PMR446
Revision as of 19:07, 7 May 2020 by R4002 (Talk | contribs)
Channel Freq MHz
1 446.00625
2 446.01875
3 446.03125
4 446.04375
5 446.05625
6 446.06875
7 446.08125
8 446.09375
9 446.10625
10 446.11875
11 446.13125
12 446.14375
13 446.15625
14 446.16875
15 446.18125
16 446.19375
Digital FDMA
Digital dPMR446 uses 32 digital voice channels separated by 6.25 kHz from each other with 4-level FSK modulation at 3.6 kbit/s. These frequencies overlap the original 16 analog voice/digital voice frequencies and operate in the same 446.0 to 446.2 MHz frequency range of the original PMR446 service. Kenwood designates the 6.25 kHz PMR446 digital band as DPMR446 or Digital DPMR446, not to be confused with digital DMR Tier 1 (which operates on the 12.5 kHz "wideband" channels, same frequencies as the analog channels).
Channel Freq MHz
1 446.003125
2 446.009375
3 446.015625
4 446.021875
5 446.028125
6 446.034375
7 446.040625
8 446.046875
9 446.053125
10 446.059375
11 446.065625
12 446.071875
13 446.078125
14 446.084375
15 446.090625
16 446.096875
17 446.103125
18 446.109375
19 446.115625
20 446.121875
21 446.128125
22 446.134375
23 446.140625
24 446.146875
25 446.153125
26 446.159375
27 446.165625
28 446.171875
29 446.178125
30 446.184375
31 446.190625
32 446.196875
Authorized PMR446 Countries
  • 446.006250 MHz - Analog FM or wideband digital channel 1
  • 446.018750 Analog FM or wideband digital channel 2
  • 446.015625
  • 446.021875
  • 446.028125
  • 446.031250 Analog FM or wideband digital channel 3
  • 446.034375
  • 446.040625
  • 446.043750 analog channel 4
  • 446.046875
  • 446.053125
  • 446.056250 analog channel 5
  • 446.059375
  • 446.065625
  • 446.068750 analog channel 6
  • 446.071875
  • 446.078125
  • 446.081250 analog channel 7
  • 446.084375
  • 446.090625
  • 446.093750 analog channel 8
  • 446.096875
  • 446.103125
  • 446.106250 analog channel 9
  • 446.109375
  • 446.115625
  • 446.118750 analog channel 10
  • 446.121875
  • 446.128125
  • 446.131250 analog channel 11
  • 446.134375
  • 446.140625
  • 446.143750 analog channel 12
  • 446.146875
  • 446.153125
  • 446.156250 analog channel 13
  • 446.159375
  • 446.165625
  • 446.168750 analog channel 14
  • 446.171875
  • 446.178125
  • 446.181250 analog channel 15
  • 446.184375
  • 446.190625
  • 446.193750 analog channel 16
  • 446.196875
