MURS
Multi Use Radio Service
MURS Frequencies / Channels:
- Are the "color dot" frequencies license free or part of MURS? Yes and no. Only the Blue Dot (154.57 MHz) and Green Dot (154.6 MHz) channels are license free and part of MURS. The other color dot frequencies, star frequencies, etc. require FCC Part 90 Business Radio licenses to operate on. You must have a license to use 151.625 MHz, 151.955 MHz, 467.925 MHz, 467.850 MHz, 467.7625 MHz, 464.500 MHz and 464.550 MHz, for example.
- Are Baofeng radios legal? This is a gray area. If you use the MURS or FRS frequencies you should be good to go. Make sure to use narrowband mode on the MURS and FRS/GMRS frequencies. Certain radios are FCC type accepted for Part 95 use. Examples include the Baofeng Baofeng Tech BTECH MURS-V1 and GMRS-V1 radios currently available on the market.
- Are MURS channels part of the CB radio service? Legally and technically, yes. MURS is included under Part 95 of the FCC rules, as an unlicensed Personal Radio Service. Like CB, and FRS, MURS is designed as a short range voice and data radio service for personal, family, business and any other use by members of the public. MURS is not designed for public safety purposes.
- Can you transmit voice modes other than regular FM on MURS? Yes, you can transmit analog voice in FM mode, AM mode or digital voice in any DV mode that meets the bandwidth requirements for the MURS frequencies. This includes DMR, DPMR, TRBO, C4FM, MotoTRBO, IDAS, NEXEDGE, NXDN, D-STAR, Project 25/P25/APCO-25 digital voice, etc. Mixed voice and data, including TDMA DMR 2-slot DMR as well as TDMA and FDMA P25 are also permitted.
Motorola RDM2070D VHF MURS
Motorola RDM2020 VHF MURS
Motorola RDM2080D VHF MURS
Retevis RT-27V MURS VHF
- 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Mount Jackson, Virginia (Shenandoah County, VA) very large coverage area - 151.880 MHz 156.7 PL
- 151.8800 MHz MURS Channel 2 156.7 Hz CTCSS/PL - Richmond, Virginia (low power - located in downtown Richmond, VA) - 151.880 MHz 156.7 PL
- The Mount Jackson, VA MURS simplex repeater - Confirmed active May 2020 - has 50+ mile radius coverage in the valleys below and even further from higher elevations in the Blue Ridge Mountains and Virginia Piedmont region. Coverage extends into portions of West Virginia and western Maryland. Very large footprint.
- The Richmond, VA MURS simplex repeater - Temporarily off the air as of 27 July 2020 - has considerably less coverage due to its low power transmitter and location in an urban area. Antenna is located on top of a low-rise building, ERP is approx. 4-6 watts. 156.7 Hz tone required to open repeater - repeater equipment switched to FRS channel 7 462.7125 MHz [156.7 Hz CTCSS tone].
- 151.8200 MHz - Militia/Patriot MURS VHF MURS 1 - Tactical and Calling
- 151.8800 MHz - Militia/Patriot MURS VHF MURS 2 - Sovereign Citizen Freeman Primary Patriot Radio Channel
- 151.9400 MHz - Militia/Patriot MURS VHF Primary/Calling MURS 3 - AmRRON
- 151.9400 MHz - Militia/Patriot MURS VHF Patriot Nationwide Primary MURS 3 (see also: FRS 3 and CB 3)
- 154.5700 MHz - Militia/Patriot MURS VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel
- 154.6000 MHz - Militia/Patriot MURS VHF MURS 5
Alternate VHF militia plans:
- 151.8200 MHz - Channel 1 - Operations MURS 1
- 151.8800 MHz - Channel 2 - Operations MURS 2
- 151.9400 MHz - Channel 3 - Calling Primary / Operations MURS 3
- 154.5700 MHz - Channel 4 - Operations MURS 4
- 154.6000 MHz - Channel 5 - Operations MURS 5
- 151.9100 MHz - Channel 6 - Operations VHF 6 Business Band
- 154.5550 MHz - Channel 7 - Operations VHF 7 Business Band
- 154.6250 MHz - Channel 8 - Operations VHF 8 Business Band
- 151.5950 MHz - Channel 9 - Operations VHF 9 Business Band
- 151.5050 MHz - Channel 10 - Operations 10 VHF Itinerant Business
- 151.5125 MHz - Channel 11 - Operations 11 VHF Itinerant Business
- 151.6250 MHz - Channel 12 - Operations 12 VHF Itinerant Business
- 151.6400 MHz - Channel 13 - Operations 13 VHF Itinerant Business
- 151.7000 MHz - Channel 14 - Operations 14 VHF Itinerant Business
- 151.7600 MHz - Channel 15 - Operations 15 VHF Itinerant Business
- 151.8200 MHz - MURS1 - CALLING / TACTICAL MURS Ch 1
- 151.8800 MHz - MURS2 - SOVEREIGN CITIZEN FREEMEN MURS Ch 2
- 151.9400 MHz - MURS3 - PATRIOT NATIONWIDE PRIMARY MURS Ch 3
- 154.5700 MHz - MURS4 - PATRIOT REGIONAL SECONDARY MURS Ch 4
- 154.6000 MHz - MURS5 - MURS Ch 5
- 151.7000 MHz - BIZ 5 - BUSINESS 5 / FREEBAND / PATRIOT / MILTIIA
- 151.7600 MHz - BIZ 6 - BUSINESS 6 / FREEBAND / PATRIOT / MILTIIA
- 152.9450 MHz - BIZ 7 - BUSINESS 7 / FREEBAND / PATRIOT / MILTIIA
- 151.8350 MHz - BIZ 8 - BUSINESS 8 / FREEBAND / PATRIOT / MILTIIA
- 151.8050 MHz - BIZ 9 - BUSINESS 9 / FREEBAND / PATRIOT / MILTIIA
- 151.5125 MHz - BIZ 10 - BUSINESS 10 / FREEBAND / PATRIOT / MILTIIA
- 151.6550 MHz - BIZ 11 - BUSINESS 11 / FREEBAND / PATRIOT / MILTIIA
- 151.6850 MHz - BIZ 12 - BUSINESS 12 / FREEBAND / PATRIOT / MILTIIA
- 151.7150 MHz - BIZ 13 - BUSINESS 13 / FREEBAND / PATRIOT / MILTIIA
- 151.7450 MHz - BIZ 14 - BUSINESS 14 / FREEBAND / PATRIOT / MILTIIA
- 151.7750 MHz - BIZ 15
- 151.8650 MHz - BIZ 16
- 152.7000 MHz - BIZ 18
- 154.4900 MHz - BIZ 19
- 154.5150 MHz - BIZ 20
- 154.5275 MHz - BIZ 21
- 154.5400 MHz - BIZ 22
- 153.0050 MHz - BIZ 23
- 154.6650 MHz - BIZ 24
- 158.4000 MHz - BIZ 25
- 158.4075 MHz - BIZ 26
- 146.4850 MHz - HAMV48 - 2 meter amateur radio ham channel 146.485 MHz Patriot/Militia
- 151.880 MHz - MURS 2
- 154.570 MHz - MURS 4
- 154.600 MHz - MURS 5
- 151.655 MHz - VHF Business
- 151.685 MHz - VHF Business
- 151.715 MHz - VHF Business
- 151.745 MHz - VHF Business
- 151.775 MHz - VHF Business
- 151.805 MHz - VHF Business
- 151.835 MHz - VHF Business
- 151.865 MHz - VHF Business
- 151.895 MHz - VHF Business
- 151.925 MHz - VHF Business
- 151.955 MHz - VHF Business
- 152.870 MHz - VHF Business
- 152.885 MHz - VHF Business
- 152.900 MHz - VHF Business
- 152.915 MHz - VHF Business
- 152.930 MHz - VHF Business
- 152.945 MHz - VHF Business
- 152.960 MHz - VHF Business
- 152.975 MHz - VHF Business
- 152.990 MHz - VHF Business
- 153.005 MHz - VHF Business
- 154.4825 MHz - VHF Business (narrowband)
- 154.490 MHz - VHF Business
- 154.4975 MHz - VHF Business (narrowband)
- 154.505 MHz - VHF Business (narrowband)
- 154.515 MHz - VHF Business (narrowband)
- 154.5275 MHz - VHF Business Itinerant (narrowband)
- 154.540 MHz - VHF Business
- 154.5475 MHz - VHF Business
- 154.555 MHz - VHF Business (narrowband)
- 154.625 MHz - VHF Business (narrowband)
- 154.655 MHz - VHF Business (narrowband)
- 158.4075 MHz - VHF Business Itinerant (narrowband)
