Militia Radio Frequencies
- Channel 1 - 462.5625 MHz - FRS 1 - FRS Nationwide Calling
- Channel 2 - 462.5875 MHz - FRS 2 - Tac
- Channel 3 - 462.6125 MHz - FRS 3 - Primary Patriot Militia Calling
- Channel 4 - 462.6375 MHz - FRS 4 - Convoy Tac Ops
- Channel 5 - 462.6625 MHz - FRS 5 - Tac
- Channel 6 - 462.6875 MHz - FRS 6 - Tac
- Channel 7 - 462.7125 MHz - FRS 7 - Tac
- Channel 8 - 467.5625 MHz - FRS 8 - Tac
- Channel 9 - 467.5875 MHz - FRS 9 - Mutual Aid, Tac
- Channel 10 - 467.6125 MHz - FRS 10 - Tac
- Channel 11 - 467.6375 MHz - FRS 11 - Tac
- Channel 12 - 467.6625 MHz - FRS 12 - Tac
- Channel 13 - 467.6875 MHz - FRS 13 - Mutual Aid, Tac
- Channel 14 - 467.7125 MHz - FRS 14 - Tac
- Channel 15 - 462.5500 MHz - FRS 15 - Tac
- Channel 16 - 462.5750 MHz - FRS 16 - Convoy Tac Ops
- Channel 17 - 462.6000 MHz - FRS 17 - Patriot Militia Ops Tactical
- Channel 18 - 462.6250 MHz - FRS 18 - Tac
- Channel 19 - 462.6500 MHz - FRS 19 - Mutual Aid, Tac
- Channel 20 - 462.6750 MHz - FRS 20 - Calling/GMRS Travel Channel
- Channel 21 - 462.7000 MHz - FRS 21 - Tac
- Channel 22 - 462.7250 MHz - FRS 22 - Tac
- Channel 31 - 151.8200 MHz - MURS 1 - Calling, Tac/Ops
- Channel 32 - 151.8800 MHz - MURS 2 - Command or Safety Channel
- Channel 33 - 151.9400 MHz - MURS 3 - Primary Patriot Militia Calling or Prepper Frequency Prep
- Channel 34 - 154.5700 MHz - MURS 4 - Command Blue
- Channel 35 - 154.6000 MHz - MURS 5 - Command Green
- FRS 1 - 462.5625 MHz - 67.0 Hz
- FRS 2 - 462.5875 MHz - 71.9 Hz or 118.8 Hz
- FRS 3 - 462.6125 MHz - 74.4 Hz, 88.5 Hz or 127.3 Hz.
- FRS 4 - 462.6375 MHz - 131.8 Hz
- FRS 5 - 462.6625 MHz - 136.5 Hz, 79.7 Hz, or 88.5 Hz
- FRS 6 - 462.6875 MHz - 141.3 Hz
- FRS 7 - 462.7125 MHz - 97.4 Hz or 146.2 Hz
- FRS 8 - 467.5625 MHz - 88.5 Hz
- FRS 9 - 467.5875 MHz - 88.5 Hz, 97.4 Hz, or 127.3 Hz
- FRS 10 - 467.6125 MHz - 77.0 Hz or 88.5 Hz
- FRS 11 - 467.6375 MHz - 88.5 Hz
- FRS 12 - 467.6625 MHz - 88.5 Hz
- FRS 13 - 467.6875 MHz - 88.5 Hz
- FRS 14 - 467.7125 MHz - 88.5 Hz or 107.2 Hz
- FRS 15 - 462.5500 MHz - 71.9 Hz, 123.0 Hz or 141.3 Hz
- FRS 16 - 462.5750 MHz - 141.3 Hz
- FRS 17 - 462.6000 MHz - 141.3 Hz
- FRS 18 - 462.6250 MHz - 127.3 Hz
- FRS 19 - 462.6500 MHz - 127.3 Hz or 141.3 Hz
- FRS 20 - 462.6750 MHz - 141.3 Hz strongly recommended
- FRS 21 - 462.7000 MHz - 141.3 Hz
- FRS 22 - 462.7250 MHz - 136.5 Hz
- MURS 1 - 151.8200 MHz - 88.5 Hz CALL
- MURS 2 - 151.8800 MHz - 88.5 Hz or 210.7 Hz CTCSS SAFETY tone transmit recommend 210.7 Hz PL
- MURS 3 - 151.9400 MHz - 88.5 Hz or 141.3 Hz CTCSS PREP tone transmit 141.3 Hz PL
- MURS 4 - 154.5700 MHz - 88.5 Hz COMMAND/TAC BLUE
- MURS 5 - 154.6000 MHz - 88.5 Hz COMMAND/TAC GREEN
- Channel 001 - FRS 1 - 462.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 1
- Channel 002 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 118.8 Hz - display channel name: FRS 2
- Channel 003 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 3
- Channel 004 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 131.8 Hz - display channel name: FRS 4
- Channel 005 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 136.5 Hz - display channel name: FRS 5
- Channel 006 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 6
- Channel 007 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 146.2 Hz - display channel name: FRS 7
- Channel 008 - FRS 8 - 467.5625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 8
- Channel 009 - FRS 9 - 467.5875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 9
- Channel 010 - FRS 10 - 467.6125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 10
- Channel 011 - FRS 11 - 467.6375 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 11
- Channel 012 - FRS 12 - 467.6625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 12
- Channel 013 - FRS 13 - 467.6875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 13
- Channel 014 - FRS 14 - 467.7125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 14
- Channel 015 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 123.0 Hz - display channel name: FRS 15
- Channel 016 - FRS 16 - 462.5750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 16
- Channel 017 - FRS 17 - 462.6000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 17
- Channel 018 - FRS 18 - 462.6250 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 18
- Channel 019 - FRS 19 - 462.6500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 19
- Channel 020 - FRS 20 - 462.6750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 20
- Channel 021 - FRS 21 - 462.7000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 21
- Channel 022 - FRS 22 - 462.7250 MHz - Mode: NFM - Tone: 136.5 Hz - display channel name: FRS 22
- Channel 031 - MURS 1 - 151.8200 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 1
- Channel 032 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 2
- Channel 033 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 3
- Channel 034 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 4
- Channel 035 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 5
- Channel 041 - FRS 1 - 462.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 1 CALL - high power setting
- Channel 042 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 118.8 Hz - display channel name: FRS 2 CALL - high power setting
- Channel 043 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 3 CALL - high power setting
- Channel 044 - FRS 20 - 462.6750 MHz - Mode: NFM - Tone 141.3 Hz - display channel name: FRS 20 CALL - high power setting
- Channel 045 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: MURS 3 CALL - high power setting
- Channel 046 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 4 TAC - low power setting
- Channel 047 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 88.5 Hz - display channel name: MURS 5 TAC - low power setting
- Channel 048 - FRS 8 - 467.5625 MHz - Mode: NFM_ - Tone: 88.5 Hz - display channel name: FRS 8 TAC - low power setting
- Channel 048 - FRS 9 - 467.5875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 9 TAC - low power setting
- Channel 050 - FRS 10 - 467.6125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 10 TAC - low power setting
- Channel 051 - FRS 11 - 467.6375 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 11 TAC - low power setting
- Channel 052 - FRS 12 - 467.6625 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 12 TAC - low power setting
- Channel 053 - FRS 13 - 467.6875 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 13 TAC - low power setting
- Channel 054 - FRS 14 - 467.7125 MHz - Mode: NFM - Tone: 88.5 Hz - display channel name: FRS 14 TAC - low power setting
- Channel 101 - FRS 1 - 462.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 1 HP - high power setting
- Channel 102 - FRS 2 - 462.5875 MHz - Mode: NFM - Tone: 118.8 Hz - display channel name: FRS 2 HP - high power setting
- Channel 103 - FRS 3 - 462.6125 MHz - Mode: NFM - Tone: 127.3 Hz - display channel name: FRS 3 HP - high power setting
- Channel 104 - FRS 4 - 462.6375 MHz - Mode: NFM - Tone: 131.8 Hz - display channel name: FRS 4 HP - high power setting
- Channel 105 - FRS 5 - 462.6625 MHz - Mode: NFM - Tone: 136.5 Hz - display channel name: FRS 5 HP - high power setting
- Channel 106 - FRS 6 - 462.6875 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 6 HP - high power setting
- Channel 107 - FRS 7 - 462.7125 MHz - Mode: NFM - Tone: 146.2 Hz - display channel name: FRS 7 HP - high power setting
- Channel 108 - FRS 8 - 467.5625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 8 HP - high power setting
- Channel 109 - FRS 9 - 467.5875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 9 HP - high power setting
- Channel 110 - FRS 10 - 467.6125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 10 HP - high power setting
- Channel 111 - FRS 11 - 467.6375 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 11 HP - high power setting
- Channel 112 - FRS 12 - 467.6625 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 12 HP - high power setting
- Channel 113 - FRS 13 - 467.6875 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 13 HP - high power setting
- Channel 114 - FRS 14 - 467.7125 MHz - Mode: NFM - Tone: 67.0 Hz - display channel name: FRS 14 HP - high power setting
- Channel 115 - FRS 15 - 462.5500 MHz - Mode: NFM - Tone: 123.0 Hz - display channel name: FRS 15 HP - high power setting
- Channel 116 - FRS 16 - 462.5750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 16 HP - high power setting
- Channel 117 - FRS 17 - 462.6000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 17 HP - high power setting
- Channel 118 - FRS 18 - 462.6250 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 18 HP - high power setting
- Channel 119 - FRS 19 - 462.6500 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 19 HP - high power setting
- Channel 120 - FRS 20 - 462.6750 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 20 HP - high power setting
- Channel 121 - FRS 21 - 462.7000 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 21 HP - high power setting
- Channel 122 - FRS 22 - 462.7250 MHz - Mode: NFM - Tone: 141.3 Hz - display channel name: FRS 22 HP - high power setting
- Channel 123 - MURS 1 - 151.8200 MHz - Mode: NFM - Tone: 77.0 Hz - display channel name: MURS 1 HP - high power setting
- Channel 124 - MURS 2 - 151.8800 MHz - Mode: NFM - Tone: 77.0 Hz - display channel name: MURS 2 HP - high power setting
- Channel 125 - MURS 3 - 151.9400 MHz - Mode: NFM - Tone: 77.0 Hz - display channel name: MURS 3 HP - high power setting
- Channel 126 - MURS 4 - 154.5700 MHz - Mode: FM - Tone: 77.0 Hz - display channel name: MURS 4 HP - high power setting
- Channel 127 - MURS 5 - 154.6000 MHz - Mode: FM - Tone: 77.0 Hz - display channel name: MURS 5 HP - high power setting
- 151.9400 MHz - Militia/Patriot VHF MURS 3 - Primary Calling, Command Nets, AmRRON Patriot Nationwide Primary MURS 3 (also FRS 3, CB 3 and 146.42 MHz)
- 154.5700 MHz - Militia/Patriot VHF MURS 4 - Patriot Regional Channel Patriot Militia Secondary Channel, Vehicle Coordination
- 154.6000 MHz - Militia/Patriot VHF MURS 5 - Tactical or Command Nets
- 467.5625 MHz - Militia/Patriot UHF FRS 8 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.5875 MHz - Militia/Patriot UHF FRS 9 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6125 MHz - Militia/Patriot UHF FRS 10 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6375 MHz - Militia/Patriot UHF FRS 11 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6625 MHz - Militia/Patriot UHF FRS 12 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.6875 MHz - Militia/Patriot UHF FRS 13 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 467.7125 MHz - Militia/Patriot UHF FRS 14 - Tactical, Inter Squad Radio coordination/inter-group cooperation
- 462.5500 MHz - Militia/Patriot UHF FRS 15
- 462.5750 MHz - Militia/Patriot UHF FRS 16 - Patriot Tactical, Vehicle Coordination (see also: FRS ch. 4)
- 462.6000 MHz - Militia/Patriot UHF FRS 17
- 467.5875 MHz - FRS9 - Militia/Patriot UHF FRS Channel 9 - Tactical
- 467.6125 MHz - FRS10 - Militia/Patriot UHF FRS Channel 10 - Tactical
- 467.6375 MHz - FRS11 - Militia/Patriot UHF FRS Channel 11 - Tactical
- 467.6625 MHz - FRS12 - Militia/Patriot UHF FRS Channel 12 - Tactical
- 467.6875 MHz - FRS13 - Militia/Patriot UHF FRS Channel 13 - Tactical
- 467.7125 MHz - FRS14 - Militia/Patriot UHF FRS Channel 14 - Tactical
- Channel 01 - 467.6375 MHz
- Channel 02 - 467.6625 MHz
- Channel 03 - 467.6875 MHz
- Channel 04 - 467.7125 MHz
- Channel 05 - 462.6625 MHz
- Channel 06 - 462.6875 MHz
- Channel 07 - 462.7125 MHz
- Channel 08 - 467.5625 MHz
- Channel 09 - 467.5875 MHz
- Channel 11 - 462.5625 MHz
- Channel 12 - 462.5875 MHz
- Channel 13 - 462.6125 MHz
- Channel 14 - 462.6375 MHz
- Channel 15 - 462.7000 MHz
- Channel 16 - 462.6000 MHz
- Radio A - 5 feet above ground communicating with Radio B - 5 feet above ground = 5 miles line of sight range
- Radio A - 20 feet above ground communicating with Radio B - 5 feet above ground = 9 miles line of sight range
- Radio A - 30 feet above ground communicating with Radio B - 5 feet above ground = 11 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 5 feet above ground = 13 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 5 feet above ground = 17 miles line of sight range
- Radio A - 20 feet above ground communicating with Radio B - 10 feet above ground = 10 miles line of sight range
- Radio A - 20 feet above ground communicating with Radio B - 20 feet above ground = 12 miles line of sight range
- Radio A - 30 feet above ground communicating with Radio B - 10 feet above ground = 12 miles line of sight range
- Radio A - 30 feet above ground communicating with Radio B - 20 feet above ground = 14 miles line of sight range
- Radio A - 30 feet above ground communicating with Radio B - 30 feet above ground = 16 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 10 feet above ground = 14 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 20 feet above ground = 16 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 30 feet above ground = 18 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 40 feet above ground = 19 miles line of sight range
- Radio A - 50 feet above ground communicating with Radio B - 50 feet above ground = 20 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 10 feet above ground = 18 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 20 feet above ground = 20 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 30 feet above ground = 22 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 40 feet above ground = 23 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 50 feet above ground = 24 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 60 feet above ground = 25 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 75 feet above ground = 26 miles line of sight range
- Radio A - 100 feet above ground communicating with Radio B - 100 feet above ground = 28 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 5 feet above ground = 23 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 10 feet above ground = 24 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 25 feet above ground = 27 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 50 feet above ground = 30 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 75 feet above ground = 32 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 100 feet above ground = 34 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 125 feet above ground = 36 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 150 feet above ground = 37 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 175 feet above ground = 39 miles line of sight range
- Radio A - 200 feet above ground communicating with Radio B - 200 feet above ground = 40 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 5 feet above ground = 35 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 10 feet above ground = 36 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 25 feet above ground = 39 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 50 feet above ground = 42 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 75 feet above ground = 44 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 100 feet above ground = 46 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 150 feet above ground = 49 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 200 feet above ground = 52 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 250 feet above ground = 54 miles line of sight range
- Radio A - 500 feet above ground communicating with Radio B - 500 feet above ground = 64 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 5 feet above ground = 48 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 10 feet above ground = 49 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 25 feet above ground = 52 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 50 feet above ground = 55 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 100 feet above ground = 59 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 150 feet above ground = 62 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 200 feet above ground = 65 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 250 feet above ground = 67 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 500 feet above ground = 77 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 750 feet above ground = 84 miles line of sight range
- Radio A - 1000 feet above ground communicating with Radio B - 1000 feet above ground = 90 miles line of sight range
