PMR446
Channel | Freq MHz |
1 | 446.00625 |
2 | 446.01875 |
3 | 446.03125 |
4 | 446.04375 |
5 | 446.05625 |
6 | 446.06875 |
7 | 446.08125 |
8 | 446.09375 |
9 | 446.10625 |
10 | 446.11875 |
11 | 446.13125 |
12 | 446.14375 |
13 | 446.15625 |
14 | 446.16875 |
15 | 446.18125 |
16 | 446.19375 |
Digital FDMA
Digital dPMR446 uses 32 digital voice channels separated by 6.25 kHz from each other with 4-level FSK modulation at 3.6 kbit/s. These frequencies overlap the original 16 analog voice/digital voice frequencies and operate in the same 446.0 to 446.2 MHz frequency range of the original PMR446 service. Kenwood designates the 6.25 kHz PMR446 digital band as DPMR446 or Digital DPMR446, not to be confused with digital DMR Tier 1 (which operates on the 12.5 kHz "wideband" channels, same frequencies as the analog channels).
1 | 446.003125 |
2 | 446.009375 |
3 | 446.015625 |
4 | 446.021875 |
5 | 446.028125 |
6 | 446.034375 |
7 | 446.040625 |
8 | 446.046875 |
9 | 446.053125 |
10 | 446.059375 |
11 | 446.065625 |
12 | 446.071875 |
13 | 446.078125 |
14 | 446.084375 |
15 | 446.090625 |
16 | 446.096875 |
17 | 446.103125 |
18 | 446.109375 |
19 | 446.115625 |
20 | 446.121875 |
21 | 446.128125 |
22 | 446.134375 |
23 | 446.140625 |
24 | 446.146875 |
25 | 446.153125 |
26 | 446.159375 |
27 | 446.165625 |
28 | 446.171875 |
29 | 446.178125 |
30 | 446.184375 |
31 | 446.190625 |
32 | 446.196875 |
Authorized PMR446 Countries
- 446.000000 MHz - begin PMR446 allocation lower band edge 446.0 MHz
- 446.00625 MHz - Analog FM or wideband digital channel 1
446.015625
|- | 4 || 446.021875 |- | 5 || 446.028125 |- | 6 || 446.034375 |- | 7 || 446.040625 |- | 8 || 446.046875 |- | 9 || 446.053125 |- | 10 || 446.059375 |- | 11 || 446.065625
446.015625 446.021875 446.028125 446.034375 446.040625 446.046875 446.053125 446.059375 446.065625 446.071875 446.078125 446.084375 446.090625 446.096875 446.103125 446.109375 446.115625 446.121875 446.128125 446.134375 446.140625 446.146875 446.153125 446.159375 446.165625 446.171875 446.178125 446.184375 446.190625 446.196875
