)
  • 154.490 MHz - VHF Business
  • 154.4975 MHz - VHF Business (narrowband)
  • 154.505 MHz - VHF Business (narrowband)
  • 154.515 MHz - VHF Business (narrowband)
  • 154.5275 MHz - VHF Business Itinerant (narrowband)
  • 154.540 MHz - VHF Business
  • 154.5475 MHz - VHF Business
  • 154.555 MHz - VHF Business (narrowband)
  • 154.625 MHz - VHF Business (narrowband)
  • 154.655 MHz - VHF Business (narrowband)
  • 158.4075 MHz - VHF Business Itinerant (narrowband)
