Part 15
13.56 MHz (13560 kHz) x2 = 27.12 MHz (27120 kHz)
11 meter band 27 MHz operations under Part 15. 26.980 MHz - 27.280 MHz (covers the area between CB channels 2 and 28 - 26.975 MHz to 27.285 MHz).
(a) The field strength of any emission within this band shall not exceed 10,000
microvolts/meter at 3 meters. The emission limit in this paragraph is
based on measurement instrumentation employing an average detector.
The provisions in 15.35 for limiting peak emissions apply.
RC frequencies:
- 26.995 MHz
 - 27.045 MHz
 - 27.095 MHz
 - 27.145 MHz
 - 27.195 MHz
 - 27.255 MHz
See also: the RC Radio Service, the CB Radio Service, and high power datalink systems that use 26-27 MHz.
This section applies to cordless telephones. 43.71 MHz to 44.49 MHz (43.72 MHz to 44.48 MHz), 46.60 MHz to 46.98 MHz (46.61 MHz to 46.97 MHz), 48.75 MHz to 49.51 MHz (48.76 MHz to 49.50 MHz and 49.66 MHz to 50.0 MHz (49.67 MHz to 49.9 MHz). Note that the frequencies overlap with the VHF low band business radio band, the military bands, the 49 MHz RC 49 MHz remote control device frequencies and 49 MHz short range devices (walkie-talkies, baby monitors, etc.) The original 10 channel cordless phones used the 46.6 MHz - 47.0 MHz and 49.6 MHz to 50.0 MHz ranges only (46.610 MHz - 46.970 MHz and 46.670 MHz - 49.990 MHz).
 - 49.850 MHz - Channel 2
 - 49.870 MHz - Channel 3
 - 49.890 MHz - Channel 4
 - 49.875 MHZ - Channel 4
- 49.850 MHz - Channel 1A
 - 49.870 MHz - Channel 2A
 - 49.830 MHz - Channel 1B
 - 49.890 MHz - Channel 2B
Modern equipment generally uses 2 switchable channels.  Some of these transmitters use a simple 16.6xxx MHz crystal with a frequency tripler circuit (16.610 MHz x3 = 49.830 MHz - 16.61415 MHz x3 = 49.8425 MHz, 16.615 MHz x3 = 49.845 MHz, 16.61575 MHz x3 = 49.84725 MHz, 16.616 MHz x3 = 49.848 MHz, 16.1616 MHz x3 = 49.8484 MHz, 16.61667 MHz x3 = 49.850 MHz, 16.620 MHz x3 = 49.860 MHz etc.) and simple FM modulation.  Frequency steps, channel plans and channel spacing is random and channel labeling or naming is arbitrary and not consistent from manufacturer to manufacturer or even model number to model number - including:
- 49.845 MHz - Channel X
 - 49.875 MHz - Channel Y
Or,
- 49.830 MHz - Channel A
 - 49.860 MHz - Channel B
Or,
- 49.845 MHz - Channel A
 - 49.890 MHz - Channel B
Or,
- 49.840 MHz - Channel A
 - 49.870 MHz - Channel B
Or,
- 49.850 MHz - Channel I
 - 49.870 MHz - Channel II
Or,
- 49.825 MHz - Channel 1
Or,
- 49.870 MHz - Channel 1
Or,
- 49.840 MHz - Channel 1
 - 49.860 MHz - Channel 2
Or,
- 49.8425 MHz - Channel 1 (49.842 MHz or 49.843 MHz offset)
 - 49.8625 MHz - Channel 2 (49.862 MHz or 49.863 MHz offset)
Or,
 - 49.885 MHz - Channel B
Or,
 - 49.875 MHz - Channel B
Or,
 - 49.876 MHz - Channel B (specifically designed to operate off-frequency from 49.875 MHz - 49.876 MHz per FCC ID documentation)
Or,
 - 49.850 MHz - Channel X
 - 49.880 MHz - Channel Y
- 49.870 MHz - Channel A (actually closer to 49.885 MHz, 49.8875 MHz, 49.888 MHz or 49.890 MHz)
 - 49.810 MHz - Channel B - actual center frequency 49.8225 MHz (49.820 MHz or 49.825 MHz on 5 kHz step receivers)
 - 49.870 MHz - Channel 4
 - 49.880 MHz - Channel 5
 - 49.890 MHz - Channel 6
- 49.835 MHz - Channel A
 - 49.850 MHz - Channel B
 - 49.865 MHz - Channel C
Or,
 - 49.890 MHz - Channel C
- 49.835 MHz - Channel 1/A
 - 49.860 MHz - Channel 2/B
 - 49.885 MHz - Channel 3/C
49 MHz R/C transmitters usually use 49.830 MHz, 49.860 MHz or 49.890 MHz.  As noted earlier, frequencies may vary +/- several kHz.  Baby monitors are usually found on 49.83 MHz, 49.86 MHz or 49.89 MHz.  It's common for a set of R/C toys to be sold with one toy using a 49 MHz RC frequency and the other using a 26 MHz or 27 MHz RC frequency.
§ 15.235 Operation within the band
49.82–49.90 MHz.
The provisions in §15.35 for limiting
(b) The field strength of any emissions appearing between the band edges
and up to 10 kHz above and below the
band edges shall be attenuated at least
26 dB below the level of the
unmodulated carrier or to the general
limits in §15.209, whichever permits the
higher emission levels. The field
strength of any emissions removed by
more than 10 kHz from the band edges
emission limits in §15.209. All signals
exceeding 20 microvolts/meter at 3 meters shall be reported in the application for certification.
(c) For a home-built intentional radiator, as defined in §15.23(a), operating
within the band 49.82–49.90 MHz, the
following standards may be employed:
(1) The RF carrier and modulation
products shall be maintained within
the band 49.82–49.90 MHz.
(2) The total input power to the device measured at the battery or the
power line terminals shall not exceed
100 milliwatts under any condition of
modulation.
(3) The antenna shall be a single element, one meter or less in length, permanently mounted on the enclosure
containing the device.
(4) Emissions outside of this band
(5) The regulations contained in
§15.23 of this part apply to intentional
radiators constructed under the provisions of this paragraph.
(d) Cordless telephones are not permitted to operate under the provisions
of this section.
1963 barely 4 pages, 11 1964
1953 Part 15 1957 Part 15 1958 Part 15
1963 Part 15 1964 Part 15 1965 Part 15 1966 Part 15 1967 Part 15 1968 Part 15 1969 Part 15
